AcuraZine Dallas/Ft.Worth Crew
Old 07-08-2012, 10:34 AM
  #7761
Silver Bullet's Avatar
Originally Posted by Silver Bullet
Rotors and pads are in. Install on Friday.
Only had one major-ish issue with the rotors swap. My pax side front brembo had a strip bolt from when I had my local brake shop swap my last rotors out. I had to use a breaker bar to get the bolt out and then when I put it back I wasn't able to get it to torque down. It screws in completely but spins at the end. It's not coming out or going to wiggle any but eventually I need to go get a replacement bolt and hope that works first, otherwise I either will have to have it re-threaded or even replaced. I got time to figure that out.
What amazed me was the fact that the 2 production line screws came off the front with just a screw driver and bare hand grip. The rear rotors screws I had to drill out since they were OEM rotors and had rusted in.
I'm loving the cross drilled slotted look and they seem to perform well.
Old 07-08-2012, 10:58 AM
  #7762
Coins's Avatar
Take it to any quick lube place to have it done. Some of the basic work like fluid changes don't need a dealership to have done. If you don't DIY then do Kwik Kar for fluids.
Appreciate it man. Will get it done once I order the fluid then!
Still have yet to see your tl around Rowlett haha
Old 07-08-2012, 11:03 AM
  #7763
I'm always driving in or out of rowlett via rowlett rd or centervile towards firewheel. You'll know my car when you see it and hear it.
Old 07-08-2012, 11:26 AM
  #7764
Coins's Avatar
I am always driving around that area as well haha.
Right now 06 WDP TL is stock. Under my front bumper on the right side is bruised up from the previous owner running over a curb I guess. Not too noticeable, but its there.
Hopefully within the next few days I'll order my aspec kit which I have delayed for ever.
Old 07-08-2012, 11:38 AM
  #7765
TrojanTSX's Avatar
I always take the rotor screws out and leave them out. They are only there for when the car is being built on the production line.
Old 07-08-2012, 12:34 PM
  #7766
Majofo's Avatar
Received 11,841 Likes on 8,573 Posts
Originally Posted by NAiL05
questionable at that...I have gotten cars from those places at the dealership and refuse to take my vehicle there...I still dont understand how you can fuck up putting in a cartridge filter on a lexus instead they just jam it in there and let it go.
So you're telling me you're cruising around with a bolt hanging in a stripped thread. I guess you're unfamiliar with the guy whose caliper did the hamster tumble in his wheel, losing all braking power to that axle and almost crashing while his baby sister was riding shotgun. You should helicoil it before you drive another mile.
https://acurazine.com/forums/3g-tl-2004-2008-93/near-death-experience-complete-brake-failure-740740/
Old 07-08-2012, 01:05 PM
  #7767
https://acurazine.com/forums/showthread.php?t=740740
It took a breaker bar to screw it in, it's in there and not coming out. it seated against the bracket just not able to torque it. It's not coming out and it's not loose on the bracket. It's the lower bolt. The upper bolt is in fine and torqued to 125lbf-ft. I plan to take care of it in a matter of days but thanks for the warning.
That dude in the link had both bolts come out and not really sure but i think he did the work and didn't torque the screws right.
Old 07-08-2012, 01:32 PM
  #7768
Majofo's Avatar
There's still a chance that lower bolt could come loose depending on how much thread unzipped but definitely get it fixed sooner than later.
Elegant probably hand tightened his bolts..
Old 07-08-2012, 02:17 PM
  #7769
Regions Leader
trancemission's Avatar
The worst you'd have to do is replace the knuckle right?
Old 07-08-2012, 03:44 PM
  #7770
The bolt screws into the caliper through the knuckle. I'm hoping I can just replace the screw first and see if that works otherwise the suggestion of re-threading will be the second option.
Old 07-08-2012, 05:11 PM
  #7771
Majofo's Avatar
You shouldn't have to replace the knuckle. It's a common problem. A helicoil should be good enough. I'm wondering if you have enough space to do it with the rotor on.
Old 07-08-2012, 05:27 PM
  #7772
NAiL05's Avatar
Caliper screw is this what we are talking about? Well you can try to chase the threads with a Tap and see if that helps clean it up. If not you can helicoil but I would recommend a new knuckle. Not too sure how well helicoils stand heat transfer. Use them on oil pans if we get hack jobs back from the quick lubes. They seem to hold up but on something as critical as that I wouldnt trust it. Try running the proper tap through it first and see if it cleans up.
Old 07-08-2012, 05:33 PM
  #7773
Majofo's Avatar
I think we're discussing the caliper bolt to the knuckle.
Like this (not TL):
Usually the thread of the knuckle gets stripped.
AcuraZine Dallas/Ft.Worth Crew-f2tg3.jpg
Old 07-09-2012, 02:29 PM
  #7774
Like this (not TL):
I'm not sure what brake caliper that is but it's not the Brembo caliper (I have the 6MT). On the Brembo caliper the screw goes though the knuckle first and then screws into the back of the caliper so the threads are in the caliper.
I'm going to get 2 more bolts and just try using the first bolt to see if it will thread through and seat itself so I can torque it down. If that doesn't work then I'll have to find someone that has the tool that I can re-thread it. I'm also going to check into the cost of a replacement caliper. It might just be easier to replace the damn thing and while I'm at it just replace both calipers. What the heck! LOL
Old 07-09-2012, 02:52 PM
  #7775
Majofo's Avatar
Oh, it threads to the caliper.. even better.
I had to search to verify and found this gem:
https://acurazine.com/forums/3g-tl-problems-fixes-114/help-stripped-bolt-thread-brembo-caliper-849759/
Helicoil or 6 pot BBK..
Old 07-09-2012, 03:29 PM
  #7776
https://acurazine.com/forums/showthread.php?t=849759
Yep...great find on that thread! that's exactly the same issue with mine. Hmmm...rebuilt $145...hmmm...I'll try getting a new bolt and see if that works for now.
Who has a heli-coil kit?
Old 07-09-2012, 04:05 PM
  #7777
Rick_TL-S's Avatar
Received 1,208 Likes on 692 Posts
From the CCM thread.
Originally Posted by Rick_TL-S
We have 12 spots set aside for us. However, we will all need to arrive just before 3PM, possibly around 2:30 after seeing how fast people try to arrive early.
So, if E's offer is still open, we can meet at his location & all go from there.
Old 07-09-2012, 04:20 PM
  #7778
Majofo's Avatar
Amazon, harbor freight, possibly Autozone or Advance as well. Should come with a bit.. get a locking coil.
Old 07-09-2012, 07:34 PM
  #7779
Nail, you got any of these tools available? the screw is a 14 x 1.5 mm, 170 N.m. That's from section 19-19 of the manual.
Old 07-09-2012, 11:20 PM
  #7780
NAiL05's Avatar
I can borrow one if I do not have one laying around. It will be a while since I am going to IL this weekend
Old 07-10-2012, 09:09 AM
  #7781
After this week is cool. I'm going to see if I can get 2 of the bolts in the mean time and test one of the bolts out first.
I'll ping you next week. Janet is going out of town next week so I'll be bacheloring it for 8 days and might just take a few days off myself. I'll have plenty of free time to work on this then.
Old 07-10-2012, 10:50 AM
  #7782
Regions Leader
How in the hell do you strip a caliper bolt?
I always put a dab of anti seize on mine.
Old 07-10-2012, 01:02 PM
  #7783
Good question! Mine was not done by me. I called DMD to order a couple more bolts and they said that stripping it is a common problem. I guess if you use a powered wrench you could not seat it correctly and and just force it in.
My stripped bolt was torqued on tight when I went to remove it but of all the bolts it required I use the breaker bar to completely unbolt it. So the damage was done when they bolted it down and they never knew it (maybe).
Old 07-10-2012, 04:37 PM
  #7784
Regions Leader
yeah, damage was definitely done when they put it on.....they knew it too.
Old 07-11-2012, 02:23 PM
  #7785
TrojanTSX's Avatar
Just found out my old Integra Type R maybe in Plano. VIN ends in 1938 if anyone knows who owns it.
Old 07-11-2012, 02:35 PM
  #7786
Giant Blue Car
Catfisha's Avatar
AWWW!!! How did you find out that it's around there? Was it your first car? I wish I could find mine, but I don't want to think of where it....or its remains may be.
Old 07-11-2012, 03:22 PM
  #7787
TrojanTSX's Avatar
Not my first, but one of my favorites.
I used checkmyride.com It locates the last known registered listing of the VIN.
Old 07-11-2012, 03:30 PM
  #7788
Giant Blue Car
Catfisha's Avatar
Oh COOL! I'll find the VIN's for my previous two cars and see where they may be....
Old 07-12-2012, 11:32 AM
  #7789
Q('.')=O
imj0257's Avatar
Thought I'd post this here because some of you might be interested:
$99 - Drive a Lamborghini at Texas Motor Speedway, Reg. $349
http://www.travelzoo.com/local-deals...69_html_dallas
You have to have autocross track insurance. Anyone know how much it is and how to purchase it?
Old 07-12-2012, 12:15 PM
  #7790
TrojanTSX's Avatar
Im doing this on the 28th thru Groupon. i paid 99 for the Ferrari and 99 for the insurance. Min insurance is 49 but only covers 50K and has a 5K deductible. The 99 insurance covers the entire car and only has a 1K deductible. bought every thing thru the website.
Old 07-12-2012, 05:11 PM
  #7791
Rick_TL-S's Avatar
3 laps? Doesn't seem like you really get a whole lot for the regular price.
Old 07-13-2012, 02:00 PM
  #7792
TrojanTSX's Avatar
Agreed! No way would I pay full price on this one. I wouldn't even pay full price on the 1hr drive I did awhile back.
Thank God for Groupon!
Old 07-13-2012, 02:03 PM
  #7793
TrojanTSX's Avatar
Finally got my wife's car back from the body shop!! Took a little over a month to fix all the hail damage. Now mine is in, hopefully it will not take as long!
Old 07-15-2012, 12:12 AM
  #7794
All Around Klown
EvilJoker's Avatar
'06 WDP in Mesquite... wouldnt mind meeting up with some of you guys... there is a ton of stuff I dont know about these cars...
Old 07-16-2012, 12:12 AM
  #7795
NAiL05's Avatar
We should do a group car wash before CCM or something haha.
Old 07-16-2012, 10:58 AM
  #7796
Giant Blue Car
Catfisha's Avatar
We'd be fighting over the hose! LOL
Old 07-17-2012, 10:41 AM
  #7797
Q('.')=O
imj0257's Avatar
Originally Posted by Tannn
Got two of my Ron Jon Legends stolen off my car two nights ago here in Fort Worth, please keep an eye out for them if you could.
What's missing: (2) Ron Jon Legend 19x8 +32mm wrapped in Falken 245/35ZR19
Been doing some browsing and stumbled upon this.
http://dallas.craigslist.org/ftw/pts/3143878978.html
Even though the ad states he has a whole set of them and they are wrapped in Falken 235/35zr19 instead of 245/35zr19 I'd still check it out. 19" black ron jon legends for sale on craigslist is pretty rare. And if you contact the poster he might say something like 'I already sold 2 wheels so I only have 2 left .. oh and they are actually 245/35zr19'.
It had too many similarities for me to overlook it. Worth a shot.
Edit: I sent him an email using my 2nd email account I never use asking him about the wheels. We'll see what he says...
Old 07-17-2012, 11:00 AM
  #7798
Giant Blue Car
Catfisha's Avatar
If any of you drive down Cole (between Knox and Fitzhugh), be wary of a motorcycle cop lying-in-wait....
I got tagged at 42 MPH....I wanted to cry LOL!
At least he didn't give me shit about no front plate!
Old 07-17-2012, 07:30 PM
  #7799
All Around Klown
EvilJoker's Avatar
http://dallas.craigslist.org/sdf/pts/3071472216.html
Old 07-17-2012, 07:52 PM
  #7800
Q('.')=O
imj0257's Avatar
LOL. Nevermind, forget the ad I found. His original ad said they were black. Since then he updated the ad with a pic of his car and now they are silver.
EvilJoker, I'm 99% sure that ad was posted before the OP's wheels were stolen.
Quick Reply: AcuraZine Dallas/Ft.Worth Crew
