My '03 CLS6 progress thread
Old Jul 14, 2011 | 09:38 AM
  #321
brian6speed's Avatar
Lone Wolf
Originally Posted by anthracitecl
One more question. Sorry for keep asking. They don't show list for cl.
Which model did you buy for?
radiator cap 19045-XGER-0000
thermostat 19301-XGMR-0000
fan switch 37760-XK5-00N0
Old Jul 14, 2011 | 10:31 AM
  #322
anthracitecl's Avatar
Thanks man. I appreciate it!!!
Old Aug 2, 2011 | 01:18 PM
  #323
Lone Wolf
I removed the driver door panel today and tried hooking up just the door handle/lock piece and the window piece, but it dsnt work unless I plug in the other plug that goes to the light. Anyone know why? I will have to look into it further later.
Old Aug 2, 2011 | 02:31 PM
  #324
Lone Wolf
This is the plug that needs to be plugged in for any controls to work on driver door.
Old Aug 2, 2011 | 08:37 PM
  #325
Originally Posted by brian6speed
I am having an issue with my front brakes and wanted to ask for opinions. I installed the legend calipers and everything seemed fine for the first few months. Then I took my car into Acura and they inspected my brakes without me asking them too. Ever since I got the car back from Acura the front brakes are constantly squeeking now. The weird thing is that they only squeek when you arent using the brakes. When you press the brake pedal the noise goes away and comes back as soon as you release the pedal. It sounds like the pad or something is contacting the rotor when brakes arent being used. Could this be frozen pistons. I have a feeling it is because of using those calipers or because of acura.
I had a similar issue with my Legend calipers. I thought I needed to rebuild them because of the noise, that was something I really did not want to do. So, instead, I thought I would try and replace the shims that attach to the outside of the inner and outer brake pads. Especially the inner pad shims because they are the ones (there's two) that contact the two brake pistons. I bought #'s 16, 17 & 19 on the link below.
http://www.acuraoemparts.com/delray/...All&vinsrch=no
I am certain that #17 was the one that corrected my squeak problem because I never installed a 'second shim' from the old single piston CL caliper. It had one; however, it was smaller and only was big enough for the single piston. It was #11 on the link below.
I only had one shim on the inner pad. That was #10 on the single caliper diagram. Long story short, when I included that #17 shim on the legend diagram, it eliminated the similar noise mentioned above.
I gave parts to my mechanic to rebuild, told him to rebuild and was charged for it so I assume he did it. Looks like I'll have to rebuild again. I don't remember where to get the parts tho.
If you absolutely have to rebuild, your thread below talks about it. The links in posts numbered eleven and twelve lead to rebuild kits and seals for the legend calipers.
https://acurazine.com/forums/2g-cl-2001-2003-50/where-get-caliper-rebuild-kit-782143/
Old Aug 2, 2011 | 08:43 PM
  #326
StreetKA's Avatar
https://acurazine.com/forums/showthread.php?t=782143
that is very helpful but i may give u my
last time i changed brake pads i messed up RETAINER ? # 23
when i was braking everything was fine but when i release, it started to make noise and squeek those parts fixed problem
Old Aug 2, 2011 | 08:51 PM
  #327
StreetKA, are you running legend calipers?
I agree, those maybe the culprit as well. Sometimes these parts wear a bit to fast and the result is an annoying noise that drives you crazzzzy.
Old Aug 2, 2011 | 09:13 PM
  #328
StreetKA's Avatar
i dont but its a same part a belive... i though it might help and dont buy ones from autozona they are aluminium and it gets even worse with them (lesson learned)
Old Aug 3, 2011 | 09:37 AM
  #329
Lone Wolf
thnx for the info will need to look into it. Sometimes I just wish I saved up for a bbk tho.
Old Aug 5, 2011 | 02:08 PM
  #330
Lone Wolf
I am hoping to get alot done this weekend. Gonna remove my audio stuff and all interior parts, clean, rewire audio if i plan to put it back. Hope to have my seat, harness bar and harness in soon. Will be removing the carpet but havnt decided if I will put it back in and see what other weight savings I can do.
I will be putting the front door panels and door sills back, I dont like it without them(too noisy and too many wires showing).
Old Aug 5, 2011 | 02:35 PM
  #331
civicdrivr's Avatar
Get rid of that sound deadening on the floor too. That shit is heavy.
Old Aug 5, 2011 | 03:14 PM
  #332
Lone Wolf
Here is the hole in the floorboard from when a vehicle flung a huge metal something at me on the highway in a construction zone. You can see where the floor is dented in, and the green is plastic i taped underneath to keep water from getting in. Where you see green is where the hole is. It completely bent that one bracket. That brown glue sucks.
Old Aug 5, 2011 | 07:55 PM
  #333
Damn WTH!! sorry to hear that. That's not permanet fix right? you have to do weld to cover up? That's only thing i can think of it.
Old Aug 5, 2011 | 08:00 PM
  #334
Lone Wolf
It happened over a year ago. I havn't fixed it yet. Will rebend the metal back into place and use jb weld most likely.
Old Aug 5, 2011 | 08:24 PM
  #335
Will JB weld work for that? I would do welding for permanent fix. just my opinion. cause i'm not sure about jb weld for the damage...
Old Aug 6, 2011 | 07:23 AM
  #336
Lone Wolf
I dunno. Either I use jb weld or take it to bodyshop to weld. I have never welded and don't have equipment.
Old Aug 6, 2011 | 09:12 AM
  #337
Lone Wolf
I removed the carpet, and most of the sound deadening by driver side rear passenger feet. I weighed the carpet and it weighs 23 lbs. Here is some of the change I found in the car under the carpet, looks 100 years old.
Old Aug 7, 2011 | 07:12 PM
  #338
Lone Wolf
I removed the cross member to get at the front driver seatbelt.
Removed the audio system and navi.
I installed the seat. Still need to do the harness bar and harness just test fitting stuff first. Cant wait to drive it like this and see how light it is. Seating position is really low, almost too low for me.
[IMG]http://i1083.photobucket.com/albums/j388/brian6speed/interiorremoval02
Old Aug 7, 2011 | 09:05 PM
  #339
StreetKA's Avatar
woooooooow man i love it seat looks amazing you're the boss now
Old Aug 8, 2011 | 10:11 AM
  #340
Lone Wolf
thnx
Old Aug 8, 2011 | 11:10 AM
  #341
StreetKA's Avatar
What's total weight savings now ?
Old Aug 8, 2011 | 08:10 PM
  #342
+1
Damn I love new seat!! looks really nice!
Old Aug 8, 2011 | 08:42 PM
  #343
civicdrivr's Avatar
The new seat looks great. Were you ever able to find a matching seat of the passenger side?
Old Aug 8, 2011 | 11:16 PM
  #344
Lone Wolf
I am not sure. I can make an itemized list of what is removed, but that wont count the stuff already installed that Id rather not remove just to weigh and put back on.
+1
thnx
thnx, no I didn't find one. Not sure if I want to spend that much just for a seat for passengers.
http://www.nengun.com/recaro/sp-g-iii-kk that is closest I could find, but its black with white stitching.
Could do a reclining recaro with the same color setup like this. http://www.gotuning.com/product_info...oducts_id=1187
Old Aug 10, 2011 | 09:21 PM
  #345
Lone Wolf
Since you have asked I decided to weigh everything I could and made a list. For the bigger items I used a scale that weighs to .5 lbs, and for smaller items I used a food scale that weighs to the gram. I put (not sure) for items I don't have anymore or are installed and I don't feel like removing just to weigh.
Weight Reduction Progress
03 Acura CL-S 6
curb weight 3446 lbs
WHEELS
SSR wheels -32lbs
Project Kics Lugs -1.05 lbs
TRUNK
Spare tire -29.5 lbs
Jack -3.63 lbs
Trunk tools -1.61 lbs
Trunk carpet floor -8 lbs
Trunk side carpet(2 pieces) -6 lbs
Trunk plastic -3.06 lbs
Trunk lid cover/fabric (don't have)
Stock amp -1.75 lbs
REAR SEAT
C Pillars(x2) -1.81 lbs
Rear decklid -3 lbs
Third brake light -.72 lbs
Rear speakers -3.58 lbs
Rear seat belts -4.4 lbs
Rear seat back -26 lbs
Rear seat bottom cushions(x2) -11 lbs
Rear seat console -7 lbs
Rear seat side panels(x2) -11 lbs
1 piece sound deadening driver passenger floor -3.5 lbs
FRONT SEATS
Driver seat swapped for Recaro(20.2) -46.8 lbs
Passenger seat(can put back in when needed) -54.5 lbs
B Pillars(x2) -.93 lbs
Kick panels(x2) -.68 lbs
Center console -13.69 lbs
Carpet -23 lbs
Stock radio -6.07 lbs
Driver seatbelt -4.7 lbs
Steering column plastic -1.83 lbs
Front speakers -4.1 lbs
Mugen/ works bell steering wheel(stock delete) -5 lbs
ENGINE BAY
Braille battery(15 lb) -23.5 lbs
Cruise control -2.81 lbs
Front bumper damper -7 lbs
Engine cover (not sure)
Small engine cover -.92 lbs
Plastic over radiator -1 lbs
Hood fabric cover (not sure)
Comptech strut bar (not sure)
Comptech headers (not sure)
XLR8 cat(probably -3 to -5 lbs) (not sure)
Zeal coilovers (not sure)
Option pulley (not sure)
Random removed bolts and clips (not sure)
Subracted weight I am sure of -335.14 lbs
ADDED WEIGHT
Stock spoiler (not sure)
Harness bar +10 lbs
Harness +3.5 lbs
UR bar (not sure)
Cusco bar (not sure)
Old Aug 13, 2011 | 11:03 PM
  #346
Lone Wolf
I decided to fix the door panel armrest gap issue on my driver panel while I had it removed. I used rhino glue that I ordered online. I bought the bag of clips at walmart and got the paint stick free from home depot. You just spread the glue between the seperated foam and plastic part. Then using the clips attach on the back plastic and on the paintstick. Let it sit for an hour or two then remove the clips. Just be careful not to get glue on anything cause you wont get it off.
Old Aug 14, 2011 | 05:24 AM
  #347
StreetKA's Avatar
350lbs that awesome. Your car should run mid 13's now what suspension are u running last time i removed few things car was 4x4 back again.
Btw i like Maxim too
Old Aug 14, 2011 | 07:28 AM
  #348
Lone Wolf
I reinstalled my zeal coilovers I had rebuilt. The car is pretty high but I can adjust. The car feels extremely light now. It accelerates, brakes and turns so easy. I dunno why but it seems like shifting is easier and smoother.
I am happy with the seat it fits me great. It is really comfortable for a bucket seat. I am kind of glad I wasnt able to get another for passenger. My friend couldn't even fit in the seat, and most people I have in the car can't fit in it. I would have to get the xl seat or a reclining seat for passenger.
After I get motor mounts I will begin the engine work. 13's should be pretty easy I'd think.
Old Aug 14, 2011 | 08:58 AM
  #349
StreetKA's Avatar
I know the feeling i did remove back seats passenger seat everything from a trunk and i eas able to hit 13.8. Thats around 100-130lbs of savings. I still weight 240lbs though, you must by skinny to fit in that seat. Im sure you will break 13.5 easy. As long as cl is my daily i wont do that to her but i may get something else instead then we'll see.
Old Aug 14, 2011 | 09:45 AM
  #350
Lone Wolf
I only weigh 135 and my waist is 30-32 so yea I am small.
Old Aug 14, 2011 | 10:36 AM
  #351
nspec_ya4's Avatar
Regional Coordinator (Texas)
wow. a lot of weight reduction going on. and that hole in the floor definitely sucks. love the seat!
Old Aug 14, 2011 | 07:56 PM
  #352
350lbs weight reduction... hmm... That's freaking great!!! Damn I can't wait to see you break 13.5! What is your plan for your angine? pnp intake and runner? I remember you bought one from p2r. Am i wrong?
Old Aug 14, 2011 | 08:27 PM
  #353
StreetKA's Avatar
135lbs i would never fit in that seat lol that like 450lbs weight reductions... must feel great
Old Aug 16, 2011 | 09:35 PM
  #354
Lone Wolf
Engine mods will be option ud pulley, ported runners, ported IM, bored tb, p2r plenums, mdx horns, p2r tb spacer, p2r thermal gaskets,comptech headers and comptech icebox. I am also going to install the tl springs to protect from over rev.
Only other things I plan on doing with engine is maybe custom header or header collectors and exhaust. With the reduced weight I think I will be plenty happy with the power.
Old Aug 18, 2011 | 09:34 AM
  #355
Lone Wolf
So I purchased/paid for a radiator from excelerate that will be made by griffon. I gave them my car info and was told they already had the dimensions to make radiator. Keep in mind I paid over 4 months ago. When I received the radiator it did not fit so I sent it back. They asked me to take measurements of my stock radiator to fix it. I sent them dimensions multiple times and waited. Then weeks or a month later they tell me that I have to send in my stock radiator or they refuse to fix it. So I bought a brand new knockoff stock radiator I had to pay for and I had to pay shipping. Then I don't hear anything from them for another fee weeks. Now they tell me modifying the radiator to fit is not possible and they would have to make a whole new one. According to griffon i am liable for this problem. They refuse to do this unless I pay them another 500 on top of the 6-700 I have already spent. I told them I will not pay another cent. Now my only option is to take legal action.
Old Aug 18, 2011 | 10:44 AM
  #356
richardparker's Avatar
3.7L Nitrous Breathing CL
That sucks man.
Good heads up too.
How did you make payment.
what is their policy with cutom parts ?
Most places that make custom parts will not offer no refunds.
But if they went by their spec's then they should have had their shit together.
And that might be able to get your funds back.
They do not want to pay for the new material and that's their problem.
material is always the biggest factor is custom jobs.
good luck getting you stuff straght.
Old Aug 18, 2011 | 11:33 AM
  #357
Lone Wolf
I got email today from excelerate that he will work it out and pay them. I must say excelerate is an amazing vendor and I really appreciate what he is doing. He has always answered my emails promptly. I feel bad about the whole situation and just wish it went smoothly and noone had to lose out on this deal. The only winner in this situation is Griffon since they are getting paid twice.
I dunno if I want to deal with anymore custom parts, not worth the headache.
Old Aug 18, 2011 | 12:43 PM
  #358
If Griffon was the fabricator on the thread below that XLR8 used for aluminum radiators, it seems that they should have had already worked out the proper measurements, especially since the thread specifically states the radiator is for 01-03 CL, CL-S, 99-03 TL, TL-S.
https://acurazine.com/forums/sponsored-sales-group-buys-10/xlr8-custom-aluminum-radiators-368175/
I was saving to purchase that Griffon aluminum radiator, back in 2007, when someone found an alternative made by CSF for almost half price, which I ended up buying. Its been trouble free since.
Great to hear it's working out for you, although something smells rotten in Denmark, err, Griffon.
Old Aug 23, 2011 | 02:53 PM
  #359
gnuts's Avatar
3.5 psi
For your seat, how are they mounted? Did everything come with the seat? Does the back recline?
Old Aug 23, 2011 | 08:14 PM
  #360
Damn that really sucks. I hope everything goes well.
