Possible New Mod??
Dynojet
Im going to look into it somemore tomorrow after work if not monday. If it doesnt require a rebuild then Ill hold off for a few months. But if it does, Ive already been in contact with NVA-AV6 so hopefully he has some free time in his schedule to do it.
post the graph so i can see it ... the graph may revel alot ... btw my 3.5 consistantly went through oil id know i was down 2 qts when it would start to fuel cut at vtec
Got home late and then the Yankee game took up the rest of my night
Im uploading the runs right now. I just realized while taking pics that the first runs were done on SAE Smoothing 3 and the after runs were done on SAE Smoothing 5. I called the shop and he's got them saved so he's going to set the smoothing to 3 and email me the graphs. Hopefully I get them today.
I also noticed that my car is running extremely lean up to 3500rpm. You'll see in the graphs. Give me a few minutes to get them loaded.
Before:
After:
The lean condition up to 3500rpm has me worried.
THE AFTER RUNS ARE NOT SET TO THE SAME SMOOTHING! I SHOULD HAVE THE CORRECT GRAPHS LATER TODAY*!!!IT WAS ALSO 96 DEGREES ON THE AFTER RUNS WHILE THE BEFORE RUNS WERE DONE IN 81 DEGREE WEATHER.
*As long as the shop does it for me.
After:
Did the shop get you the revised sheet? did the numbers go up to 4,000,000???
Lol, no the shop hasnt email me the sheet yet. Theyre closed today so Ill call tomorrow and get on their case about it. Once they set it to the correct smoothing I believe it will be more then 240.
Im ordering my new clutch today or tomorrow so my 3.5 build should be starting within the next month or so.
Yea, the shop sent me the corrected graphs this afternoon. That printout that I have is the first run. The second and third runs showed the AFR correctly, no spiking.
The numbers are about the same with the SAE smoothing set to 3.
You should really ask if they can overlay the best before run with the best after run on 1 graph. That's the real way to see what kind of power you made. Those numbers are peak numbers and that's it. A quick comparison of the torque lines shows how good of a gain this made. Your previous run, the torque barely went above the 200 mark. The after run, it comes up much higher and stays there for longer. It would be nice to see the HP overlapped.
shoot me a PM if when you go!
TL-P should show more gains
