'07 RDX key wont turn ...
That turbo though.....
Hey guys,
I just replaced my starter and went in to turn it over and the ignition wont turn over (the key chime does chime), go to on, or accy.... not sure if I may have popped a fuse or what? The key inserts all the way but I can't turn it at all. I did of course make sure the steering wheel didn't lock and no dice... any suggestions before I have it towed to Acura service?
move your steering wheel back and forth as you try to turn the key.
as you turn it back and forth and turn the key, it will unlock.
Basically, turn your wheel in whatever direction has a bit of slack while also turning the key. If there is any tension in the steering wheel when locked, it may be difficult to turn the key.
I have tried moving the wheel slowly back and forth and still no luck. Luckily I have free towing so I hope to bring it to Acura for them to point out I'm an idiot, and not a 500$ fix.
Hey guys, so I want to thank you all for chiming in on this. I took it to Acura and it turns out I needed a new key! They believe the chip inside the actual key may have been damaged. So luckily $200 later and I'm driving home happily.
MaxPower777
1G RDX Problems & Fixes
03-26-2019 12:32 AM
