HELP! Stripped bolt and thread on Brembo Caliper
Old Mar 5, 2012 | 09:31 PM
gotboost79's Avatar
I was doing pads and rotors on my wifes 2007 TL Type S and the bottom bolt(19mm) came out damaging the thread from the Brembo caliper(bottom hole). I thought it just F'd up the bolt but as you can see the threading where the bolt goes in to the caliper is damaged and can't fit a new bolt in there. Anyone know what I can do in this situation or know any shops that can rethread the existing bolt hole?? I took off the caliper in the meantime. I appreciate any help anyone can give me.
Old Mar 5, 2012 | 10:29 PM
Bearcat94's Avatar
AZ Community Team
Not uncommon.
Search Heli-coil.
Old Mar 5, 2012 | 11:05 PM
kingkong_dav's Avatar
KingKong_Dav
get a new spindle
Old Mar 6, 2012 | 01:41 AM
ez12a's Avatar
the overexplainer
You do not need a new spindle. Get it heli coiled.
Old Mar 6, 2012 | 01:21 PM
JORTS's Avatar
Happened to me on both front brembos. I had to purchase new brembo calipers for $600 (that's employee pricing)!!!
Old Mar 6, 2012 | 05:51 PM
94eg!'s Avatar
#1 Super Guy!
Centric Parts (same company as Stoptech) makes re-manufactured calipers for the TL 6MT/Type-S. RockAuto.com sells them for $145 each + $125 core desposit (send your old ones back).
http://extranet.soleniuminc.com/Cent...05&m=58&mm=749
Current part numbers:
142.40084 Front Left
142.40083 Front Right
They also sell both pistons to rebuild yourself: 146.38054 & 146.42023
And a rebuild kit with seals & boots: 143.63023
The part number shown below isn't valid any longer (I think)
Old Mar 6, 2012 | 06:30 PM
blkmz3's Avatar
tap and die kit
Old Mar 6, 2012 | 07:32 PM
TheDingo's Avatar
Resident Dingo
That's good information to have handy.
Old Mar 7, 2012 | 10:12 AM
gotboost79's Avatar
Thumbs down
Definitely good to know, thanks man. If i knew about it a little sooner i would of went this route. I ended up getting it tapped and i believe the machine shop put a helicoil. From speaking with a acura service guy, he tells me they use aluminum bolts on cast iron calipers?? Is there any truth to this? I put a good amount of anti-seize and cleaned out the threads to make sure it went on smooth as possible on all 4 holes. From what i've searched, its a pretty common problem with Acura in general.
Old Mar 7, 2012 | 10:13 AM
ez12a's Avatar
the overexplainer
what he said doesnt pertain to the brembo caliper, which is aluminum if i'm not mistaken.
Old Mar 7, 2012 | 10:31 AM
94eg!'s Avatar
#1 Super Guy!
No that is not correct in any case. The bolts are always metric grade 10.9 steel (with a zinc coating). The calipers are typically cast steel (rotors are cast iron). Brembo calipers are aluminum.
Old Jul 9, 2018 | 08:22 PM
krugsss07's Avatar
5th Gear
I just had this happen to me. What has everyone who went the heli coil option experienced? have they held well??
Old Jul 9, 2018 | 09:36 PM
horseshoez's Avatar
Latent car nut
The TimeSert made for the Brembos gets great reviews. I've used TimeSert to fix stripped spark plug holes and so far, every time I've used them they have worked out great. I believe this is the correct kit for the Brembo caliper repair:
Old Jul 14, 2018 | 09:42 PM
Ossman14's Avatar
I used the time seer kit when one of mine stripped out $100ish dollar kit and $150 to have all 4 bolts done on the calipers, but at least I know it won’t happen again. The kit replaces the aluminum threads with Steele ones
Old Jul 20, 2018 | 04:47 PM
srg818's Avatar
The TimeSert kit works great, I'd even encourage it as a preventative maintenance especially for northern climates.
I made a quick write-up of the install here: https://acurazine.com/forums/3g-tl-p.../#post15923116
Aug 15, 2019 12:58 PM
Lucrativesoldier
Sep 28, 2015 03:47 PM
HOWELLiNC
Sep 18, 2015 11:12 PM
jmoney2001
Sep 11, 2015 12:07 PM
HOWELLiNC
Sep 10, 2015 01:39 PM
