TPMS Error pops up a moment after I start driving!
it does not go away for the duration of the drive. how can i get it fixed? is this fuse problem or sensor problem? thanks in advance
it's actually "tpms system error". when i check the tire pressure reading on the mid display before the error pops up the right front tire is showing 58 psi and the rest were 32. i had new left front tire replaced a month ago due to poor alignement. maybe the dealership over inflated the tire? i'm gonna check the pressure manually and see 58 psi is the real reading.
ok i manually checked the tire pressure and the right front tire is 31 psi, not 58 shown in the MID display. so does this mean i need to replace the tire pressure sensor for that one tire? thanks
all the tires are the same size. this error came up about 1 month after dealer install the left front tire. the error is for the front right tire. guess i will bring it in when i get the chance. hopefully it isn't an expensive job
Had the same problem with a wheel falsely reading 58psi. Swapped this defective tire with another one to see if the problem moved. It did, which proved it was the pressure sensor in the defective wheel. Ordered an Acura TPS on Ebay (eBay My World: dch.acura.of.temecula)
for about $45. Have a knowledgable tire place properly torque the new sensor on the wheel. The Acura TPMS will sense the new working sensor without needing the dealer for any programming.
Good Luck
for about $45. Have a knowledgable tire place properly torque the new sensor on the wheel. The Acura TPMS will sense the new working sensor without needing the dealer for any programming. Good Luck
got it fixed at the dealship today. sensor was $50 and the labor was $100 with $15 disposal fee for total of $165. is there anywhere else i can take it to next time this occur again?
mada51589
Jan 9, 2025 04:40 PM
andysinnh
Sep 5, 2015 11:38 PM
