Computer case fan??
Old Mar 4, 2005 | 03:08 PM
fsttyms1's Avatar
Computer case fan??
should it be blowing into the case or out of the case?
Old Mar 4, 2005 | 03:22 PM
Dan Martin's Avatar
Photography Nerd
Generally you want air to move from the front of the case to the rear. So any fans at the front should suck and the ones at the rear shoudl blow.
Old Mar 4, 2005 | 03:36 PM
fsttyms1's Avatar
ok. thanks.
ive only got 1 case fan at the rear but it doesnt seem to keep the temp that much lower than with out it?? maybe i need 2?
Old Mar 4, 2005 | 03:46 PM
bigwilliestyle's Avatar
You can measure the temp? And you've done it with disconnecting the fan?
Why do you think it's too hot?
Like Dan said, the rear should blow out. If there's another opening on the back, and you have extra fan connectors on your motherboard, go ahead. IT's easy. You can install one on the front to blow in, but make sure the fan speeds and amount of air they move match up front to back.
Old Mar 4, 2005 | 06:58 PM
fsttyms1's Avatar
i can measure the temp inside the case with the case fan. monitoring teh cpu with and with out it isnt changing. maybe 1-2 deg 117 F with out 115 F with case fan on.
Old Mar 4, 2005 | 08:28 PM
TLover's Avatar
What is your room temperature? 117F is kind high.
Old Mar 5, 2005 | 09:45 AM
Lung Fu Mo Shi's Avatar
Registered AssHat
?? It's only 47C. If he's running an AMD-64 it's fine. They stay around 40-45C at idle and peak at 55C at room temp.
Old Mar 5, 2005 | 09:58 AM
TSX 'R' US's Avatar
Old fart
^^ yeah, depends on what type of CPU you're running.
you could also get a better CPU heatsink & fan
Old Mar 7, 2005 | 12:20 PM
fsttyms1's Avatar
its a P4 3.2 and fan that came with it
Old Mar 7, 2005 | 12:21 PM
fsttyms1's Avatar
my room is about 10 deg warmer than the rest of the house due to my computer
Old Mar 8, 2005 | 12:51 AM
NiteQwill's Avatar
Adventurist.
Are you running a Northwood or Prescott? That temp seems high. I run that at load. WE have the same CPU.
After some research with another friend, we found that exhaust fans are much more important than intake; as long as you have adequate intake access in the front of your case. If you can just use exhaust fans, your case will naturally allow the air to passively move from the front to rear without the use of other fans.
I use this method and I run 30 degrees C idle and 47 degrees C at load with just two SilenX 9dba fans. Keep in mind, I have 2 WD Raptors, 2 EIDE HDs, 2 CD drives, a Cardreader, and other components. Everything is nice and cool.
Old Mar 9, 2005 | 01:04 PM
kensukikatayo's Avatar
Turbo + Sound = Hey-pee
P4's rnt supposed to run so hot, mayb its time for sum watercooling, im running 12 fans and watercooling on my athlon xp 2500+ oced to 2.2 at 30C idle
F-C
Motorsports News
33
Aug 22, 2018 09:53 AM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
Jinkazetsukai
Nov 21, 2015 05:28 PM
hashbrown
Sep 29, 2015 12:13 PM
