Possible New Mod??
Old Jun 28, 2009 | 05:12 PM
  #441
CleanCL's Avatar
Why did you adjust the TPS? I have never touched it even after bored throttle body. Do you still have your core TB? Swap the TPS over if you do.
Old Jun 28, 2009 | 05:17 PM
  #442
civicdrivr's Avatar
I had to swap the TPS from my old TB to the new one. The bored tb didnt have any sensors attached. It was just the bare tb.
Ive decided to postpone the dyno results. I dont want to drop the money on it knowing that theres something wrong, and I dont want to misrepresent this swap in any way. Ill have the results within the next week though, it just wont be tomorrow.
Old Jun 28, 2009 | 05:21 PM
  #443
e30cabrio's Avatar
LFG RANGERS!!!!!!!!!!!
OMG WTF????
post teh nmbrz
dyno it dyno it bwahaaaaaaaaaaaaaaaaaaaa
Old Jun 28, 2009 | 05:26 PM
  #444
DC3328's Avatar
Your Garage
did you fix the exhaust leak? i think since you did the before dyno with it you should do the after with the leak too
Old Jun 28, 2009 | 06:43 PM
  #445
civicdrivr's Avatar
Thats exactly what Im doing. Everything will be the same. The only variables are the manifold and the weather. Im pretty sure Im narrowed my leak down, in which case I have a fix for it. I just have to wait for the "fix" to arrive
Old Jun 29, 2009 | 10:41 AM
  #446
suspekt360's Avatar
CLS^6
I just wanted to post a thank-you to 'civicdrivr' and 'e30cabrio' for doing the testing of these intake manifolds. Spending several hundred dollars on a modification that wasnt proven AND sharing the details as they went along (to the extent they have and with zero vested interest) is commendable. I know I am standing on the side-lines waiting for the bugs to be worked out before I commit to the IM swap but that doesnt leave me feeling good that these two guys had to spend the personal time/money/stress working out the bugs for my benefit. I know they would have done the mod regardless of others watching or not, but they took the personal time to share their progress and assist the forum in understanding what they have done to date on this.
At any rate, if they setup a paypal account, I would gladly send some $'s their way to show appreciation for the investment they made in ironing out the bugs so others could simply 'walk-in' to the mod. Maybe this flies in the face of how this forum works, but i am not talking big dollars, just a little something to show gratitude.
Thanks guys and by all accounts, this is looking to be a very promising mod. It will be my next mod as I am certain it will have excellent synergies with all the other modifications.
My mods at present on 2003 CL-S6 (btw, this is my 2nd CL, last was auto 2001 CL-S):
- comptech headers_installed 2 weeks ago_new from CT
- option pulley_installed 1 month ago
- P2R test pipe_inst 1 month ago
- Custom Cat-back exhaust (vibrant 3" in/out ultra quiet resonator)_installed 2 weeks ago
- Vibrant street power mufflers (got them locally for $70/each, that is why I chose them)
***exhaust will be switched to 3" b-pipe, and 2.5" axle back. Full mandrel.
- AEM CAI_came with car
- Koni yellow's on H&R springs
Remaining mods:
- Rear progress sway bar
- '09 TL- SH-AWD IM
- Tune (still not sold on what is the best way to tune a non-FI CLS6... neo/emanage?
Thanks again guys for your work...
Old Jun 29, 2009 | 11:15 AM
  #447
civicdrivr's Avatar
Thankyou for the offer, but I dont want any money from you guys. Ive gotten plenty of ideas from this forum as well as others over the past few years that I think its about time I returned the favor.
I didnt mean to bring up the amount of money I had put into this in my little outburst, but it was just a frustrating day. I am quite confident that I figured out what the problem is, so it will be fixed by wednesday or thursday. Once I get numbers, the DIY will be posted, with pictures and all the little work arounds I had to deal with.
Hold off on deciding what to tune with. On one of the other forums we are talking with a company to make a direct PnP system for these engines and gives you full control. It is projected to be a bit pricey, around $1300, but if it does what its supposed to it is more then worth it in my mind (at least with what Im planning to do to the car )
Old Jun 30, 2009 | 02:00 PM
  #448
civicdrivr's Avatar
The parts I needed to fix the idle issue should be here today. UPS says they are out for delivery. I scheduled the dyno run for thursday afternoon, around 3pm after I get off from work. With any luck you guys will have results thursday evening.
Old Jul 2, 2009 | 07:48 PM
  #449
gfrg88's Avatar
slow tl..
any updates??
Old Jul 2, 2009 | 09:40 PM
  #450
AnthraciteBeast's Avatar
subscribed
Old Jul 3, 2009 | 09:53 AM
  #451
civicdrivr's Avatar
Update:
This car is pissing me the fuck off. I replaced the IACV. I replaced all gaskets. Ive replaced all the vacuum lines. The idle is still fucked up. Ive adjusted the idle speed screw. I adjusted the idle butterfly bolt (the one near the cables), and I have slack in my throttle cables. The car refuses to idle lower then 1500rpms. I am about to swap the throttle body. If that doesnt work I will try one more thing. Whenever I hit the gas I hear a "woosh" sound coming from the throttle body side of the intake. The top plate may not be sealing properly. If that isnt it, then the last thing Im checking is the intake manifold itself. Its possible that Honda didnt seal the two halfs correctly and its sucking air in from there. Theres absolutely no reason why it should be giving me this much of a headache. E30 and P2R has gotten this setup to work fine. My car just seems to be the problem child.
And no, I didnt get the after dynos yesturday because of the idle issue. If it truely is a vacuum leak, I didnt want to dyno it if it would be down on power.
Old Jul 3, 2009 | 09:56 AM
  #452
Rajca's Avatar
wham bam thank you ma'am
and when u switch the tb and still doesnt idle right, switch the im to the stock one. than if its possible but the p2r tb on the stock im and check if u have any leaks
Old Jul 3, 2009 | 10:48 AM
  #453
civicdrivr's Avatar
Thats what Im planning. Im heading outside to check out the throttle body and top cover.
Old Jul 3, 2009 | 11:19 AM
  #454
Rajca's Avatar
with the car running, i forgot the name of the tool, but u spray this white power thing over where u thing its leaking and it will suck it in, no harm caused to the engine and will find the leak for you
Old Jul 3, 2009 | 12:08 PM
  #455
Pinho's Avatar
i belive snap-on make a smoke testing machine...once i had a leak on my H22 intake manifold that i welded and i was running into the same problem...my mechanic had a tester that put pressured smoke in the intake manifold and we found out where the crack came from...maybe u know someone that has this tool??? good luck
Old Jul 3, 2009 | 12:21 PM
  #456
Rajca's Avatar
^thats what it was, u can do it with the car running or off
Old Jul 3, 2009 | 05:35 PM
  #457
Pinho's Avatar
no no..u put the smoke in the intake manifold through a vacume line going to the intake manifold and u cap the TB so there is a complete seal...because when u hook up the machine it creates pressure in the intake manifold ..now if u see the smoke there is a leak somwhere...this is a good test machine if u know someone who has one
Old Jul 3, 2009 | 07:31 PM
  #458
Rajca's Avatar
so.... whats stops it from going into the cylinders and out the exhaust? but u will see some come out if u have a leak
Old Jul 3, 2009 | 07:36 PM
  #459
SPoolinspOON's Avatar
OG 3.x^7 rawr
Tdc?
Old Jul 3, 2009 | 11:39 PM
  #460
e30cabrio's Avatar
Sorry this is not resolved for you Civic, I have a bit more than2k on mine and it runs great, I drove to L.A. this morning, got on it in the middle of nowhere and all I can say is I really love the car.
Old Jul 4, 2009 | 09:40 AM
  #461
gnuts's Avatar
3.5 psi
I think i need to pull the trigger on this mod!
Old Jul 5, 2009 | 12:00 AM
  #462
civicdrivr's Avatar
I put the stocker back on today. The manifold was 100% the issue. I am heading to Honda monday to *hopefully* exchange this one. It was leaking from the rear. I put the old manifold on and no idle problems.
Driving with the new manifold on that car felt like it had balls. According to my seat-of-the-pants dyno, it was making about 10hp more over the stock manifold. I cant wait to get a non-leaking manifold.
Sorry to those of you waiting for after numbers. Its going to be alittle while longer. Unfortunately something like this is out of my control. If its going to take more then two weeks to get a new manifold, Im going to get the exhaust fixed and re-do the before dyno runs. That also is dependant on if my new cat comes in before the manifold.
Old Jul 5, 2009 | 12:24 AM
  #463
e30cabrio's Avatar
That sucks. Is it cracked? I am really sorry but glad you got it worked out. Hopefully they get you another quicker than you got this one.
Old Jul 5, 2009 | 12:37 AM
  #464
gnuts's Avatar
3.5 psi
I think i'm going to order mine soon, not sure how long it will take to come in. I'll need P2R parts as well so it may be a while. I'll look into before and after dynos. I'm getting exhaust and pulley put on this week coming up, so the motor should be peachy.
Old Jul 5, 2009 | 12:58 AM
  #465
civicdrivr's Avatar
It wasnt cracked, but I think the sealant they used to seal the two halfs wasnt doing its job. Once I put the old manifold on it ran like it used to. Im glad it wasnt something electrical.
Old Jul 5, 2009 | 02:39 AM
  #466
LIPPSTUH's Avatar
Unregistered user
im glad you found the problem. hope you continue with this mod. sucks to have your project car as your DD. good luck
Old Jul 5, 2009 | 01:39 PM
  #467
nf3d0149ab's Avatar
Old Jul 5, 2009 | 05:27 PM
  #468
civicdrivr's Avatar
Yea, Im just happy I didnt sell my stock manifold before I found the issue. I cant wait to get it back on. The car is slow as hell now compared to what it was.
Old Jul 6, 2009 | 12:07 PM
  #469
e30cabrio's Avatar
What did the dealer say? When will you get the replacement?
Old Jul 6, 2009 | 12:31 PM
  #470
civicdrivr's Avatar
Havent gone yet Im waiting for package to arrive for work then I have to go work on some servers
Not sure if Ill be able to get there today.
Old Jul 6, 2009 | 12:58 PM
  #471
LIPPSTUH's Avatar
Unregistered user
wonder if its possible to compared if the tb with the new manifold is positioned any higher/lower or forward or backward... for s/c purposes...
Old Jul 6, 2009 | 08:01 PM
  #472
e30cabrio's Avatar
Drove 850 miles this weekend Phoenix to L.A. Here are some impressions from the road.
at speed (60+) flooring it is much improved, 100 comes very quickly (2seconds?)
There are now three distinct power transitions when floored from 5th gear, first the 4th drop down, then VTEC, then the butterfly.
Each gives a surge of new power. I was with my Wife so I did not venture too fast but I was able to keep up with and keep in front of (when I was in front) a C6 Vette convertible for over two hundred miles of position jockeying.
The car was ok when I got it (stock) now it is reasonably fast as well as comfortable. I averaged 27mpg at an average of 75mph over the course of the trip
Old Jul 6, 2009 | 08:10 PM
  #473
Pinho's Avatar
did u make an appointment at a local dyno yet?...its good to hear that this combo works well and performes well..just wondering the difference in hp
Old Jul 6, 2009 | 08:17 PM
  #474
Rajca's Avatar
civicdrivr is the one that will be dynoing.
Old Jul 6, 2009 | 08:32 PM
  #475
e30cabrio's Avatar
It is 113 here now, will not be under 90 until November so any dyno numbers I get will be low. I won't be thinking about dynoing it at least until it cools off if ever.
I just don't care whet the actual number is, I know it is considerably more than the 220-225 it was at the wheels stock, I am guessing 250+
Old Jul 6, 2009 | 08:34 PM
  #476
Rajca's Avatar
cant see anyone getting 20+whp on of this intake manifold
Old Jul 6, 2009 | 08:39 PM
  #477
e30cabrio's Avatar
Did I say those numbers are from the manifold? I am saying all my mods:
P2R CAI,Thermal gaskets, 71mmTB 09 3.7TL Intake Manifold VSA- DC Sport headers,RT Cat Magnaflow 2.5" exhaust UR Pulley set, Unichip
And I am being conservative so people like you won't say I am exaggerating.
Old Jul 7, 2009 | 12:05 AM
  #478
LIPPSTUH's Avatar
Unregistered user
well at least its butt-dyno.... only mods we have that are like that are headers.... maybe pulleys... thats about it...
Old Jul 7, 2009 | 12:31 AM
  #479
e30cabrio's Avatar
If we go conservative from 220 at the wheels I come up with:
220
20 + Headers
10 + Unichip
7 + spacer/thermal gaskets
10 + CAI/bored tb
10 + 09 intake
277
Old Jul 9, 2009 | 07:41 PM
  #480
civicdrivr's Avatar
Im fighting some other issues with my car right now. Its been off the road for the past three days. For me, when things go bad, they go real bad. Im battling CELs and yesturday I got a flat and a bent rim. Go me.
