steering noise
Old Nov 19, 2024 | 08:54 PM
marklittlefield4's Avatar
steering noise
Only happens at low speeds/rpms. Thoughts? Ball joint?
https://share.icloud.com/photos/0eck...LrFQXGM9YVSVNQ
Old Nov 22, 2024 | 08:23 AM
Old Nov 25, 2024 | 09:18 PM
Chad05TL's Avatar
If not ball joints, try spraying the rubber sway bar mounting grommets with silicone or some lubricant
Old Nov 28, 2024 | 08:40 AM
Update: inner tie rods were worn and one outer tie rod - looks like the previous owner only replaced one and not both - the noise has improved, but not completely gone. There was some PSF in the boots when I took them off. There also appeared to be some play in the rack itself. No play in the ball joints or CA bushings or sway bar links/bushings or rack and pinion bushings. Maybe a little play in the CV axles, but this noise doesn't sound like a failing cv joint. Looks like a new rack and pinion may be in my future.
Old Jan 12, 2026 | 04:46 PM
tasso's Avatar
Reviving this thread, did you end up replacing rack and pinion and did that solve the issue? I have the same noise, i just replaced the upper control arms thinking that might be it but no. Within the last 6 months - 1 year i have replaced inner an outer tie rods, both CV axles, struts, and ball joints and never had an issue until now. I've never touched the rack and pinion but would like to know if anyone else has dealt with this same exact issue and found it to be the rack and pinion.
Old Jan 12, 2026 | 10:18 PM
Mine ended up being lower ball joint
Old Jan 12, 2026 | 10:59 PM
tasso's Avatar
Interesting....you had mentioned you found PS fluid in the inner tie rod boots. I guess since it was the ball joints you left the rack and pinion alone?
Old Jan 13, 2026 | 08:19 PM
No I did the rack too. It was a bad day for my wallet.
black6.3
Jun 16, 2024 09:55 PM
myTaLizaS3.2
Nov 11, 2019 01:20 PM
lylen
Mar 5, 2010 09:08 AM
Cisko TLS
Jan 28, 2009 12:43 PM
siuwan
1G TSX Problems & Fixes
Jul 18, 2004 10:01 AM
