Computer Building Thread
Old Feb 26, 2019 | 03:28 PM
  #881
Yvuru's Avatar
nice pickup! pictures for us plz
Sweet! That'll be quite nice.
I grabbed a used desktop recently on Offerup!
i7-8700K
16 Gigs of DDR (I've upgraded it to 32)
250 GB 970 EVO
3 TB WD 7200 rpm
Nvidia Ti 1070 Ti with 8GB of video RAM
Not bad for under $700. Came with a nice case too!
Old Feb 26, 2019 | 03:56 PM
  #882
stogie1020's Avatar
Needs more Lemon Pledge
you want pics of a computer tower? Lol.
"ooooh, nice USB ports...."
Old Feb 26, 2019 | 03:57 PM
  #883
Costco's Avatar
take off access panel bb
Old Feb 26, 2019 | 04:43 PM
  #884
stogie1020's Avatar
Yeah, that's it.... unclip the sata connector. Slowly...
Old Feb 26, 2019 | 05:39 PM
  #885
doopstr's Avatar
I want a vid of the plastic being pulled off.
Old Feb 26, 2019 | 06:21 PM
  #886
Mizouse's Avatar
^Nice pickup!
Hackintosh 2.0?
Yes sir
tell me more about these hackintoshes? Are there any limitations or features missing?
i may go this route since the new Mac Pro will be butt ass expensive.
the new mini while nice, doesn’t have any dedicated graphics and a egpu wouldn’t perform as well as an internal GPU
Old Feb 26, 2019 | 07:36 PM
  #887
Ken1997TL's Avatar
Your only real limitations are hardware related really. I recommend checking this guide out for what processors, motherboards etc are supported properly. https://www.tonymacx86.com/buyersgui...-buyers-guide/
In my experience, motherboards are the big limitation. You just pick one that is supported properly along with a supported graphics card. Installation and setup of OSX is easy after you have the right stuff in place
Old Feb 26, 2019 | 07:51 PM
  #888
Mizouse's Avatar
Any issues with handoff/continuity?
airdrop?
iCloud? ICloud Drive? iCloud Keychain? Photo stream?
Thunderbolt 3?
stuff like that
Old Feb 26, 2019 | 07:53 PM
  #889
Ken1997TL's Avatar
That I know of? No. But I recommend browsing the TonyMac forum for issues people might encounter.
Old Feb 26, 2019 | 09:39 PM
  #890
Bearcat94's Avatar
AZ Community Team
Well, my late October planned build had to be put off, so I am revisiting it now...
PCPartPicker part list / Price breakdown by merchant
CPU: Intel - Core i9-9900K 3.6 GHz 8-Core Processor ($525.89 @ Amazon)
CPU Cooler: Noctua - NH-D15 82.5 CFM CPU Cooler ($89.95 @ Amazon)
Motherboard: ASRock - Z390 Taichi Ultimate ATX LGA1151 Motherboard ($253.88 @ OutletPC)
Memory: G.Skill - Ripjaws V Series 64 GB (4 x 16 GB) DDR4-3200 Memory ($430.98 @ Newegg)
Storage: Samsung - 970 Evo 250 GB M.2-2280 Solid State Drive ($77.99 @ B&H)
Storage: Samsung - 970 Pro 1 TB M.2-2280 Solid State Drive ($347.92 @ Amazon)
Video Card: Gigabyte - GeForce GTX 1050 2 GB OC Video Card ($139.99 @ Amazon)
Power Supply: EVGA - SuperNOVA 1000 P2 1000 W 80+ Platinum Certified Fully-Modular ATX Power Supply ($159.99 @ B&H)
Total: $2026.59
Prices include shipping, taxes, and discounts when available
Generated by PCPartPicker 2019-02-25 14:07 EST-0500
64GB RAM is probably overkill, unless you're doing CAD or modeling or rendering. For day-to-day use, including a lot of gaming, people will say even 32GB is overkill. Nice thing about RAM, if you start lower (say 32GB), you can add on later if needed.
I don't understand that motherboard with that Graphics Card. You can get an MB just as good spec-wise for less, reduce RAM, then upgrade the GPU and probably stay close the same overall spend. Also, personally, I wouldn't buy ASRock. I'd go with MSI or ASUS, maybe Gigabyte third.
Too much power supply. Power supply efficiency is based on load. Having a load that is too high or too low isn't good (more is not necessarily better) and you're not running anything that should need more than about 650 watts as far as I can tell.
Linky: Cooler Master: Power Supply Calculator
Edit:
BTW, what do you plan to use it for?
Also, what case and what OS?
Old Feb 27, 2019 | 06:16 AM
  #891
Yvuru's Avatar
show me that bare PCB
Old Feb 27, 2019 | 09:49 AM
  #892
stogie1020's Avatar
Edit:
I totally understand your point, but I am not a normal use-case, as this machine is used for data processing, hashing, OCRing, etc.
Here is it's current predecessor (i7 5820 w 64GB RAM) in moderate use (I can nearly max it out on RAM and peg the processor at 100% for long duration on a regular basis):
All components in the build are chosen for reliability and durability. I make money off these machines, so downtime needs to be avoided. I also plug lots of peripherals in (hence the power supply choice). Motherboard has a layout I need for 64GB of RAM as well as a massive air cooler, plus it has 10GB nic onboard. GPU is only for a few apps I use that are java based and seem to tax the GPU enough that I want to move that work off the i9. Plus, I have the machine hooked up to a KVM for remote desktop, so it helps with the display rendering a bit.
OS will be Win7 or 10 PRO, leaning toward 7 though.
Case will be Lian Li, still deciding which one. Unfortunately, they put a window on most of their cases now, which I try to avoid.
Old Feb 27, 2019 | 03:56 PM
  #893
stogie1020's Avatar
Anyone ever use Phanteks cases?
https://www.newegg.com/Product/Produ...82E16811854004
Old Feb 27, 2019 | 04:14 PM
  #894
Yvuru's Avatar
I have a Phanteks case currently. See post #845. Great case to work with, would recommend
Old Feb 27, 2019 | 04:34 PM
  #895
stogie1020's Avatar
Thanks Yvuru, forgot you had one and posted it.
I have been loyal to LianLi for the last decade+, but the Phanteks looks pretty comparable, and they have clearance for my air cooler, which Lian Li does not (nothing over 175mm...) I only wish the Enthoo Pro was aluminum, not plastic. I loved the aluminum on the Lian Li cases.
Old Mar 11, 2019 | 11:30 AM
  #896
stogie1020's Avatar
OK, adjusted the PS down to a 750W and added the Phanteks case plus some fans and an OS...
CPU: Intel - Core i9-9900K 3.6 GHz 8-Core Processor ($529.89 @ B&H)
CPU Cooler: Noctua - NH-D15 82.5 CFM CPU Cooler ($89.95 @ Newegg)
Motherboard: ASRock - Z390 Taichi Ultimate ATX LGA1151 Motherboard ($253.98 @ Newegg)
Storage: Samsung - 970 Evo Plus 250 GB M.2-2280 Solid State Drive ($87.99 @ B&H)
Storage: Samsung - 970 Pro 1 TB M.2-2280 Solid State Drive ($347.99 @ B&H)
Video Card: Gigabyte - GeForce GTX 1050 2 GB OC Video Card ($129.99 @ Newegg)
Case: Phanteks - Enthoo Pro ATX Full Tower Case ($94.00 @ Newegg)
Power Supply: EVGA - SuperNOVA P2 750 W 80+ Platinum Certified Fully-Modular ATX Power Supply ($151.42 @ Amazon)
Operating System: Microsoft - Windows 10 Pro OEM 64-bit ($147.49 @ B&H)
Case Fan: Noctua - NF-A14 PWM 82.5 CFM 140mm Fan ($23.67 @ Newegg)
I think this is the final build, just going to mull it over a little longer to make sure I don't have any bright ideas...
Somehow, the QVL memory in the 64GB size ended up being much less than I previously was finding... Yay me. It's not the fastest timing, still looking into faster memory.
Old Apr 1, 2019 | 09:32 AM
  #897
imj0257's Avatar
Q('.')=O
Time to get a new home PC. The one I currently have is 5+ years old and takes forever to boot up and it seems like it needs to install Windows updates every week and those updates take hours. I usually have to restart it a few times because it is so slow or freezes.
Anyways, I'm looking for a (already built!) home PC. It will mainly be used for browsing/videos/music/oldergames.
Not sure if I want an All-in-one or the desktop and monitor like I currently have. I was thinking of getting another Dell just because I am most familiar with them. Any ideas?
Old Apr 2, 2019 | 03:04 PM
  #898
Yvuru's Avatar
Get something with a SSD. No HDD. This will sort your boot/load times out. That should be your minimum requirement. Everything else is up to your budget.
Old Apr 3, 2019 | 12:58 PM
  #899
imj0257's Avatar
Q('.')=O
What is the difference between SSD and HDD? I assume SSD is faster...
Old Apr 3, 2019 | 01:55 PM
  #900
Ken1997TL's Avatar
SSD = Solid State Drive
In short, it doesnt have moving parts that are spinning. Read/write times are faster and for you the user, it'll generally be much snappier
Old Apr 3, 2019 | 02:27 PM
  #901
imj0257's Avatar
Q('.')=O
Old Apr 3, 2019 | 02:43 PM
  #902
Costco's Avatar
Is NVMe worth spending extra? I read that it's way faster than a SATA SSD, but I really mostly play games and browse on my PC. Occasionally will watch stuff on it.
But you can get a 500GB 970 Plus for $130. Should I just wait and get a 1TB later? I don't really need it now, I just want it
btw damn stogie, I've been looking into builds lately and you chose top notch components all around.
Old Apr 3, 2019 | 02:44 PM
  #903
Costco's Avatar
Seriously though I think stogie might be one of a handful of people in the entire world using a 9900k with a 1050 I know it is exactly what he needs, still funny.
Old Apr 4, 2019 | 09:46 AM
  #904
Yvuru's Avatar
I would personally go for the NVME. I am bias tho because I have two of them. They are so easy to install no cables needed. I have a video comparison below of windows boot times and gaming load times for ssd/hdd/nvme
Old Apr 4, 2019 | 09:54 AM
  #905
DTvn's Avatar
Wow that's less of a difference than I was expecting. With how cheap SSDs are now I should probably grab a 1TB to replace my 240.
When I built my PC I think I paid close to $100 for a 128GB Adata SSD
Old Apr 4, 2019 | 12:56 PM
  #906
stogie1020's Avatar
I know... My wife tells me all the time that I am "special"... She means in a good way, right?
Old Apr 4, 2019 | 12:57 PM
  #907
stogie1020's Avatar
You could also get the best of both worlds but using a 250GB NVME for OS and programs and then use a 1TB SATA SSD for storage.
Old Apr 4, 2019 | 03:18 PM
  #908
Costco's Avatar
The mobo I recently got has an m.2 slot, which is why NVMe tempts me. Seems like m.2 is the popular form factor right now, and having fewer cables sounds good to me.
I'm just debating right now on which size. Don't laugh, but I have a 60gb SSD for the OS (and not much else obviously) and 1TB HDD for media which is only half full. The system was built 6+ years ago.
Got a 500gb SATA SSD as a gift, going to set it up this weekend. Ideally I would have the OS, programs and games on a 500gb NVMe, and use the 500gb SATA for the rest of it. Or should I do it the other way around, since NVMe is supposed to be better for file transfer?
Old Apr 4, 2019 | 03:53 PM
  #909
stogie1020's Avatar
You generally want your OS on your fastest drive, unless you do specialized stuff like database work, photo editing, etc.
Old Apr 4, 2019 | 05:09 PM
  #910
Yvuru's Avatar
if you guys dont have crazy performance requirements i would recommend the intel 660p nvme drives. the pricing is fantastic for it right now especially in the higher capacities. also it has a 5 year warranty which is what drew me to buying it in the first place. my 500gb intel 660p is full now so i bought a 1tb samsung 970 evo plus to become my new boot drive
Old Apr 5, 2019 | 11:45 AM
  #911
stogie1020's Avatar
The speed specs on those intel drives are similar to a SATA drive, kind of defeats the purpose of going to NVME IMO.
Old Apr 5, 2019 | 12:00 PM
  #912
DTvn's Avatar
I'll upgrade at some point. Content with my i7-4790k/1070 right now but I always get the urge to upgrade when my friends start talking about new parts.
Old Jul 29, 2019 | 11:23 AM
  #913
stogie1020's Avatar
OK, my i9 build was put on hold for little while while I worked out some cooling issues in the room it will be housed in. Now that I have additional cooling, I am going to move forward with the build:
CPU: Intel Core i9-9900K 3.6 GHz 8-Core Processor
CPU Cooler: Noctua NH-D15 82.5 CFM CPU Cooler
Motherboard: MSI MPG Z390 GAMING PRO CARBON ATX LGA1151 Motherboard
Memory: G.Skill Trident Z 64 GB (4 x 16 GB) DDR4-3200 Memory
Storage: Samsung 970 Evo Plus 250 GB M.2-2280 Solid State Drive
Storage: Samsung 970 Pro 1 TB M.2-2280 Solid State Drive
Video Card: Gigabyte GeForce GTX 1050 2 GB OC Video Card
Case: Phanteks PH-ES614PC_BK ATX Full Tower Case
Power Supply: EVGA SuperNOVA P2 850 W 80+ Platinum Certified Fully Modular ATX Power Supply
Operating System: Microsoft Windows 10 Pro OEM 64-bit
Case Fan: Noctua NF-A14 PWM 82.5 CFM 140 mm Fan
Case Fan: Noctua NF-A12x15 PWM 55.44 CFM 120 mm Fan
I swapped out the Tiachi Ulitimate motherboard for an MSI one, as the Tiachi's main feature was the onboard 10GB NICm, but reviews of that onboard NIC were pretty bad. I will add a Intel540 10G NIC for a few hundred more and know I am getting a good NIC.
Old Aug 15, 2019 | 07:29 PM
  #914
stogie1020's Avatar
OK, everything is ordered, should be here by next week to assemble.
Old Aug 15, 2019 | 07:49 PM
  #915
Mizouse's Avatar
Old Aug 15, 2019 | 09:49 PM
  #916
svtmike's Avatar
Make sure you orient all those fans to create positive pressure in the case and thereby exhaust all heat and repel all dust. It’s magic!
And I think you know 64 GB of memory is complete overkill.
Meanwhile my Core i7 rig is close to a decade old.
Old Aug 16, 2019 | 02:03 AM
  #917
Mizouse's Avatar
He’s mentioned this before but for his use, 64GB is not overkill.
Old Aug 16, 2019 | 10:35 AM
  #918
svtmike's Avatar
Old Aug 16, 2019 | 12:13 PM
  #919
stogie1020's Avatar
I forgot to list the barometer I also ordered. It sits inside the case and shuts the system down if neutral or negative pressure are sensed.
Originally I wanted 65GB of RAM, but I scaled back to 64GB to be more "reasonable"...
Old Aug 16, 2019 | 02:31 PM
  #920
Mizouse's Avatar
