Noise on front end
Old Jan 11, 2021 | 08:07 PM
Acuragang97's Avatar
Noise on front end
Hey guys hope everybody is safe and welll
so I got a 2013 tl base n am try trouble shoot all the problems I have n get em fixed but it’s hard to diagnose n where I live the mechanics ain’t really that good but with that being said sometimes when I put the car in reverse you hear a bang like something knock or something it only happens every now n then but only when I put the car in reverse sometimes drive thinking if it’s the mounts I change them like twice already they just keep going bad and the other problem I have this crank/knock sound when I turn the steering like example am about to parallel park it’s not continuous but one or two times you can hear it you hear it mostly when it rains last problem lol I think it’s electrical idk but when I drive I the car loosing power it would seem as if am about to run out of gas or something I changed the coil paks n plugs it was fine but started again after a few it’s not bad as before now but wondering if the coilpaks may not be working ??? I got like 103k miles on it btw had it for 2 years now never had these problems
Old Jan 12, 2021 | 07:22 PM
csmeance's Avatar
Worn axles are most likely the cause of your clunk, tie-rod ends or the bushings that the steering rack sits on. Loosing power how so? Like someone suddenly is holding the car back? It could be the VSA kicking in to keep the car from skidding.
Old Jan 12, 2021 | 09:46 PM
Say I be on the highway just doing regular 60 when I look at the rpm needle it goings up n down like I’m about to run out of gas n I can feel the power loss cuz when it goes up the power is there but when it drops down the power it’s gone it’s hard to explain but I think I have a video, tonight I was On my way! Home n it was acting weird in the same kind of way but when I come to a complete stop it feels like the car about to cut off but it don’t
Old Jan 12, 2021 | 09:51 PM
Here’s a example it does that even when I be pressing on the gas (LOOK AT RPM NEEDLE)
Old Jan 12, 2021 | 09:56 PM
When it seems like it gone drop the power goes away n comes back on n off until it stops
File Type: mov
Old Jan 13, 2021 | 01:41 AM
Getting worse
I think it’s getting worse now was driving On my way! To work just now n everything I try to accelerate it just felt like hulk pulling me n releasing me none stop this time it didn’t go away n when o stop I feel the engine feels like it’s about to stall just a lil not crazy
Old Jan 13, 2021 | 01:58 PM
New update
So the check emission system lights in now and traction control plus car drives light shyt like am pulling a trailer with a house on it just over it sad day made an appointment at the dealer closest ones Friday so 😪😪
Old Jan 15, 2021 | 07:31 PM
csmeance's Avatar
1. Why are your tire pressure so high?
2. Seems like trans issue with torque converter or fluid flow/pressure issue
Old Jan 16, 2021 | 04:09 AM
Update
Took it to Acura yesterday they said one of my injectors wasn’t firing n honestly idk I been meaning to ask how much cuz I think I have too much but idk how much exactly what’s the right tp? N with the noise that I was telling you they it’s nothing wrong with the car I told them check the axles n they said everything was fine I just needed a injector n trans mount I paid for them to do complete check of the car
CPR
6G TLX (2021+)
Jan 11, 2021 07:08 PM
pnokio
Mar 22, 2016 06:10 AM
GLowrdr
Mar 8, 2013 03:44 PM
Bike Effects
Oct 30, 2008 06:02 AM
wonderboy
Apr 14, 2004 08:24 AM
