Apple: Hardware News and Discussion Thread
Old Oct 22, 2010 | 11:52 AM
  #281
Whiskers's Avatar
Go Giants
Originally Posted by doopstr
Isn't there a lot more apps available for the iPad than the mac? For you guys that have both what do you think is better for kids under 10? There are a lot of nice mac options in the refurb store for around $1000.
Kids love Ipads...
Old Oct 22, 2010 | 03:06 PM
  #282
einsatz's Avatar
I miss my 03 CL-S :(
Originally Posted by Sarlacc
The only reason I have a 13" MBP instead of an MBA is because my photography when I travel. Otherwise I would have had an Air a long time ago...BUT that said...everything I might use on a MBA (sans photo processing) can also be accomplished on an iPad.
I've used my MBA (1.8+SSD) for processing in LR2/LR3 since LR2 came out in mid 2008. I toss in the MBA into my camera bag and it slips in between the back and the dividers where all the gear goes since it's so thin. That way I can have my gear and "photo lab" all in one bag. It really helps when you're traveling.
Old Oct 23, 2010 | 09:27 AM
  #283
einsatz's Avatar
So it turns out you can get the 13" with a 2.13GHz C2D and 4GB of RAM... it's starting to sound a little more appealing.
Old Oct 23, 2010 | 05:42 PM
  #284
Sarlacc's Avatar
The Third Ball
You dont have any issue with lag while processing?
As much as I love my 13" MBP...its not nearly as fast for processing as my iMac...but it gets the job done when I need it. I figured the MBA would be much slower to use. plus the lack of firewire support for external drives kinda sucks.
I think once they get faster processors, larger capacity SSD drives, and USB 3...then we'll have a game changer.
Old Oct 27, 2010 | 01:46 PM
  #285
doopstr's Avatar
I installed my SSD in my imac today.
Holy cow this is so much better.
Old Oct 27, 2010 | 04:18 PM
  #286
Scrib's Avatar
Administrator Alumnus
I didn't realize the imac hard drives could be accessed. Which model do you have?
Old Oct 27, 2010 | 04:31 PM
  #287
jupitersolo's Avatar
nnInn
just search youtube for videos, many of them.
Old Oct 27, 2010 | 04:47 PM
  #288
doopstr's Avatar
It's a 24" aluminum. One needs to be VERY careful with the LCD display. I was happy that OCZ makes a 3.5" SSD. There is a issue with the cable not being long enough for a 2.5".
Old Oct 27, 2010 | 05:15 PM
  #289
Sarlacc's Avatar
The Third Ball
How much storage and how much did that set you back?
Old Oct 27, 2010 | 05:26 PM
  #290
doopstr's Avatar
This one http://www.newegg.com/Product/Produc...82E16820227590
120GB $205 after rebate.
I also got a 1TB external FW800 drive from OWC.
Old Oct 27, 2010 | 05:32 PM
  #291
doopstr's Avatar
FWIW...
Results 313.07
System Info
Xbench Version 1.3
System Version 10.6.4 (10F569)
Physical RAM 4096 MB
Model iMac8,1
Drive Type OCZ-VERTEX2 3.5
Disk Test 313.07
Sequential 184.72
Uncached Write 266.95 163.90 MB/sec [4K blocks]
Uncached Write 272.27 154.05 MB/sec [256K blocks]
Uncached Read 85.32 24.97 MB/sec [4K blocks]
Uncached Read 397.50 199.78 MB/sec [256K blocks]
Random 1025.98
Uncached Write 1322.40 139.99 MB/sec [4K blocks]
Uncached Write 527.90 169.00 MB/sec [256K blocks]
Uncached Read 3458.08 24.51 MB/sec [4K blocks]
Uncached Read 1042.70 193.48 MB/sec [256K blocks]
Old Oct 27, 2010 | 05:58 PM
  #292
Scrib's Avatar
Damn. That's a nice increase over stock.
Old Oct 28, 2010 | 09:40 AM
  #293
doopstr's Avatar
My grey apple boot screen moves into the OS X GUI after 2.5 spins
Old Oct 28, 2010 | 10:13 AM
  #294
Scrib's Avatar
And this is why I want a macbook air. I took a trip down to the apple store and launched every single app in the applications folder and the laptop didn't choke one bit. From the benchmarks I'm seeing, it is outpacing the 13" MBP with the weaker processor, which is a direct tribute to the flash memory.
Now you're making me consider ripping out the hard drive in my iMac. Was it that hard? I've opened up MBPs before. Worse?
Old Oct 28, 2010 | 10:19 AM
  #295
stogie1020's Avatar
Needs more Lemon Pledge
Last I checked, there were three screws on the bottom of the "case" when standing up. Remove those and the back comes off. That was a few years ago, though and they may have redesigned the mechanism to open it. Prior to that system it was like friggin neurosurgery to get the damn things out...
Old Oct 28, 2010 | 10:34 AM
  #296
doopstr's Avatar
If you are comfortable opening things up it's not hard. I did the drive swap in about an hour and I wasn't rushing. Find a video on youtube for your model and just follow along.
You will need suction cups to get the front glass off ($1 at dollar store). The glass comes off very easily. You will also need a small torx screwdriver (don't know the size) and a Philips head. Keep track of where the screws came out as there are several different lengths.
You need to be a bit careful with the isight cable. The LCD on my model had two ribbon cables that needed to be pulled out. The thing that surprised me is that the LCD will quickly get a few bits of dust on it. I was able to blow the dust off of it before putting the glass back over it.
So far I have no complaints with my drive and the 3.5" size made it a drop in replacement.
BTW: In the vid I watched the guy used scotch tape to re-tape the ribbon cables. IMO that's a no no. Scotch tape holds static. I just reused the existing tape.
Old Oct 28, 2010 | 03:29 PM
  #297
Scrib's Avatar
Don't you run the risk of getting dust behind the glass? Not sure how you get around that other than working in a controlled environment.
Old Oct 28, 2010 | 03:51 PM
  #298
doopstr's Avatar
Pick an area in your house with the least amount of dust and you will be alright.
I did it on my dusty desk and noticed that a few specs of dust got on the LCD pretty quickly but it did blow off. Don't worry about it too much. Once it's all back together, if you notice dust behind the glass you can simply pull the glass off with the suction cups and take care of it. Be more concerned about the way you handle the LCD to avoid fingerprints.
Old Oct 28, 2010 | 04:48 PM
  #299
The Dougler's Avatar
Unofficial Goat
ifixit.com has excellent step by step pictorials.
Old Oct 29, 2010 | 11:05 PM
  #300
astro's Avatar
Community Architect
robb m.
posting from my new 11" MBA
Old Oct 30, 2010 | 01:20 PM
  #301
Sarlacc's Avatar
The Third Ball
Noice!
Old Oct 31, 2010 | 10:33 AM
  #302
Scrib's Avatar
Did you get it with 4gb?
Old Nov 5, 2010 | 09:54 AM
  #303
doopstr's Avatar
Xserve
Long live Mac Pro Server
Old Nov 5, 2010 | 12:17 PM
  #304
#1 STUNNA's Avatar
Sanest Florida Man
yeah I saw that! IDK how they're going to penetrate the business market without a rack-mountable server, maybe they got something new coming out? but then why would they change the name?
Old Nov 5, 2010 | 12:26 PM
  #305
doopstr's Avatar
I'm more interested in what server hardware they will be putting in this...
Old Nov 5, 2010 | 12:47 PM
  #306
#1 STUNNA's Avatar
Sanest Florida Man
I'm more interested in what they're going to do with it, they've been building it for what two years now?
Old Nov 5, 2010 | 01:10 PM
  #307
Sarlacc's Avatar
The Third Ball
The towers are rack mountable with third party access. Always have been since the G3.
Old Nov 5, 2010 | 01:21 PM
  #308
#1 STUNNA's Avatar
Sanest Florida Man
So then the smallest size is a 3U? Does the mac pro have redundancy options like redundant power supplies cause that's a standard feature on servers
Old Jan 15, 2011 | 07:43 AM
  #309
doopstr's Avatar
So the Mac Plus is 25 years old.
http://www.macworld.com/article/1569...tml?lsrc=top_1
Twenty-five years ago, Apple introduced the Macintosh Plus, a groundbreaking member of the Mac family tree. Industry analysts praised the Plus, which retailed for $2,599 (or what would be a whopping $5,188 today), as the computer Apple should have released in 1984
So I thought that was interesting but then I found this...an iPad and Mac Plus Helmet!
click link for vid...http://afterglowvp.com/2011/01/kid-chameleons-helmet/
Old Jan 29, 2011 | 10:02 PM
  #310
TS_eXpeed's Avatar
Not new hardware....just picked this thread since it was recent and didn't want to start a new thread.
Got a little quirk going on with my MBP (circa early 2008). The past couples months or so, my computer no longer will play/load VEVO videos both on YouTube or on the VEVO site. In case you don't know what VEVO is, it's typically the site associated with "official" music videos from artists and most are on YouTube I believe.
It hasn't always been like this.
When I go to a video that's from the VEVO site, it has the little rotating dots symbol in the middle of the black screen where the video would play but never actually loads. Ever. The buttons are also there but greyed out so you can't click them. This includes the 'time bar' of the video as well.
All other videos on YouTube (or anywhere else for that matter) play just fine. There something I'm missing??
FWIW, I'm running OSX 10.6.4.
Old Jan 29, 2011 | 11:52 PM
  #311
Whiskers's Avatar
Go Giants
Reinstall Flash
Old Jan 29, 2011 | 11:55 PM
  #312
lightjak_tsx's Avatar
Old Jan 29, 2011 | 11:57 PM
  #313
Ken1997TL's Avatar
Originally Posted by Whiskers
Reinstall Flash
+1
And why are you still on 10.6.4? Just curious
Old Jan 29, 2011 | 11:59 PM
  #314
Ken1997TL's Avatar
Oh and for those that didn't know, I got a Mac Mini this past month for my home theater.
Old Jan 30, 2011 | 12:35 AM
  #315
#1 STUNNA's Avatar
Sanest Florida Man
Do you have any ad blockers or HOST files running? On some sites, videos won't load if access to the ad servers that display the pop up ads on the bottom of the video screen are blocked. For example, Engadget, CBS, College Humor and I think MSNBC videos won't play due to this.
Yup, I checked, VEVO videos won't play for me either and I'll guarantee you that's why. Oh well, fuck em I can watch videos on YouTube
Old Jan 30, 2011 | 02:37 AM
  #316
Mizouse's Avatar
i was at the apple store earlier tonight, but unlike whiskers i walked out empty handed and i am fine with that
Old Jan 30, 2011 | 10:23 AM
  #317
doopstr's Avatar
Third party, Apple blessed, XServe replacement coming tomorrow?
http://www.activestorage.com/
Some of the senior management used to work at Apple. Intel has invested in them.
Old Jan 30, 2011 | 10:39 AM
  #318
TS_eXpeed's Avatar
Reinstall Flash
Didn't werk.
Old Jan 31, 2011 | 08:46 AM
  #319
doopstr's Avatar
FAIL, just a storage device that mac clients can use.
Old Jan 31, 2011 | 11:55 AM
  #320
Whiskers's Avatar
Go Giants
Originally Posted by TS_eXpeed
Didn't werk.
:fail:
