The Official Honda Accord Thread
#1881
Your Friendly Canadian
Received 1,492 Likes
I think they all do. I forget the numbers exactly but 2003 has positive camber in the front and something like -1 in the rear.
#1883
The Dumb One
why do people tell you to unbolt your suspension from the control arms to raise/lower F&F coilovers?
you can easily adjust height from the shock body without ever doing anything more than removing the wheel.
#1884
Whats up with RDX owners?
In the front I unbolt the fork arm to allow the lower part of the shock body to spin. You have to unbolt the shock body from the lower control arm in the rear on the CL.
#1885
The Dumb One
i loosened the lock nut off of the shock body and was able thread the shock itself down while still attached.
differnt F&F design, but you get the idea.
1. loosen the shock body lock nut.
2. using the top lock nut near the spring, thread down into shock body.
3. tighten lock nut when at desired height.
#1886
Turd Polisher
It's a custom 3" catback with Vibrant mufflers.
My only complaint about the exhaust system is the fitment isn't the greatest underneath the car.
They put a large resonator underneath and it scrapes quite a bit on speed bumps.
Oh well, the power gains were worth it!
#1887
http://i26.photobucket.com/albums/c1...15-08_1547.jpg
http://i26.photobucket.com/albums/c1...15-08_1548.jpg
http://i26.photobucket.com/albums/c1...15-08_1551.jpg
#1888
#1889
Turd Polisher
Hey guys,
If there are any owners in SoCal with 7G Accord Coupes / Sedans, I'll be parting out my car once I get the stock parts to fill in their spots.
Keep your eyes peeled on VeSixPe for my FS thread, real cheap prices.
#1890
What? Why are you parting out?
#1891
Turd Polisher
I was planning on parting out my car and trading it in for an S2000.
After thinking about it over the weekend, I don't think it's a wise decision right now (Trying to save for a place).
I might as well keep something that's reliable / comfy DD .. since my commute is around 40 miles a day.
So, to eliminate this new car itch .. I bought coilovers
I can get about $200 - $250 for my suspension now .. pretty cheap upgrade
#1893
I was lucky enough to get my hands on a set of 8.5" A-specs locally. Gave them a wash in my basement's laundry tub today and took off the Acura "A" to be replaced with a set of Honda emblems.
Tires are going off tomorrow. Then I have to decide whether or not to refinish the wheels. It's not really curb rash but looks like someone was bright enough to set the wheels on the ground with the face down. All the wheels have little pits almost uniformly across the outer edge.
Then I have a set of 245/40/18 Bridgestone RE960AS Pole Position that I'm putting on to serve as our new winter set-up. The white TLs will be for sale soon!
Before
After
Before
After
#1895
Heck yeah! I almost feel bad because this will primarily be a winter set-up. Actually it presents a challenge because I have to run a pretty fat tire to cover the wheel so I can take it through a tunnel wash. Necessary evil here in Michigan. Would rather run something narrow to cut through the snow.
#1896
Under construction
Didn't you have a 4 door Accord a while back? You had the 19' rdx aspecs if I recall...it looked damn good!
#1899
Under construction
I searched cars.com and only came up with like 30 6mt TLs in the country with less then 40k. Pretty rare and some of the prices are ridiculous!
#1901
Turd Polisher
Car is looking fresh!
#1902
The Dumb One
thanks bud! and glad you decided to keep yours... you've been progressing so fast, i'd hate to see it go before you finished it up!
on the subject of blue coupes...
why do people buy these type of wheels! it bugs the shit out of me.
it would be a clean car otherwise.
#1904
Turd Polisher
I just installed my coilovers and there are things I like and don't like.
When I first installed them, I put the shocks on the lowest perch and marveled on how good it looked after lowering the floor jack. .
Very excited, I got in the car .. turned the key and went for a test drive.
I could tell immediately that the car rode like shit, bounced all over the place and felt undriveable as my daily. It bounced so much it honestly felt like there was nothing but rebound from the spring with no compression from the shock .. lead me to believe maybe the shocks were faulty?
I raised them up to where my old H&R Race spring setup was and called it a day .. Ride is still stiff and bouncey .. but nothing compared to what it was on the lowest perch.
I'm happy to report that it handles like it's on rails. I was testing my car on Palomar mountain and it felt 5 / 10mph faster in the tighter turns. Even going through full throttle shifts (1st - 3rd), the car / engine / everything felt so planted. Hardly had any wheel spin and wheel hop on the big 1st > 2nd shift compared to my softer suspension setup.
I'll post pics when the car is cleaned up, overall I'm pretty disappointed in the ride quality on dumped coilovers .. guess that's what you sacrifice on a really low car? .
#1905
I saw your thread in the 3G Section but didn't have much to contribute. I've ridden in slammed cars before and they rode just fine, not bouncy whatsoever. Maybe you should try to get yourself a set of TEIN SS so you have the dampening ability?
#1906
I dont like Teins because in order to lower the car, you have to adjust the spring perch. When you do that, you lose strut travel. They are also very expensive for what you get. A better option would be a set of custom built Konis/Ground Control slip ons or a set of high quality custom coilovers (Zeal, AMR, etc.).
What springs are on those Teins? It sounds as though you have absolutely no damping, which is why the car is bouncing around so much (its relying solely on the spring to control body motion). If the struts themselves arent blown, its possible the springs are too stiff for the damping rates.
Another thing I dont like about Tein, $100 each strut for a rebuild/revalve
#1907
Turd Polisher
I was driving down a semi bumpy road and I was watching the front of my car bounce like it was on bags.
I just don't have $700 - $1000 to throw down on a nice set of coilovers .. I figured I could get these and have a small improvement over what I had installed with adjustable ride height.
Live and learn I guess .
I'll have to get the model # off of the springs, but it looks like the stock ones that came with it.
Perhaps I could re-use my H&R springs and throw them on these adjustable shocks? I wonder if it'll ride any better.
Next weekend's project will be?
The following 4 users liked this post by Rockstar21:
#1911
I drive a Subata.
Turd Polisher
Nice retrofit. Are those TSX projectors?
#1919
Milan, your pics make me feel really guilty about the condition of my 2003.
