TPMS Error pops up a moment after I start driving!
Old Apr 19, 2010 | 12:52 AM
daoism76's Avatar
it does not go away for the duration of the drive. how can i get it fixed? is this fuse problem or sensor problem? thanks in advance
Old Apr 19, 2010 | 12:21 PM
shadowkahn's Avatar
Have you checked your tire pressures? a TPMS error usually means one (or more) of them is low.
Old Apr 19, 2010 | 03:42 PM
KaMLuNg's Avatar
what kind of error is it? have you filled the tires with air...
Old Apr 19, 2010 | 04:42 PM
daoism76's Avatar
it's actually "tpms system error". when i check the tire pressure reading on the mid display before the error pops up the right front tire is showing 58 psi and the rest were 32. i had new left front tire replaced a month ago due to poor alignement. maybe the dealership over inflated the tire? i'm gonna check the pressure manually and see 58 psi is the real reading.
Old Apr 19, 2010 | 05:43 PM
2Slo4U's Avatar
manually check the tire pressure. TPMS is fairly accurate so I would guess you have a tire pressure issue...
Old Apr 19, 2010 | 10:23 PM
daoism76's Avatar
ok i manually checked the tire pressure and the right front tire is 31 psi, not 58 shown in the MID display. so does this mean i need to replace the tire pressure sensor for that one tire? thanks
Old Apr 19, 2010 | 10:40 PM
shadowkahn's Avatar
Most likely, yes.
Old Apr 19, 2010 | 10:47 PM
daoism76's Avatar
is this something that's DIY or do i need to take it to the shop?
Old Apr 20, 2010 | 12:05 AM
SpiderX1016's Avatar
Are all tires the same size?
Old Apr 20, 2010 | 08:51 AM
shadowkahn's Avatar
It's inside the tire, on the part of the valve stem that you can't see. The tire has to be taken off to get at it, so you'll have to take it in.
Old Apr 20, 2010 | 10:16 AM
Jesstzn's Avatar
Maybe the installer damaged the in wheel sensor. Did this error message start right after the tire replacement?
Old Apr 20, 2010 | 12:21 PM
daoism76's Avatar
all the tires are the same size. this error came up about 1 month after dealer install the left front tire. the error is for the front right tire. guess i will bring it in when i get the chance. hopefully it isn't an expensive job
Old Apr 20, 2010 | 12:50 PM
mglax13's Avatar
New shoes on my
What year is your TL? It might still be covered under warranty.
Old Apr 20, 2010 | 07:24 PM
daoism76's Avatar
bought it new april 2006 but i already have 90k miles so i doubt it haha
Old Apr 20, 2010 | 09:19 PM
marcoguy's Avatar
Had the same problem with a wheel falsely reading 58psi. Swapped this defective tire with another one to see if the problem moved. It did, which proved it was the pressure sensor in the defective wheel. Ordered an Acura TPS on Ebay (eBay My World: dch.acura.of.temecula) for about $45. Have a knowledgable tire place properly torque the new sensor on the wheel. The Acura TPMS will sense the new working sensor without needing the dealer for any programming.
Good Luck
Old Apr 22, 2010 | 05:24 PM
daoism76's Avatar
got it fixed at the dealship today. sensor was $50 and the labor was $100 with $15 disposal fee for total of $165. is there anywhere else i can take it to next time this occur again?
Old Apr 22, 2010 | 06:22 PM
Jesstzn's Avatar
Disposal fee for something that small .. I would have said " give it to me ... I'll dispose of it " then took it home and garbaged it.
mada51589
Jan 9, 2025 04:40 PM
bailey24
Nov 21, 2015 08:43 PM
andysinnh
Sep 5, 2015 11:38 PM
dlknight
Sep 3, 2015 07:54 PM
chrisr
5G TLX Problems & Fixes
Aug 31, 2015 08:24 PM
