Apple: iPhone News and Discussion Thread
Needs more Lemon Pledge
Anyone have any info on any deals for the 8 in the next week or two? Need to replace wifey's 6...
Grandpa
Received 2,609 Likes
I cannot imagine why that would be.
But in a given place and time, at the same dBm, the iPhone X will report fewer bars of signal than the LG V30.
In this same situation, both devices can make crystal clear voice calls.
However.... In this same situation, the LG V30 gets about ⅓ faster data speeds than the iPhone X.
This seems to be true across my travel area and in all sorts of situations...1.33X to 1.50X faster data speeds with the LG V30.
This 4XMIMO thing is apparently not just a selling point.
If data speeds were the most important thing to me, the LG V30 would be the device that I used the most.
Grandpa
astro (11-23-2017)
Received 3,755 Likes
So has everyones required a signature for delivery or only if it says on the tracking information? Mine is not showing that it is required. Just trying to figure out if I need to be home tomorrow.
Azine Jabroni
Pixel has nasty burn-in. Having regrets leaving iOS
How does a phone have burn in? The screen isnt on for hours...
bought two Apple computers last week as gifts
one came today no signature
another supposed to come Friday
Azine Jabroni
Just Google Pixel burn in, so bad! So worst than the TV’ s in the 90’s.
The Third Ball
Received 4,852 Likes
Even Apple warns against burn in on the X. Says it’s an inherent trait to OLED. Hence it comes with stock settings for a short active times before putting the screen to sleep.
Grandpa
In some Apple documents, Mr Ive cautions against holding an image on an active iPhone X screen for longer than 20 minutes.
This is probably overly cautious, but it is still a good idea to change your habits if you are someone who does things like keeping a full size clock loaded at night, or something like that.
The burn-in issue is one of the many reasons why Apple stuck with LCD for so very long. The burn in issue is much better now than it used to be.
Yet even now, they're working on an "Active LCD" screen for a cheaper version of the iPhone in 2018.
Grandpa
Is the burn in also an issue on the regular Pixel2 or just the XL?
Azine Jabroni
Just the 2 XL. The 2 XL screen is manufactured by LG Display and has been riddled with problems. By contrast the 2 screen is manufactured by Samsung Display (sister company of Samsung Mobile) and doesn't have any issues. iPhone X and the Pixel 2 have the same screen manufacturers and have a similar collection of minor issues.
stogie1020 (11-21-2017)
Does Samsung still reserve the latest and greatest screen tech for their own devices? Or will the S9 have essentially the same screen as the iPhone X?
Azine Jabroni
So, technically, Samsung display is a separate company from Samsung Mobile, but they're all under the same umbrella. iPhone X's screen was built to Apple's specification by Samsung display. The S9 will have a Samsung Display designed by Samsung mobile. I would expect the Samsung one to be significantly more vibrant but less real looking. Either way, they're very different.
Sanest Florida Man
I do notice that I'm on AT&T Wi-Fi more often on the X. My house is very near a cell tower and I usually have 4-5 bars on my 6. With the X I'm on Wi-Fi calling, that could mean it's signal is weak enough that it's switching to Wi-Fi instead or maybe there's a change we don't know about where it favors Wi-Fi calling in more situations than it did before. Apple removed the actually dbm signal strength numbers from the field test menu so it's harder to tell. Which that seems suspicious to me....
Is there a way to completely shut off wifi?
If I turn off the control center toggle, it sometimes turns back on by itself? I mainly get annoyed with the available wifi networks pop-up.
when I hit “turn off WiFi” on control center it always stays off
Received 2,786 Likes
https://www.macrumors.com/2017/11/13...-explanations/
https://support.apple.com/en-us/HT208086
Use Bluetooth and Wi-Fi in Control Center with iOS 11
Learn how to control Wi-Fi and Bluetooth from Control Center on your iPhone, iPad, and iPod touch with iOS 11 and later.
About Wi-Fi and Bluetooth
In iOS 11 and later, when you toggle the Wi-Fi or Bluetooth buttons in Control Center, your device will immediately disconnect from Wi-Fi and Bluetooth accessories. Both Wi-Fi and Bluetooth will continue to be available, so you can use these important features:
Disconnect from Wi-Fi networks
Open Control Center and tap
. The icon will dim and your device will disconnect from any network that you're connected to.
While Wi-Fi is disabled, auto-join for any nearby Wi-Fi networks will also be disabled until:
Disconnect from Bluetooth accessories
. The icon will dim and your device will disconnect from any accessory it's connected to, except for Apple Watch, Instant Hotspot, Apple Pencil, and Continuity features, like Handoff.
If Bluetooth is turned off, you won’t be able to connect your iOS device to your Bluetooth accessories until:![](https://support.apple.com/library/content/dam/edam/applecare/images/en_US/mac_apps/itunes/divider.png)
Turn off Wi-Fi and Bluetooth
If you want to completely disable Wi-Fi and Bluetooth for all networks and devices, follow these steps:
- AirDrop
- AirPlay
- Apple Pencil
- Apple Watch
- Continuity features, like Handoff and Instant Hotspot
- Instant Hotspot
- Location Services
![](https://support.apple.com/library/content/dam/edam/applecare/images/en_US/iOS/ios11-control-center-wi-fi-inline-icon.png)
- You turn on Wi-Fi in Control Center.
- You connect to a Wi-Fi network in Settings > Wi-Fi.
- You walk or drive to a new location.
- It's 5 AM local time.
- You restart your device.
![](https://support.apple.com/library/content/dam/edam/applecare/images/en_US/iOS/ios11-control-center-bluetooth-inline-icon.png)
- You turn on Bluetooth in Control Center.
- You connect to a Bluetooth accessory in Settings > Bluetooth.
- To turn off Wi-Fi, go to Settings > Wi-Fi and turn off Wi-Fi.
- To turn off Bluetooth, go to Settings > Bluetooth and turn off Bluetooth.
if you do it in control center, no, it doesn't actually turn it off.
my apologies
Grandpa
It also looks like they've got an Intel chip in line for 2018, with gigabit LTE and 5G potential, and they might not use Qualcomm at all.
0_o
Sanest Florida Man
I did that like 8-9 years ago, shit is annoying.
Mizouse (11-22-2017)
That. I've had mine off since iPhone 3GS(?) maybe even 1st gen iPhone.
On my X photos the live mode is always on
when I turn it off it’s off
next time I take a photo it’s ON again
so frustrating
need to permanently turn it off
so frustrating
Grandpa
Probably, for a lot of us.
As a device to use when you must get something done...yes. Yes several times over.
You will find an Android device that can do something or another better, however.
In my case, my V30 has cellular data that is demonstrably faster than the iPhone X's cellular data, just as an example.
Because the iPhone X is insurmountable in its benchmark scores and calculating ability, reviewers are coming up with these weird tests where they load a bunch of games and applications, and then reload them to see how fast devices can do it.
I don't know anybody who uses his smartphone like that, but whatever.
LOL....
Loading a bunch of crap into an 8 gb RAM Android and expecting a 3 gb iPhone to be able to do the same thing is something I do not understand...but that's what they're doing these days to try to make the other devices maybe stand a chance against the iPhone.
As a single device that does everything well, even if it's not the best at something or another, yes, the iPhone X is worth the money for people who have to do things. :-)
LOL....
Community Architect
robb m.
robb m.
I think the iPhone X is possibly the most close to perfect physical embodiment of technology I have ever held in my own hands. I was skeptical on the size (I like the Plus size a lot), but after 5 days of use, this device is essentially the perfect physical form. The material quality, fit and finish are really, really great too.
I guess you could say I'm pretty happy with the purchase.
Whiskers (11-24-2017)
Grandpa
Community Architect
robb m.
robb m.
it is the best phone they ever created
I am still going no cover no case
loving it
Stage 1 Audi S5
Community Architect
robb m.
robb m.
I don't use protection.
Mizouse (11-23-2017)
The Third Ball
Robb don’t need no jimmy hat!
