J32A2 blew up; swapped in a new motor
Old 05-28-2022, 02:17 PM
  #241
619rcr's Avatar
Originally Posted by zeta
Just curious, Thefireball, since you swapped the Type-S cams, from your partially disassembled J32A2 heads, is it possible for you to post a picture(s) of the actual J32A2 lost motion assembly ([color=#333333]14820-ZY3-405)?
I'm just wondering if the latest (14820-P8F-A01) LMA's, pictured above, are a further improvement since the design changed and this is what Acura is currently selling should one need replacements?
Hey Zeta, the newer lmas are improved design. The ones on my cls6 motor were the bullet style top with a small spring on the underside. I know some of the older h series had oil pressurized Lmas, which switched to the coil type in 99. The old design tends to wear out and not hold pressure at idle, so the valvetrain gets noisy. The 1st j series im not sure if they were oil pressurized. But, i can tell you that the new one's are basically just a coil spring with a flat top, no oil pressure. This is what my RL parts motor had so that is what i am using on my build. here's a quick pic of my head without the rockers. you can see the 3 lma coils on the intake side.
other pics are of the j32a2 orig ones. they do have a small orifice at the base
Attached Thumbnails J32A2 blew up; swapped in a new motor-20220528_122226.jpg   J32A2 blew up; swapped in a new motor-20220528_123454.jpg   J32A2 blew up; swapped in a new motor-20220528_123440.jpg
The following 2 users liked this post by 619rcr:
Thefireball (05-28-2022), zeta (05-28-2022)
Old 05-28-2022, 04:24 PM
  #242
I am dumb
Thefireball's Avatar
What they said.
I'm running the newer style LMAs.
I can take a pic next week. Getting the valve cover off doesn't take long.
zeta (05-30-2022)
Old 05-28-2022, 04:32 PM
  #243
Received 1,831 Likes on 1,474 Posts
Thanks 619rcr for that information & the pictures!
When I zoom in on the RL LMA's, as you stated, one can see the spring.
They look a lot more heartier then the older LMA version.
Old 05-28-2022, 08:48 PM
  #244
619rcr's Avatar
definitely. i don't wanna thread jack, so I'll bow out now. later guys.
Old 05-30-2022, 07:54 PM
  #245
Thefireball, in addition, while you are there, can you measure a J32A2 intake valve with that nice digital caliper you have?
619rcr provided the picture below, in another thread, and I was just wondering what the official dial caliper result would be.
pretty damn close to me, i think i remember someone saying 35.5 rounded to 36
Old 06-06-2022, 01:13 PM
  #246
I am dumb
Measured two different J35A3 intake valves; similar results.
1.376 inches, or 34.9504
Also, I'm too lazy to pull out my LMAs.
zeta (06-06-2022)
Old 06-06-2022, 02:01 PM
  #247
Thanks, great pictures BTW.
So the pictured J32A2 intake valve is 35.76mm?
Check out this guys 2001 CL-S 6MT swapped K20A in Japan.
I bought strange 2001 CL TypeS 6MT - AcuraZine - Acura Enthusiast Community
Old 06-06-2022, 02:21 PM
  #248
I am dumb
No, those two pics are 2 different J35A3 intake valves. Not J32.
And wow. There's so much room in the CL with that K20 in it. How did they get a CL in Japan though, and why? I like it, but I prefer the J over the 4 bangers. Been looking at getting this really beat up RSX base model. $750 for it, but it needs a lot of work. If I get it, then I'll be in the RSX section of these forums as well, lol.
Old 06-06-2022, 02:35 PM
  #249
Ok, help me out.
Your provided pictures are of J35A3 intake valves.
I'm seeing 35.76mm in the first photo?
Old 06-06-2022, 02:43 PM
  #250
I am dumb
Ok, help me out.
The dial reads in inches.
Old 06-06-2022, 03:04 PM
  #251
6 in. Dial Caliper (harborfreight.com)
Is 'nt the upper scale (first picture 'red') millimeters?
Old 06-06-2022, 03:15 PM
  #252
I am dumb
Yup. Top is mm, bottom is inches, dial is inches.
I can bust out my micrometers if you want as well, get a better reading.
Old 06-06-2022, 03:21 PM
  #253
Yeah, please try that.
If possible, measure a J32A2 intake valve so we can observe the difference from the J35A3 intake valve above.
Old 06-06-2022, 03:37 PM
  #254
I am dumb
If only I had a J32A2 head & valves. If that CL-S is still at the yard, I might go pull the heads off.
I'll do the micrometers later tonight. I gotta finish fixing my passenger seat and head to work.
Old 07-12-2022, 12:14 AM
  #255
I am dumb
So a bit of an update pertaining to the J35A3 swap itself. When I was originally putting the car back together, I had a lot of trouble with a part upon installation. The serpentine belt.
It was incredibly difficult to put back on, and I had required help from my girl. I pulled the tensioner back with all my strength, while she used a pry bar to get it on. Even then, half of the belt was still stuck around the edge of the crank pulley. After it was fully on, the tensioner barely went down, because the belt was already so tight.
I've been driving the car around with it like this, which is obviously bad for the crank bearings inside. But it's held up, aside from the squeezing from the crank pulley.
I went down to the autoparts store to do an oil change, and to see if there was a difference in parts numbers for the belt between the J32 & J35. Turns out, they are different, with the J35 belt being slightly larger. I tried showing the difference by pulling on both belts side by side with it held on to something.
The difference in length isn't massive, but it was a world of difference with installation. It slipped right over the pulleys with some slack left over, and the tensioner went down, ridding of the slack. So if you're doing the J35A3 swap, make sure to swap over the belts as well. The squeek has gone away, and I was hoping this might fix my rough idle with the AC on, but alas, it did not. Maybe the bearing for the AC pulley is just going out, who knows. But the car absolutely HATES the AC being on. Well, that is until it warms up, then it's fine.
The idle on a cold start actually has a classic V8 style chop to it when the AC is on. Not a huge drop in RPMs, but you can feel it pulling forward out of the drive way every time it goes up.
In addition to doing all this, that being the oil change & filter, and the belt, I also took the time to enlarge the holes for the IACV ports.
You can see the before & after, as well as the size increase on the caliper. I didn't notice much of a difference in idle, but maybe it'll show when I'm actually driving the car; we'll see I suppose.
And, last but not least, where would I be if I weren't fixing an issue and another one arises. 'Arises' is an understatement, because the coolant hose that goes from the top of the radiator to the the coolant passages has ballooned up.
I took the pictures after finishing everything, so the car has cooled off by then. But the ballooning was much, much larger before. I wrapped it in a bunch of aluminum tape to help prevent it from busting, just as a temporary fix. I'll be going down to the auto parts store to fix it ASAP. Hopefully they have the part. TL's tags are expired, so I sure hope they have the part. Guess it's time to renew them; there goes part of the 6 speed swap money. (Which will be soon™)
Old 07-12-2022, 06:29 AM
  #256
Interesting.
CL-S/TL-S; (Mitsuboshi); 38920-P8C-A02; 22.0 x 5.0 x 0.8 inches
MDX; (Mitsuboshi); 38920-P8F-A02; 22.2 x 6.3 x 1.0 inches
MDX; 38920-P8F-306; 17.4 x 4.8 x 0.8 inches
Thefireball (07-12-2022)
Old 09-06-2022, 09:40 PM
  #257
Picture of my CL-S6 manual trans barcode shows 'C6' versus 'MC6'
This looks like Accord V6 manual trans.
The CL-S6 shift lever should be at the far end (red):
Therefore, he's either untruthful or just does not know wtf he's got.
Thefireball (09-06-2022)
Old 09-06-2022, 10:31 PM
  #258
I am dumb
I originally asked them if it came out of an Acura CL and they said yes. I just messaged them asking them what car it came out of, and they said a TL Type S, and then eventually they said a 2007 Acura TL Type S.
I think you're correct on your second remark. I told them that they should at least clarify that in their post.
The hunt for a transmission continues..
Old 09-07-2022, 06:08 AM
  #259
I can't think of any easier way to visually identify; therefore, If you come across another 'prospective' advertised CL-S6 trans., the easiest way to verify before purchase is to ask for a picture of the 'shift arm' and the trans mounted crank sensor.
CL-S6; 24470-PYZ-000
TL; 24470-RAT-000
TL; 24470-RDE-000
Accord; 24740-RAT-000
Good Luck!
Thefireball (09-07-2022)
Old 09-07-2022, 08:27 AM
  #260
619rcr's Avatar
@Thefireball the guy I purchased the used cls gear set from is selling the bare clutch case and transmission case. The clutch case is still sold new, but its pricey. The shift arm itself is discontinued. but as Zeta pointed out elsewhere can be modified to add a second peg...
cls clutch case
cls trans case
Old 09-07-2022, 12:44 PM
  #261
I am dumb
cls clutch case
cls trans case
What would I do with just the clutch case though?
Old 09-07-2022, 02:16 PM
  #262
619rcr's Avatar
use it with another non cls j series trans that you can pickup from the junkyards. the clutch case and the rear mounted sensor are unique to the cls6. the gears and trans case are not.
just a suggestion. easier than looking for unicorns.
Old 09-07-2022, 03:16 PM
  #263
I am dumb
Isn't there a sensor that mounts onto the bell housing casing as well?
Old 09-07-2022, 04:25 PM
  #264
The crank sensor 'sheath' is there & you can use something like
this one:
37500-PNB-003 Genuine Acura Crank Sensor Assembly (acurapartswarehouse.com)
Per this thread:
Part no longer available!!! - AcuraZine - Acura Enthusiast Community
619rcr (09-07-2022)
Old 09-07-2022, 04:31 PM
  #265
619rcr's Avatar
The bellhousing is aka clutch case
The part number for trans case is discontinued. idk what makes it unique. maybe just that the newer ones used different mounting. Anyways both halves are for sale from same guy. I thought about getting the clutch case myself for a spare.
Old 09-07-2022, 04:32 PM
  #266
619rcr's Avatar
+1, I used a off the shelf generic RSX sensor went mine started acting up.
pakn-heat
04-23-2013 10:00 PM
bgsrmyth
08-15-2010 11:21 PM
crx_91si
11-24-2009 08:34 AM
Pure Adrenaline
04-20-2005 03:27 PM
Quick Reply: J32A2 blew up; swapped in a new motor
