Possible New Mod??
Old Jul 9, 2009 | 07:48 PM
  #481
e30cabrio's Avatar
LFG RANGERS!!!!!!!!!!!
That sucks, I feel your pain especially the rim. Remember I bent two right after doing the mod?
I have a new rim in back & the cracked one that I had fixed in front. There is a slight vibration so I figured I'd swap the rims front to back, couldn't get the new one off the back it was somehow stuck to the hub, Discount Tire who put it on needs to get it the hell off when I have time to take it to them.
Old Jul 9, 2009 | 08:00 PM
  #482
civicdrivr's Avatar
I dont have any vibrations yet. We'll see. The car always acts up whenever I look at another car. Ive always had that sort of luck. I took a look at an 07 TL-S this past weekend, but found out it was an auto, so I walked away. I swear my car has feelings.
  #483
gnuts's Avatar
3.5 psi
Shitty news man, your new rims too!
I'm back and forth on this mod...to do it or not. I don't know much about car wiring.
Edit...666th post, weird. Omen?
Old Jul 9, 2009 | 08:44 PM
  #484
nf3d0149ab's Avatar
Shitty news on the wheel though...it sounds like your car felt that one too...
Old Jul 9, 2009 | 09:09 PM
  #485
civicdrivr's Avatar
Oooof.
I just realized Ive got over 2000. Wooohooo!
I just got the valve stem replaced on that wheel, so hopefully its the stem that leaking and not the wheel itself. The bend isnt horrible, but I notice it so it bothers me.
The shittiest part about the car is that Honda doesnt have any of the parts on hand. They should be in tomorrow, otherwise I have to wait until next week. Luckily Ive got the bike to ride around for work, but my shoulders and legs are killing me. I need a day off.
Old Jul 9, 2009 | 09:46 PM
  #486
e30cabrio's Avatar
Two missing bolts:
Catch Can is in
Old Jul 9, 2009 | 10:21 PM
  #487
civicdrivr's Avatar
I still need to get a real catch can. Im using the air compressor filter as a catch can. It works pretty well honestly.
And before anyone asks, its not the cause of my previous vacuum leaks. I tested it without it on.
Which reminds me, I put everything back to stock on the car, and three days later I got a P0505 CEL, Idle Control System. The IACV is brand f*cking new. Im now hearing another vacuum leak, and Im getting a surging idle when I hit the gas in neutral. So Im getting rid of the thermo-gaskets and going back to stock, and Im even replacing the gaskets on the lower intake manifold even though I didnt take them off. Something in that area is leaking, and Im determined to find it.
Old Jul 10, 2009 | 07:53 AM
  #488
CleanCL's Avatar
I wouldn't bother with the runner gaskets unless you unbolted them.
Check the plenum lid metal gasket. It can go on 2 ways, one of which will cause issues.
Old Jul 10, 2009 | 11:56 AM
  #489
civicdrivr's Avatar
Its not the lid. The leak is coming from underneath the manifold in the vacinity of the lower manifold. Later today Im going to play around with it and try to get everything running right. I heard this noise on both the TL and the stock manifold. It just took a day or two for it to become noticeable.
Old Jul 10, 2009 | 12:16 PM
  #490
ThegreatGATHby's Avatar
sounds like its time for some liquid gasket
Old Jul 10, 2009 | 08:59 PM
  #491
civicdrivr's Avatar
Blech. Im determined to find out what this issue is. Once I get of work of course
Its probably the simplest thing, but Im going to cover all my bases to be sure.
Old Jul 11, 2009 | 10:18 AM
  #492
typeR's Avatar
hey clean wonder if the MDX spacer will fit with the lower profile of this intake >?
Old Jul 13, 2009 | 02:58 PM
  #493
02type-s's Avatar
-Arsenic-
Good call, thats a great possibility
Old Jul 13, 2009 | 06:41 PM
  #494
CleanCL's Avatar
maybe? the spacer is 1.8" high. what's the height difference of the new manifold? the 3g TL guys got it to fit with minimal work. i'm kinda pissed, i had 2, and sold them both. now they are on backorder. after looking at it, i believe it would fit my 3.7L now, but oh well. i went a different route.
Old Jul 15, 2009 | 03:56 PM
  #495
ACURA`TL`TYPE-$'s Avatar
OMG you guys are sick major props.
I can't believe I just stumbled upon this thread. Iono i may have missed it but does this work for 02 tls or is just for tlp? and how much exacly it is for the manifold, cause from what i understand its just a plug in-play mod. so are there any other changes that i need to make for this?
Old Jul 15, 2009 | 04:03 PM
  #496
gnuts's Avatar
3.5 psi
tl-p? This is the CL side. Both guys have CL-S engines (J32A2). You have the same engine as them if you have a TL-S. All other info you asked is in the thread. Just read
Old Jul 15, 2009 | 05:33 PM
  #497
typeR's Avatar
btw i still think someone should do that RL exhaust mod ... specially someone with a hi flow cat think itll fix the low end torque loss
Old Jul 15, 2009 | 05:44 PM
  #498
Rajca's Avatar
wham bam thank you ma'am
rl exhaust? never heard of that
Old Jul 15, 2009 | 07:46 PM
  #499
them civic i feel ur pain. my luck is similar to urs. i just finished reading this thread, so still no DIY? and btw my tls is an auto (obviously I am not cool), so do i have to change everything that you did, besides the manifold and the oil catcher thingy, is ther anything else i need to change, like the throttle body?
i am sorry if the questions are stupid i am just a little confused
Old Jul 15, 2009 | 07:51 PM
  #500
e30cabrio's Avatar
My car is auto, it has been great for well over 2500 miles. You do not have to change anything but the manifold, all of these mods are optional & cumulative.
Old Jul 15, 2009 | 08:31 PM
  #501
typeR's Avatar
the rl is close to a true dual and theres a pipe just after the cat that is dual flow ... low rpm more resrictive hi rpm opens up its only like a 150 part just not sure what it would take for it to bolt up
Old Jul 15, 2009 | 10:23 PM
  #502
CleanCL's Avatar
Maybe... but they didn't carry the system over to the 3.7L exhaust. Maybe they did something different with the motor that made up for low end. I think the best kind of exhaust would be running dual pipes off the headers into an X-pipe.
civic - have you figured out the leak?
Old Jul 15, 2009 | 10:27 PM
  #503
nf3d0149ab's Avatar
Sounds interesting...
Old Jul 16, 2009 | 12:22 AM
  #504
civicdrivr's Avatar
Im making progress, albeit slowly.
I ran through the troubleshooting guidelines in the shop manual and there is no vacuum leak. It all lies in the IACV. If I block off the port the car will idle and rev perfectly. Its not the throttle body as Ive swapped it out with my old one, and its [probably] not the IACV itself as this is the second brand new one.
I had my old IACV that I bolted up it to the motor and plugged the new IACV into the harness just to see what its reaction was. The IACV didnt spin at all. There is a slight crack that is letting the air pass by. I am leaning towards something electrical, but I am not that good when it comes to wiring, but I did try. Ive checked for battery voltage in the #2 connection of the IACV plug and got it (12v). I checked for continuity on the #3 connection and got it. I went to the E plug on the ECU and ran both tests on the #23 pin and everything checked out. Id like to find a 6MT ecu locally that I can borrow for an hour or so to see if maybe thats it. I dont think my wiring is FUBAR'd. The last step in the manual is to substitue the ecu with a known working one, so thats what Id like to do.
Right now I disassembled my old IACV and plugged the motor/sensor into the harness and tucked it away. I locked the valve itself in the closed position and bolted it up. The car runs perfectly right now. I dont have a single issue, no CEL or surge. The only time the idle acts funny is when the car is stopped and the A/C is on (it drops about 50rpms). Other then that the car is perfectly fine.
I havent driven the car since last tuesday, and it felt great. I have been driving an 08 Accord 6MT around for the past week. That car is fast. Chirping the tires and seeing the TCS light go crazy during at 2-3 shift at 65mph is definately fun (I hadnt set the TCS off as it was an impromptu romping ). As fun as the Accord was though, I really missed my car. My car handles better and honestly sounds better (I hit the rev limiter once or twice because I cant hear the damn exhaust in the Accord, even with the windows open). IIRC the Accord has 3 cats, 2 resonators along with the 2 mufflers
Even though the Accord and CL weigh the same (3446lbs) my CL feels lighter. Mainly because of the suspension. I almost ran off the road in the CL today because the turn in was much sharper then the Accord
Hopefully I can actually fix the IACV issue and not leave my ghetto rigged solution in there for much longer.
Old Jul 16, 2009 | 07:51 AM
  #505
e30cabrio's Avatar
Glad you are making progress.
As far as loss of torque I don't see it. My car is quicker in all ranges and has mush more low end than before. Maybe it is my catback 2.5 exhaust & Magnaflows?
Old Jul 16, 2009 | 02:30 PM
  #506
civicdrivr's Avatar
Yea, now that the car is running as close to perfect as possible right now the manifold swap seems more and more worth it. I did a 1st and 2nd pull this morning and the car feels just as fast as the Accord now. The ECU is still learning all the parameters again (I reset it yesturday). I cant wait to get my full exhaust done and possibly new headers. I just need to see dyno numbers for the headers before I commit. I may get the car dyno'd tomorrow to see what the gains were. My ass says its in the 10-15whp range.
Old Jul 16, 2009 | 03:41 PM
  #507
gnuts's Avatar
3.5 psi
Glad to hear man. Now you can post your DIY
Old Jul 16, 2009 | 09:49 PM
  #508
civicdrivr's Avatar
Once I get the after dyno everything will be up. It really is a straight foward install, but Ill post pointers and everything. I just have to go through my pics and figure out what I want to use.
Old Jul 17, 2009 | 04:12 AM
  #509
woot woot civicdricr
waiting for dyno.
Old Jul 18, 2009 | 11:02 PM
  #510
gfrg88's Avatar
slow tl..
where are the dyno numbers at?????
Old Jul 19, 2009 | 11:58 AM
  #511
civicdrivr's Avatar
They didnt have any time avail for me to get after numbers. Id go to a different shop but I want to keep the variables as low as possible for accuracies sake. Graphs will be posted by next saturday for sure.
Old Jul 19, 2009 | 12:22 PM
  #512
e30cabrio's Avatar
So the 09 manifold is on and all is well?
Lets see your motor!
Old Jul 19, 2009 | 02:10 PM
  #513
civicdrivr's Avatar
Its on and no codes or idle issues. I still have the IACV blocked off without any problems. The car is faster then it was the first time I put it on.
I raced my brothers 08 Accord 6MT last night on the highway. It was an impromtu race and he started it. I dont know what gear he was in for sure, but the way he took off it looked like he was in 4th. I dropped it to 4th as well doing about 70mph (he had to be doing 80-85 by this time), and I caught him when I hit 5th doing about 120-125. He said he was doing about 115 when I passed him.
Its like a whole new car. I too feel like I gained some TQ down low. Its a bit more jumpy. Im going to start looking around at aftermarket TB makers to see if anyone makes something that will bolt up. Im looking for an 80mm TB. The ported one I have is 70mm at the inlet and 67 at the outlet. It doesnt exactly take advantage of the manifold bore. We'll see what I find.
My car is begging for an exhaust. My 2.5" cat should be in sometime this week and I will be ordering the piping soon. Im shooting for 250whp at this stage. Hopefully that can hold me over until spring.
Old Jul 19, 2009 | 04:05 PM
  #514
Rajca's Avatar
u can never have enough horsepower
Old Jul 19, 2009 | 04:15 PM
  #515
civicdrivr's Avatar
I used to dissagree with that sentiment, but its 100% true
I have an idea as to what my next step is with the motor. I just need to figure out what method I want to use. I wont stop till I reach the goal that I have set though.
Old Jul 19, 2009 | 04:19 PM
  #516
Rajca's Avatar
goal with FI or NA? and i wont stop either, i will beat my goal and go above it. P&P next? if u havent done it yet?
Old Jul 19, 2009 | 04:22 PM
  #517
civicdrivr's Avatar
MOAR! Stay tuned. Im not letting anything out of the bag yet
Old Jul 19, 2009 | 06:01 PM
  #518
gfrg88's Avatar
slow tl..
Damn, I am very interested in this!! So what would a base TL/CL need since it's not a type s??
Old Jul 19, 2009 | 11:02 PM
  #519
civicdrivr's Avatar
Not sure if it bolts up. If it bolts up it should be damn near identicle. Your car doesnt have IABs does it?
Old Jul 19, 2009 | 11:08 PM
  #520
Pinho's Avatar
as for TB check out Wilson or JG ,Skunk 2..the list can go on..but i only use Wilson...i will be running a 90mm for sure and maybe 105mm depending on how the head flows when i do some porting....as for the exhaust i would hope u would consider going 3"...i had a 2.5" and when i went 3" i gained 9whp...
