K23a1 Build
Old 08-13-2014, 08:38 AM
  #481
KenB350z's Avatar
According to my tracking number the turbo will arrive at Evergreen on thursday. I wanted to go and get a re-tune with the water/meth, but I think I'll wait and see what Evergreen says on thursday and see how long it will take them. My second dyno tune will be filmed also, it's going to be the BIG ONE! I would have made "over 300 with the water/meth" Alex mentioned. I'm kicking myself for not using it. He could have advanced more and added boost with the 100+ octane. Oh well, I'm sure I'll make over 300 with the upgraded turbo and water/meth next dyno.
Old 08-13-2014, 08:55 AM
  #482
KenB350z's Avatar
It's time to get nasty!
Old 08-13-2014, 09:27 AM
  #483
FLETCH
TheWrench116's Avatar
whats the difference between them the ratio of water to meth? and $
Old 08-13-2014, 10:16 AM
  #484
KenB350z's Avatar
1 gallon Boost Juice each $8.91- 50/50. I have 4 bottles of this stuff, so I have to use them up first.
1 gallon SuperTech $3.50-$4- 70/30. Then I'll go to superTech, it's cheaper and does the same thing.
They both will put you over the 100 octane mark.
TheWrench116 (08-13-2014)
Old 08-13-2014, 12:03 PM
  #485
FLETCH
I want to put my water\meth nozzle in the end tank of my ets intercooler but I cant find a decent adapter to go from the nozzle to the supply hose and I want to keep everything short and as hidden as possible. and I might be re-welding the mounting tabs on the ets intercooler cause they don't line up for shit on my setup never did from day one.
Old 08-13-2014, 03:24 PM
  #486
not an SUV ...a Big Hatch
BigHatch's Avatar
...washer fluid??? aint that somewhat soapy?
Old 08-13-2014, 03:31 PM
  #487
KenB350z's Avatar
Haven't seen any soapy washer fluid. Bad nozzle can make it appear that way. Autozone stuff is good also. $2.29
Old 08-13-2014, 04:40 PM
  #488
dresx's Avatar
Why'd you opt not to do e85? I hear it's like race fuel at the pump.
What happens if you run out of water/meth on the road?
Old 08-13-2014, 05:07 PM
  #489
FLETCH
E85 isn't as dense as good old 93 octane and they are both down compared to number 2 diesel. yes it is a higher octane fuel but you would go 1/3 the distance. and while 800cc is overkill for 93 octane it might be marginal because of the quantity of fuel needed per injection event (read it might max his duty cycle). he might need to go to 1000cc or bigger... water meth is a better solution.
Old 08-13-2014, 05:09 PM
  #490
KenB350z's Avatar
E85 I think burns way to fast, and the kit come with a low fluid indicator. With the nozzle spraying at only 10 microns, I think I can get a lot of milage off one gallon. It doesn't spray all the time, just at your desired boost. My low will be around 11psi with a max of whatever psi we go up to on my next tune.
Old 08-13-2014, 09:02 PM
  #491
Slow98teg's Avatar
Meth is better for someone who can't or doesn't want to spend the extra coin on e85 components. Proper sized injector, fuel pump and fuel lines if necessary. As long as you have the proper safety switches for the meth kit you'll be fine.
And yes regular washer fluid works very well.
Old 08-13-2014, 09:37 PM
  #492
KenB350z's Avatar
Got bored while changing the oil.
SinCity (08-14-2014)
Old 08-14-2014, 04:40 PM
  #493
KenB350z's Avatar
The TiAL blow off valve is looking good with that old school Greddy Type-S purple, it really pops!
Old 08-14-2014, 07:59 PM
  #494
deschnes2006's Avatar
WOWW!! Nice setup!!
KenB350z (08-14-2014)
Old 08-15-2014, 02:25 AM
  #495
KenB350z's Avatar
Oh, I have my pump and 1 gallon tank mounted on the driver side front bumper. You can just drill in the end tank of the intercooler by the throttle body and use a tap and die set to get your 1/8 thread and be done. I wouldn't run the water/meth until you get it tuned. I have my install, just not using it yet. Ran it before, but it made setup run rich!
TheWrench116 (08-15-2014)
Old 08-15-2014, 08:46 AM
  #496
exist12's Avatar
What size outlet is on the bov? What psi spring did you order for it?
Old 08-15-2014, 11:23 AM
  #497
BigHatch's Avatar
..yeah I guess that would be bad..hahaha
Old 08-15-2014, 07:32 PM
  #498
KenB350z's Avatar
50mm 11psi spring.
Old 08-16-2014, 05:05 AM
  #499
KenB350z's Avatar
I just order a 9 and 7psi spring, I'm getting a little flutter dump at low boost low rpm. At high boost high rpm no problem.
Old 08-21-2014, 08:41 PM
  #500
thisaznboi88's Avatar
ugh... your suppose to get the -20 not +32. +32 has glycol in it. You know the stuff in coolant. just and FYI it turns everything in your intake tract blue.
Old 08-21-2014, 09:33 PM
  #501
bshotts's Avatar
I'm pretty sure I am getting better gas mileage. It doesn't boost as much while driving or climbing hills. This is a slight climb at 80mph. The boost never goes above the first level of the boost (as you can see the three levels here). But, pulls like hell when it goes over it!!! Love this smooth tune!!
I was hoping improved fuel economy was an added benefit by allowing the engine to breathe better and optimizing fueling/timing/boost. I'm really curious (as are others I'm sure) to see even more off-boost fuel economy benefit by your planned turbo upgrade. I'm thinking the compressor wheel size increase and turbine wheel clipping will effectively be the same as using a larger turbo therefore allowing the engine to stay out of boost more often. It's nearly impossible to keep the stock turbo and factory tune out of boost even at the hint of throttle tip-in/increased engine load.
Thanks for being a pioneer in this endeavour...I can see many an RDX benefiting from what you learn and share.
One question Ken...is it possible to control boost with the FlashPro setup?
Old 08-22-2014, 01:15 AM
  #502
KenB350z's Avatar
It's ok, I'm sticking to and will be tuned on "boost juice".
Old 08-22-2014, 02:01 AM
  #503
KenB350z's Avatar
Hey bshotts, thanks for the kind words.
I will have to get a mpg meter so I can get a true mpg reading for the community. I hope to get even better mpg with the upgraded turbo.
You're right about the boost issues we have while normal driving without having a lead foot. Before I could never stay out of boost even if I tried. Now, it's seems if the engine is doing most of the work until you want the beast to come out; which shouldn't be that often unless you want people to look at you crazy because your "RDX SUV" just went 60-100mph in just sec.
I'm sure it is possible to adjust the boost with the flashpro, but it is recommended not to touch the boost. My tuner and the guys at EverGreen suggest to try and get the most out the motor and turbo without increasing the boost. Evergreen "HIGHLY RECOMMENDS" that you not increase the boost over 16lbs. They said their rebuild & upgraded turbos are built for OEM longevity, maximum airflow, and not for over boosting. You will gain enough power with the upgrade, it doesn't need to be over boosted. I Can't wait to get it back from EverGreen. I will post an update ASAP when I do. Stay tuned!
BigHatch (08-22-2014)
Old 08-23-2014, 01:18 AM
  #504
420Coupe's Avatar
boost control is controllable through FP
Old 08-25-2014, 12:44 PM
  #505
FLETCH
yeah it is but its kind of hard to figure out what your telling it to run and what it is actually running cause the apple app doesn't read boost. and I'm not data logging my daily commute.
Old 08-29-2014, 09:35 PM
  #506
KenB350z's Avatar
YEp!
Old 09-02-2014, 04:52 PM
  #507
FLETCH
so did you get the turbo on it yet??? so cant wait to see some serious numbers out of this build!!!
Old 09-02-2014, 07:57 PM
  #508
KenB350z's Avatar
Still in route from FedEx.
Old 09-08-2014, 07:15 PM
  #509
dresx's Avatar
Annnndddd thhheeennnnn....
Old 09-08-2014, 08:24 PM
  #510
richard cranium
crxtype-r's Avatar
Smile
hey ken what's the news? how goes it with the build.
Old 09-08-2014, 08:43 PM
  #511
KenB350z's Avatar
Turbo is in, just order gasket and stuff. Shouldn't be long for the final tune.
Old 09-25-2014, 05:06 PM
  #512
andrewbenjack's Avatar
So does the driveshaft fit the rdx?
Old 09-25-2014, 09:26 PM
  #513
KenB350z's Avatar
It was never test fitted. I don't think it necessary, because our Driveshaft is super light.
andrewbenjack (10-02-2014)
Old 01-20-2015, 01:07 PM
  #514
Nachtsturm's Avatar
I enjoyed this build, what is the current state?
Really wish the pictures were still hosted.
Old 01-20-2015, 04:38 PM
  #515
KenB350z's Avatar
Everything is good, just waiting on my Driveshaft and suspension to get back.
Old 01-24-2015, 08:06 AM
  #516
kraz3RdX's Avatar
YO, hit me up i have a few questions for ya
Old 01-24-2015, 08:37 AM
  #517
kraz3RdX's Avatar
Im upgrading the turbo, going with a .62.66 precision turbo or maybe a 60-1... i already have a full single 3in downpipe and exhust Vibrant. Waiting for flashpro to fo intercooler, piping, RBC, zdx TB, manifold and change turbo with external wastegate and tune on e85... looking for 400hp+
Old 01-24-2015, 08:38 AM
  #518
kraz3RdX's Avatar
txt me 954-864-4706
Old 01-24-2015, 11:20 AM
  #519
KenB350z's Avatar
Ok
Old 01-24-2015, 11:28 AM
  #520
KenB350z's Avatar
Did you find a turbo manifold?
Quick Reply: K23a1 Build
