Microsoft: Windows 7 and Office 2010 Thread
Old Jul 31, 2010 | 09:54 PM
  #2241
#1 STUNNA's Avatar
Sanest Florida Man
Do a search for handbrake and find my handbrake where I give my settings to great video quality
Old Jul 31, 2010 | 10:58 PM
  #2242
#1 STUNNA's Avatar
Sanest Florida Man
Found it for you, I'm so nice!
I've ripped over 250 movies with Handbrake in the past month and these are the settings that I settled on.
I originally start with the high profile preset and make some changes. I turn detelecine off cause I don't care about it's framerate since either 24 or 30 will work fine. I set decomb to default since decomb is better than deinterlace I turn deinterlace off. I set denoise to weak, this takes away a slight amount of detail but gets rid off most of the mpeg2 mosquito noise and deblocking is left off. For codec I use h.264 and set the FPS the same as source and use constant quality of anywhere from RF:18.25 to RF:17.75. If it's an old black and white movie I may go higher.
For Audio I remove the 5.1 soundtrack and downmix it to Dolby Pro Logic II. I wanted to keep the 2nd discrete soundtrack but decided not to since HT is in disarray and I didn't want to take up the extra bandwidth.
Subtitles can be tricky cause some movies can use the DVD for foreign langauge parts and some have the the subtitles embedded into the film itself. The Downfall for example is a German movie but I have subtitles disabled since the subtitles are embedded into the movie. If I'm not sure if there's subtitles I'll add an english subtitle track but check the forced only button and choose burned in cause I've had issues with subtitles not showing if I don't burn them in but sometimes they do show, it's hit or miss but it always works if you hit burned in.
Then I leave chapters and advanced tabs alone and these setting work on my iPad and every other device I've tried Mac or PC in the house.
Oh and if a movie is pure black and white with no color tint I'll enable greyscale encoding and that removes all color cause sometimes you can get some slight color noise from crappy mpeg2 compression and greyscale will get rid of all color.
Old Aug 1, 2010 | 07:48 AM
  #2243
CocheseUGA's Avatar
The problem I had before was that it wouldn't autopopulate into 7MC and Metabrowser. I added the .m4v extension into Meta and got it all to work correctly. Using the standard Universal setting in Handbrake worked rather well, I was surprised. No subtitles, which I'm going to have to consider in the future. But the picture looked great on the plasma, really great considering the movie is older than I am.
Old Aug 4, 2010 | 02:41 AM
  #2244
speedemon90's Avatar
so ever since I did that clean install on my computer I've had one problem. My cd/dvd drive is all messed up. I normally dont put in CD's but I was trying to watch something a couple weeks ago and when I went to my computer it would say my D:/ was not found. My cd/dvd is my D drive btw. I went to sony's site, all I found was updates for the device I installed that then went to device manager and installed device again. It worked.
Now today when I insert a DVD nothing happens, I click on my CD/Dvd drive and in says insert a blank disc and my tray opens. Earlier I installed my driver by going through device manager and just clicked update driver went to the one already on my computer and clicked install. Tried it again and the DVD worked.
5 hours later I wanna watch something it again, (Big bang theory), I insert the DVD, same thing again, DVD is not recognized because it just wont show up on my computer, and I click on the drive and the tray pops open and says insert CD/DVD, its already in there, close the tray and nothing happens again. I dunno what is wrong. Any help?
edit: I wonder if this is a hardware issue?
edit edit: It works now. Dunno whats going on
Old Aug 4, 2010 | 04:17 AM
  #2245
#1 STUNNA's Avatar
Sanest Florida Man
check the event log and see if you see anything atapi or cdrom or disk related. It may be hardware or software. The fact that "updating the driver" works is interesting. I'd try uninstalling the drive and deleting the driver files then restarting and do a reinstall of the drive and see what happens. maybe a driver is corrupt, IDK.
Old Aug 4, 2010 | 03:55 PM
  #2246
STL+3.0CL's Avatar
Matt
Are you running any virtual drive software, PowerISO, DameonTools etc..?
Old Aug 4, 2010 | 06:17 PM
  #2247
I had dameon tools, but then I did a clean install on my computer and it went away.
  #2248
where can i find the driver files, on sony's website all it has is the update. Not the original driver.
Old Aug 4, 2010 | 06:20 PM
  #2249
Ohh and last night it happened a second time, but this time reinstalling the update or doing w/e i did last time didnt work. This time I got the pressurized air spray and used it in my cd tray. That made it work. So maybe it was to dirty? I dunno. I'll check again later to see if it works still
Old Aug 4, 2010 | 08:08 PM
  #2250
CocheseUGA's Avatar
Stunna, that method for the subs will only show the intended subs and not the whole movie, right?
Old Aug 4, 2010 | 08:31 PM
  #2251
#1 STUNNA's Avatar
Sanest Florida Man
read this
Originally Posted by Mizouse
so you'll always have on subtitles?
no, forced only means that it only displays the subtitles that are forced to display. Like when you're watching a movie with subtitles off and out of nowhere subtitles appear for a second when someone is talking in a nother language and then they go away. Those are forced subtitles that display even if subtitles are turned off. You want those to display and if you don't have a forced subtitle track then they won't display and you'll be left wondering what that person just said.
ahh i see.
but what about if i wanted to have subtitles turned on then for the entire movie?
(mom likes to use them)
sure then you just select the language you want and uncheck the forced only box and choose burned in and that will put all of the subtitles for that language in there. Well maybe try not using the burned in option cause that allows you to turn subtitles on and off like on a dvd burned in means the subtitles are burnt into the movie and can't be taken out. You can have multiple subtitle and audio tracks too
Old Aug 5, 2010 | 04:09 AM
  #2252
So I've played with a few macbooks now. I'm still a microsoft guy so I prefer windows 7 to Mac's OS. But I gotta say one feature I love in macbooks are the multitouch pad. Thats one thing windows definitely needs to look into. Otherwise I prefer my windows.
Old Aug 5, 2010 | 05:34 AM
  #2253
CocheseUGA's Avatar
Thanks. I think I'll set that as default then.
Old Aug 5, 2010 | 08:15 AM
  #2254
#1 STUNNA's Avatar
Sanest Florida Man
The Acer laptop I had had a multi-touch trackpad
Old Aug 5, 2010 | 12:41 PM
  #2255
REally?! I didn't know windows supported that. Well I guess the manufacturer has a lot to do with that also. But thats nice. I wish my laptop had that I wish more laptops would come with it. Unless they are now, i dunno havent looked at a laptop in a while.
Old Aug 5, 2010 | 01:34 PM
  #2256
#1 STUNNA's Avatar
Sanest Florida Man
multitouch trackpads aren't new I think they save them for the more expensive models. The HP Envy 14 has a multitouch trackpad
Old Aug 5, 2010 | 01:38 PM
  #2257
CocheseUGA's Avatar
You could always buy the Jesuspad from Apple and Hack it in.
Old Aug 5, 2010 | 01:48 PM
  #2258
#1 STUNNA's Avatar
Sanest Florida Man
but you don't get teh multi-touch features. Only one and two finger gestures are recognized
Old Aug 5, 2010 | 02:06 PM
  #2259
CocheseUGA's Avatar
How many fingers can you fit in a touchpad anyway?
Old Aug 13, 2010 | 10:00 PM
  #2260
Billiam's Avatar
Big Block go VROOOM!
OK, it looks like my brain somehow had an even bigger disconnect than normal. Full Windows Media Center functionality is included in Win 7 Professional? For some reason I had it thoroughly embedded in my brain that Media Center was included in Home Premium, but then you had to jump to Ultimate to get the "kitchen sink's" worth of stuff which includes Media Center.
Is there anything that's in Home Premium which is not in Professional? I'm getting a bit paranoid about this because we are about to start reselling Win 7 at work and our license agreement limits us to to Professional only. I do not want a ticked off user coming back to me after paying us money for Pro and complaining "I used to be able to do [blah] with Home Premium and now I can't with Pro!"
Old Aug 13, 2010 | 10:26 PM
  #2261
#1 STUNNA's Avatar
Sanest Florida Man
You got the vista mentality stuck in your head, those days are gone. Pro is a superset of premium and has all it's features and more. It was vista business that didn't have the media stuff but had rdp, fax and scan, domain support, etc. that vista premium didn't have
Old Aug 13, 2010 | 10:29 PM
  #2262
#1 STUNNA's Avatar
Sanest Florida Man
In os x there are 4 finger gestures....
Old Aug 14, 2010 | 05:04 PM
  #2263
whynot's Avatar
X spots the mark
The new Lenovo Thinkpads (T410, T510) have multi-touch pads.
Old Aug 16, 2010 | 07:56 AM
  #2264
litesout's Avatar
Oliver!!!
I can make all the gestures I need with 1 finger.
Old Aug 18, 2010 | 02:02 PM
  #2265
jupitersolo's Avatar
nnInn
Shit move by MS, LiveMail wouldn't d/l or show an Office file because Office wasn't installed on my laptop. Just loaded Office and they d/l now.
Old Aug 19, 2010 | 02:32 AM
  #2266
Ok so recently when I've been opening office I get a message that says the version of microsoft you have is not genuine, or something along those lines. Everytime the message pops up I just click remind me later, and I'm able to use it. So will windows ever stop from letting me use it or should I be fine?
Old Aug 19, 2010 | 06:06 AM
  #2267
rza49311's Avatar
It may lock down after "x" amount of days actually. What version of Office is it?
Old Aug 19, 2010 | 07:52 AM
  #2268
#1 STUNNA's Avatar
Sanest Florida Man
You could get the Office viewer programs instead of the full office.
Old Aug 19, 2010 | 08:54 AM
  #2269
nnInn
Can't use just viewer, need programs to work with. Problems was just making sure e-mail was working correctly trying to get the d/l's. Live Mail is different from Outlook, was confusing getting things set up, because they refuse to use same terms.
Didn't know about viewer option, good to know.
Old Aug 19, 2010 | 09:47 AM
  #2270
#1 STUNNA's Avatar
Sanest Florida Man
Old Aug 19, 2010 | 07:34 PM
  #2271
Damn, I just noticed on the notification that there is a day count! 2 more days!! the world is gonna explode!
Old Aug 19, 2010 | 07:44 PM
  #2272
nnInn
What version of Office is it? I have Office 2003 that I used for six years with no problem on my old laptop.
Old Aug 20, 2010 | 04:08 AM
  #2273
2007. I mean it worked fine for almost 2 years
Old Aug 20, 2010 | 06:08 AM
  #2274
rza49311's Avatar
there should be an activation option, does it ask you to activate when the message pops up? try to reactive.
Old Aug 20, 2010 | 11:35 AM
  #2275
#1 STUNNA's Avatar
Sanest Florida Man
You probably have to reactivate after reinstalling it, this is normal and nothing to worry about, just do it.
Old Aug 20, 2010 | 01:56 PM
  #2276
litesout's Avatar
Oliver!!!
Question about Win7 activation. Friend of mine is getting ready to swap out her mobo, chip and ram. I was going to use the old trick of blowing away everything in the device manager and going from there. Worked countless times for me in XP. Will it require reactivation in 7 though?
Old Aug 20, 2010 | 02:12 PM
  #2277
#1 STUNNA's Avatar
Sanest Florida Man
I'm sure it will. If it doesn't pass activation then call the number and and read the numbers then they'll give you a code
Old Aug 20, 2010 | 02:13 PM
  #2278
rza49311's Avatar
Old Aug 20, 2010 | 02:58 PM
  #2279
litesout's Avatar
Oliver!!!
Its a retail box Home Premium. I thought I read somewhere that was good for 3 activations before they hunt you down. Wish I could remember where I read that.
Old Aug 20, 2010 | 03:36 PM
  #2280
#1 STUNNA's Avatar
Sanest Florida Man
No that's Office Home and Student edition. Even then it just means you have to call and activate, no biggie
