Computer Building Thread
Old Jun 14, 2022 | 09:22 PM
  #1481
Acura TL Builder's Avatar
Great looking setup, as is the framed Porche picture.
Is the 34" screen Made in Russia?
Old Jun 15, 2022 | 07:57 AM
  #1482
CCColtsicehockey's Avatar
That is part of what I love about these monitors. No branding on the back except the Z on all 3 of them. They are very understaded. Although maybe I shouldn't love that they have the Z on them. Wonder if there have been discussions in HP to discountinue their Z series.
Old Jun 23, 2022 | 12:47 AM
  #1483
usdmJON's Avatar
Love the look of the triple monitor set up.
Went a little bigger with a build this time.
This build had a couple first for me.
First tenkeyless build. I normally stick to 60-65% since I dont need an F row or the cluster above the arrows.
First ISO (mostly) build. ISO should have a split left shift but I chose to split the right shift for aesthetic reasons.
First stepped capslock and first 7u chungus spacebar. Normal spacebars are 6u so this one is 1 full key longer.
First OLED screen on a board means I can finally bongocat!
GG86 by Gopolar
Boba U4T switches
Gopolar stabilizers
Kbdf Simple Grey caps
This was a really cool board to build in with one major flaw I can't get over.
First the good. The PCB is hotswap and the amount of options they decided to give the builder is just insane. Most hotswap PCBs wont give options because every option requires a new hotswap socket and a new trace per socket. It is a gasket/sandwich mount. There is a silicone plate divider that acts as a gasket mount. Then the entire pcb and plate is sandwiched between a silicone pad in the lower case and the top case. OLED can be set to show PC temps... or you can custom flash it like mine to have a bongocat that types on a keyboard while you type and counts your WPM.
As for the bad... the plastic screwless design feels cheap and I can't get over it. It is super light and the lack of hardware holding it together securely makes it feel flimsy. If you pick it up with two hands you can kind of torque it out of square with little force. Had they made it aluminum and used 4 screws to hold it all together mounted from the bottom it would be a truly awesome board... but for $130 it's hard to complain that it feels cheap. Also I'm used to fully cnc cases so plastic with no added weight just feels light to me.
Old Jun 23, 2022 | 12:59 AM
  #1484
usdmJON's Avatar
Oh and I forgot to share my endgame board. It was in the group shot I shared before but I wasn't happy with the caps so I held off sharing.
And while these aren't the caps I have planned for my endgame... these will do while I wait.
LW67 by Laneware
StupidFish POM plate and switch pads
GreenDoorGeeks case and plate PE foam
SP Star Magic Girl tactile switches
Owlab "Liquid Metal" stabilizers
GMK Modern Dolch 2 Mist caps
I absolutely love this board. The case feels super premium. It's 2 pieces and all aluminum. It's gasket mount with a custom POM plate for more bounce while typing. And I added some PE foam from GreenDoorGeeks to give it a more muted sound. I tried my first "force break mod" which is done to multipiece aluminum cases. You put tape down where the two aluminum halves meet to reduce ping. That with the foam there is legit no ping at all. In a GMK set the only cap not doubleshot with plastic is the spacebar... which sounds like a hollow bitch once you have the rest of the keys sounding good. So I took some car insulation and lined the inside of the spacebar so now it give a nice deep thud verse a higher clack found.
I have more plans for the board. The stabilizers are nice but Ive used better so I place to replace them with Durock V2 stabs. But I'll wait. My endgame caps wont show up until the end of 2022 if I'm lucky. And I plan to get the case repowdercoated in a teal that matched one of the colors in the cap set. That's when I'll make changes.
Old Jul 21, 2022 | 10:44 PM
  #1485
usdmJON's Avatar
Just joined the GB I shared a while back.
https://www.play-keyboard.store/products/command-65
leaf spring mount
hotswap
8bit sounding solenoid can be turned off with top right toggle
bluetooth
my favorite size... exploded 65%
and only $230 before shipping/taxes
I went with the grey one. I was worried how the ivory would match the cap set I wanted to put on it so I went grey since everything looks good on grey.
Old Jul 22, 2022 | 07:05 PM
  #1486
doopstr's Avatar
Now, that is cool.
Old Jul 27, 2022 | 09:25 AM
  #1487
Beelzebub's Avatar
I think I finally need a new gaming desktop
Need to finally replace my 10 year old desktop
figureing out what I need and how much I want to spend
Old Jul 27, 2022 | 09:58 AM
  #1488
Mizouse's Avatar
Well you picked a better time to build a PC.
AMD 5000 series CPUs have come down in price and have been or maybe are on sale recently.
GPU are easier to get and are coming back down to retail prices.
Nvidia 4000 series cards are supposedly coming soon and supposedly have a big jump in performance. Maybe wait for those.
Old Jul 27, 2022 | 10:08 AM
  #1489
#1 STUNNA's Avatar
Sanest Florida Man
Yeah I'm waiting for 4000 series. It's supposed to require a lot more power too, so we'll see. I might just pick up a cheap 3070 or 3080 if the 4000 series isn't worth it
Old Jul 27, 2022 | 11:14 AM
  #1490
Beelzebub's Avatar
Old Aug 17, 2022 | 03:43 PM
  #1491
Beelzebub's Avatar
well it jut fuckin died.
motherboard is fried
so now I don't have choice.
It will probably be around 3 grand
i7
32gb 16GBx2
3080 ti
m2 and 8tb 7200rpm drive
Old Aug 17, 2022 | 04:38 PM
  #1492
Beelzebub's Avatar
knock $800 off the machine,
I am just going to get a cheap video card and use my current one which isn't that old in this machine until the 4000 series comes out then I can get a 3080 for a much cheaper price.
Old Aug 23, 2022 | 12:53 PM
  #1493
#1 STUNNA's Avatar
Sanest Florida Man
There's a "NOT a" recall for Arctic Liquid Freezer II AIO CPU coolers purchased between May 2021-March 2022. I bought mine on 3/30/22
You can order the self-service kit here: https://www.arctic.de/us/lf-service-kit
GN has a video about it
Old Aug 24, 2022 | 11:08 PM
  #1494
usdmJON's Avatar
New build done. Not one I think yall will particularly like but it was my first stacked acrylic build designed by someone in the hobby not associated with any studios.
Stacked acrylic cases can be used to really create anything you want but they often look very cheap to me which is why I hadn't built one until now.
NOM60 case designed by Qlavier
IFK Delight caps designed by Hipyo
Old Aug 25, 2022 | 12:13 AM
  #1495
Mizouse's Avatar
Interesting.
Old Aug 25, 2022 | 02:46 AM
  #1496
usdmJON's Avatar
Originally Posted by Mizouse
Interesting.
It's kinda cool how you can see the PCB through the bite holes and see the switches and how they sit in the board and the plate.
I have another one of the same board but in a deep blue color on the way. Someone else in the group buy didn't get the color they wanted so I'll be trading them for an all black version. If I can sell it I may try but I would likely have to sell it for around $275 to make a little profit off it. I dont think that would be too hard so we'll see if I can make that my first build I sell.
Old Aug 29, 2022 | 06:59 PM
  #1497
doopstr's Avatar
Ryzen 7000 announcement. Up to 5.7Ghz
Old Aug 29, 2022 | 07:37 PM
  #1498
Mizouse's Avatar
hmmm AVX-512 support? Interesting since Intel dropped it from Alder Lake.
Old Aug 29, 2022 | 09:27 PM
  #1499
doopstr's Avatar
Plenty of chips and dip.
Old Aug 30, 2022 | 12:38 PM
  #1500
#1 STUNNA's Avatar
Sanest Florida Man
Looking good, we'll see how Intel responds. Either way, AMD will respond back with their 3D V-cache models, rumors are that the 3D V-cache models are quite a bit better than the base 7000 series.
Old Sep 2, 2022 | 12:12 PM
  #1501
#1 STUNNA's Avatar
Sanest Florida Man
Old Sep 2, 2022 | 12:27 PM
  #1502
Mizouse's Avatar
nah makes no sense for me to upgrade to another 30 series card.
My 3080 Founders Edition does everything I need.
I may upgrade my 5600x to a 5800X3D since prices are coming down.
Old Sep 2, 2022 | 12:40 PM
  #1503
#1 STUNNA's Avatar
Sanest Florida Man
Wait Miz, don't you have a SFF PC that's crashing randomly and you've tried everything but haven't fixed it? I was watching some GN video about power supplies and they were saying that the SFF PSUs can have difficulty handling the transient spikes from the GPU since they're more limited in the amount of capacitance they can have due to it's smaller size.
Here it is with the time stamp
Old Sep 2, 2022 | 01:13 PM
  #1504
Mizouse's Avatar
Nah, it’s not the PSU. Found out it was faulty RAM.
I figured it wasn’t the PSU because I bought a Corsair SFX750 and it still had the random crashes. Returned it since my Corsair SFX600 worked fine.
not sure why RAM was the last thing I checked for troubleshooting
(I did try running each stick in single channel mode thou and had no crashes)
Anyways this worked out better for me since I swapped out to low profile Ram, which lets me run a beefier cooler.
also want to note that the crashes happened when the computer was idle or even while posting.
Old Sep 2, 2022 | 02:10 PM
  #1505
#1 STUNNA's Avatar
Sanest Florida Man
Either way the 3080Ti may not be a good combo with your SFF PSU
Old Sep 2, 2022 | 02:15 PM
  #1506
Mizouse's Avatar
Yea, in stock form it might not be, but I have my gpu undervolted. About the same performance but less watts used.
not sure if I’ll be able to use Nvidia 40 series and AMD 7000 series thou.
But I have no plans to upgrade.
Old Sep 6, 2022 | 01:38 PM
  #1507
#1 STUNNA's Avatar
Sanest Florida Man
I'm thinking about getting the 7700x and the Asus ProArt AM5 mobo. I'll probably skip the 3d V cache this gen time around, maybe next gen it will be on all models or be standard.
I've always liked AMD for CPUs and Nvidia for GPUs but isn't AMD working to bring their chiplet design and 3d V Cache to the GPU as well?
Meh they need to start competing with Nvidia outside of games, I need an answer to NVENC or Nvidia Broadcast...
I guess it's hard for AMD to compete well in two very competitive markets at the same time
Old Sep 6, 2022 | 04:37 PM
  #1508
doopstr's Avatar
I'm hoping for some deals on Ryzen 5000 this Black Friday to upgrade my two AM4 boxes. I'll let the Stunnas of the world beta test AM5 for a couple of years.
Old Sep 6, 2022 | 08:11 PM
  #1509
doopstr's Avatar
LTT makes a good screwdriver.
Old Sep 6, 2022 | 08:20 PM
  #1510
Mizouse's Avatar
I preordered one
Wanted to replace my computer screwdriver set I got back in high school
Old Sep 6, 2022 | 10:16 PM
  #1511
#1 STUNNA's Avatar
Sanest Florida Man
https://www.youtube.com/watch?v=845HUaWYSQA
Yeah that's the only thing I've wanted that they sell. I was waiting for Project Farm to get his hands on one, and he came through real quick, love his videos.
I want an LTT screwdriver but I don't really need one, my iFixit Manta still gets the job done. The strong magnet and minimal backdrag are my fav parts about it.
Damn now that I think about it I may just buy it for the magnet, I need that shit, but I won't get it for months now. Maybe someone is scalping them on eBay....
Old Sep 16, 2022 | 05:33 PM
  #1512
doopstr's Avatar
Old Sep 16, 2022 | 07:42 PM
  #1513
#1 STUNNA's Avatar
Sanest Florida Man
I’ve heard about the complaints for years, but very surprised they took this step.
Old Sep 16, 2022 | 08:16 PM
  #1514
#1 STUNNA's Avatar
Sanest Florida Man
Damn the disrespect the other board partners are going to feel when they see this video. Nvidia wants them gone and is going to make it so unprofitable for them that they follow EVGA
Nvidia is like the boss who cuts your hours in order to encourage you to quit.
Old Sep 16, 2022 | 09:29 PM
  #1515
#1 STUNNA's Avatar
Sanest Florida Man
Old Sep 16, 2022 | 10:28 PM
  #1516
Mizouse's Avatar
Sad. I was considering an EVGA 40 series card as well.
Old Sep 17, 2022 | 03:13 PM
  #1517
#1 STUNNA's Avatar
Sanest Florida Man
Old Sep 20, 2022 | 12:12 PM
  #1518
Mizouse's Avatar
https://youtu.be/fj245xMr-BM
4090 and 4080 announced.
4090 releases 10/12 $1599
4080 November $899
https://www.theverge.com/2022/9/20/2...e-release-date
$200 increase for the 4080 over the $699 3080
Old Sep 20, 2022 | 01:09 PM
  #1519
#1 STUNNA's Avatar
Sanest Florida Man
Maybe they listened to their partners and raised prices, didn't they all say the MSRP was too low to stay in business? Blame evga for the price increase
Old Sep 20, 2022 | 08:54 PM
  #1520
doopstr's Avatar
Why no 4070/4060?
Really dumb to have two cards called a 4080 with different CUDA core counts. Why not call the 12GB version the 4070, mo money?
