'07 RDX key wont turn ...
Old 09-17-2019, 06:16 PM
That turbo though.....
TailoredTL-S's Avatar
Hey guys,
I just replaced my starter and went in to turn it over and the ignition wont turn over (the key chime does chime), go to on, or accy.... not sure if I may have popped a fuse or what? The key inserts all the way but I can't turn it at all. I did of course make sure the steering wheel didn't lock and no dice... any suggestions before I have it towed to Acura service?
Old 09-17-2019, 07:25 PM
Received 8,621 Likes on 6,659 Posts
move your steering wheel back and forth as you try to turn the key.
Old 09-18-2019, 04:46 PM
I have tried that, however my steering wheel is locked... is it possible I need a new key cut? I'm running out of ideas...
Old 09-18-2019, 04:54 PM
as you turn it back and forth and turn the key, it will unlock.
Old 09-18-2019, 07:36 PM
Tomtwtwtw's Avatar
Basically, turn your wheel in whatever direction has a bit of slack while also turning the key. If there is any tension in the steering wheel when locked, it may be difficult to turn the key.
Old 09-19-2019, 07:16 AM
I have tried moving the wheel slowly back and forth and still no luck. Luckily I have free towing so I hope to bring it to Acura for them to point out I'm an idiot, and not a 500$ fix.
Old 09-19-2019, 12:24 PM
Tomtwtwtw's Avatar
I'd be rooting for idiot in that situation as well. Good luck!
Old 09-30-2019, 03:03 PM
Hey guys, so I want to thank you all for chiming in on this. I took it to Acura and it turns out I needed a new key! They believe the chip inside the actual key may have been damaged. So luckily $200 later and I'm driving home happily.
MaxPower777
1G RDX Problems & Fixes
03-26-2019 12:32 AM
bobfriday
1G TL Problems & Fixes
01-12-2017 05:33 PM
greco9885
02-22-2009 06:29 PM
bubinga2
08-09-2007 08:41 AM
ronrobert
04-09-2004 07:58 PM
Quick Reply: '07 RDX key wont turn ...
