Apple: macOS formerly OS X News and Discussion Thread
Old May 11, 2015 | 02:37 PM
  #441
Whiskers's Avatar
Go Giants
Adwaremedic seems to be the most legit
Old May 11, 2015 | 02:47 PM
  #442
stogie1020's Avatar
Needs more Lemon Pledge
I loaded Avast to try it out. Seemed like the best mix of free and not slowing the machine down much.
Old May 15, 2015 | 12:32 PM
  #443
stogie1020's Avatar
OK, so continuing the AV discussion...
I had an interesting set of circumstances and thought I would share the results.
I was given a Mac OSX OS drive in an OWC (USB3) enclosure and asked to locate malware (I knew there was 'some' in advance).
Given the ready availability of Windows based scanners, I installed the HFS+ drivers for bootcamp on a W7 machine (Thinkpad, 7x64, i7, 8gb) and was able to access the drive without issue.
I then ran multiple scanners against the entire 125GB logical volume with Very varied results. Since some of the scans completed as expected, I am confident that the HFS+ drivers were not the source of the discrepancies.
AVAST - Scan took 40-60min, malware located.
BitDefender - Scan took 2+ hours, malware located
AVG - Scan took 43 seconds, NO malware located
Panda - Scan took 5 seconds, NO malware located
Then attached the drive to a MBP and re-ran the Avast. Scan took 60 minutes, malware located.
(None of the scanners were allowed to remove any found malware).
Just thought it was interesting in the event anyone is connecting HFS+ volumes to a windows system and expecting AV tools to work.
TLDR: Bottom line: Some do and some don't...
Old May 15, 2015 | 12:43 PM
  #444
doopstr's Avatar
what nasty did it find? Was it intentionally put on the drive to test AV or the malware got on the drive by itself?
Old May 15, 2015 | 01:15 PM
  #445
stogie1020's Avatar
It's a little bit of adware/PUP, nothing serious. It was naturally there through user activity, not placed there for testing.
Old May 15, 2015 | 04:27 PM
  #446
Whiskers's Avatar
Go Giants
Porn...
Old Jun 8, 2015 | 12:15 PM
  #447
AZuser's Avatar
_
next OS X = El Capitan
Old Jun 8, 2015 | 12:21 PM
  #448
#1 STUNNA's Avatar
Sanest Florida Man
they finally added aero snap from windows 7!
Looks just like windows 10 too, glad they added it though it's one of my most used and favorite features of windows
Old Jun 8, 2015 | 12:25 PM
  #449
Whiskers's Avatar
Go Giants
Horrible name.
Old Jun 8, 2015 | 12:31 PM
  #450
#1 STUNNA's Avatar
Sanest Florida Man
Seems like it's a small update like from leopard to snow leopard so they kept a similar name
  #451
AZuser's Avatar
_
Originally Posted by Whiskers
Horrible name.
+1
Prefer the large cats naming scheme vs new CA location name scheme.
Old Jun 8, 2015 | 12:36 PM
  #452
Whiskers's Avatar
Go Giants
Originally Posted by AZuser
+1
Im ok with the CA locations, just not this one.
Old Jun 8, 2015 | 12:38 PM
  #453
AZuser's Avatar
_
Yay! Another free upgrade. This fall.
Old Jun 8, 2015 | 12:39 PM
  #454
doopstr's Avatar
I think I know who named this one. :ghey:
Old Jun 8, 2015 | 02:57 PM
  #455
jupitersolo's Avatar
nnInn
You're just pissed because they stole your porn name.
Old Jun 8, 2015 | 03:13 PM
  #456
Whiskers's Avatar
Go Giants
Maverick
Old Jun 30, 2015 | 11:27 PM
  #457
Mizouse's Avatar
Holy fvck.. Apple finally listened. TRIM can now be turned on for 3rd party SSDs with OSX 10.10.4
Earlier today Apple released OS X 10.10.4, an under-the-hood update to OS X that introduced several bug fixes and improvements. One improvement, according to Ars Technica, is support for TRIM for third-party SSD hard drives. We previously covered TRIM likely coming natively to the next version of OS X El Capitan but it appears support has already arrived.
[​IMG]​
Photo via ArsTechnica​
Quote
With today's OS X 10.10.4 update, however, Apple has added a command line utility that can be used to enable TRIM on third-party SSDs without having to download and install anything. Called trimforce, the utility can be executed from the OS X terminal, and it requires a reboot to start working.
TRIM is a system-level command that allows the operating system and the drive to communicate about which areas of the drive are considered unused and thus ready to be erased and rewritten to. In the absence of TRIM, users can see significantly slower drive writes as the drive begins to fill up. Most modern operating systems support TRIM but for Apple's OS X, it has only included support for its OEM SSDs. This means that Mac users looking to install an after-market SSD in a machine originally intended for spinning disc hard drives would run into trouble without the help of other third-party tools.
To enable TRIM, a user just has to type "sudo trimforce enable" into the Terminal window. Ars Technica points out that running TRIM prompts a "scary" message from the system, but notes it's largely because each SSD implements TRIM in a different way, with older disks sometimes acting in a way OS X would not expect.
Too bad this doesn't apply for me since my boot drive SSD is connected via USB3.0.
still just as fast as when I installed it about 6 months ago.
Old Jun 30, 2015 | 11:33 PM
  #458
Mizouse's Avatar
yes i know there were other ways to turn it on, but this looks like to be a more "native" way to do it
Old Jun 30, 2015 | 11:34 PM
  #459
#1 STUNNA's Avatar
Sanest Florida Man
Ha! Beat me by 5 minutes! I saw this and thought of Ken
I assumed trim was enabled for all SSDs since 10.7, apparently not.
Old Jul 7, 2015 | 05:32 PM
  #460
BeezleTL85's Avatar
Needs a 930
decided to try out the new Music app and cancel my subscription to Beats music...... now i cant stream anything with full bars and unlimited service.... pretty damn annoyed right now
Old Jul 7, 2015 | 07:54 PM
  #461
stogie1020's Avatar
Got synergy working between my MBP and the windows desktop it sits next to. Love it...
Old Jul 9, 2015 | 08:14 PM
  #462
#1 STUNNA's Avatar
Sanest Florida Man
doop! First thing I checked after upgrading to 10.11 is if you could move spotlight back to the upper right. It works! And it remembers it's position next time
Old Jul 9, 2015 | 08:27 PM
  #463
Whiskers's Avatar
Go Giants
Meh, going back to Yosemite for now.
Old Jul 10, 2015 | 09:22 AM
  #464
doopstr's Avatar
Office 2016 for mac released. If you have Office 365 go get it.
Old Jul 10, 2015 | 10:35 AM
  #465
#1 STUNNA's Avatar
Sanest Florida Man
Got it now, been beta testing it. Not signing up for O365 though
Old Jul 10, 2015 | 11:17 AM
  #466
stogie1020's Avatar
Damn, just bought the standalone Office 2011 a month or two ago...
Old Jul 10, 2015 | 11:24 AM
  #467
Whiskers's Avatar
Go Giants
Office beta expired.
I paid the $99 a few weeks back. Been testing El C, IOS 9 and Watch 2 for a while.
El Capitian is pretty good. Granted there is not much change, so not a lot of things to break. I can't think of a feature that really stands out. Just performance and security. I put it on my 13 MBPr and left it on it, it actually runs very well on it. I have two partitions on my 12 inch Macbook and it seems buggier, so Im using Yosemite on it and testing it on the other partition.
IOS 9 was on by my Iphone 6 plus and Ipad Mini 3. The OS runs pretty good, I like some of the features and UI. A lot of apps still dont work with it, so that was getting to me. I put it on my phone so I could get to Watch OS 2.0.
Watch 2.0 - Love the new photo watch faces. Hate the bugs and battery life. Will be awesome when ready.
So there is no way to downgrade the watch back to 1.01. Apple is just crazy awesome and for free sent me a brand new watch with 1.01 and I shipped mine back to them. So now my phone is back to 8.4, Watch is 1.01 Ipad mini is 9, MBPr is 10.11, MBr is dual boot 10.10 and 10.11
Old Jul 10, 2015 | 11:25 AM
  #468
Whiskers's Avatar
Go Giants
Return?
I have a sub through work so Im running it.
Old Jul 10, 2015 | 11:37 AM
  #469
stogie1020's Avatar
I just saw that the standalone will not be released until September.
Oh well, Office for MAC is an "80%" of the Office for windows anyway... OneNote on the mac drives me nuts, while I love it on windows.
Old Jul 28, 2015 | 09:41 AM
  #470
doopstr's Avatar
Parallels 11 to feature always-on support in OS X for Microsoft?s Cortana virtual assistant | 9to5Mac
According to a leaked product page on the Australian Parallels page, the popular virtual machine software will support Microsoft’s Cortana virtual assistant throughout OS X. The product page explains that as long as Windows 10 is running somewhere in the background, users will always be able to say “Hey Cortana” and receive a response
Old Jul 29, 2015 | 08:20 PM
  #471
kurtatx's Avatar
Azine Jabroni
A couple of weeks later, there's still a lot of truth to all this. The new font is a bit of an adjustment on iOS9 and El Cap, but overall, not too many big changes. The first public beta of iOS9 had a really bad issue where App Switching crashed iOS (that was a common problem in early iOS 7, too IIRC). OS X is fine, a bunch of little features that make it better.
I'm hoping the next iteration of OS X addresses some of OS X's shortcomings relative to Windows 10.
Old Sep 30, 2015 | 07:46 AM
  #472
Whiskers's Avatar
Go Giants
Today is the day for El Capitan.
Old Sep 30, 2015 | 10:56 AM
  #473
Mizouse's Avatar
I still need to update my 2011 Mac mini from Mavericks. Then again it's only my mom using it
I'll update my 2012 mini in a week
Old Sep 30, 2015 | 01:20 PM
  #474
stogie1020's Avatar
Shit. I forgot.
I think I will keep the MBP in Bootcamp/Windows for a few days to see how it rolls out...
Old Sep 30, 2015 | 03:42 PM
  #475
Whiskers's Avatar
Go Giants
Its good
Old Sep 30, 2015 | 05:14 PM
  #476
stogie1020's Avatar
Its good
OK,
Old Sep 30, 2015 | 06:00 PM
  #477
Whiskers's Avatar
Go Giants
See you in 7 hours
Old Sep 30, 2015 | 06:16 PM
  #478
stogie1020's Avatar
See you in 7 hours
I am 2.1 GB in...
How big is this thing?
Old Sep 30, 2015 | 06:38 PM
  #479
Whiskers's Avatar
Go Giants
6 something. Ill check in the morning
Old Sep 30, 2015 | 06:41 PM
  #480
stogie1020's Avatar
no worries, I am at 2.5gb now. Thank the flying spaghetti monster for fiber internet.
