ran over deer! bad wobble at speed
Old Sep 30, 2023 | 09:16 AM
05tlguy's Avatar
Hello all . Hoping somebody can give advice. Wife ran over a dead deer in the center of the road, cracking lower left fender and tearing fender liner out . I removed both front wheels and looked for any play, bent or broken components. Nothing, everything is tight and looks good. The steering wheel is slightly off to the right by about an inch. I'm certain it needs an alignment, but other than that I can find nothing mechanically wrong . When I get the car on the highway and hit about 65 miles an hour there is a slight vibration from engine ?or transmission ?but not transmitted through the steering wheel. You can feel it under your feet and your seat. At highway speed of 65, if you give it more gas the vibration gets worse and lessens if you release the pedal. I can't see how an alignment would fix this and as it's only under acceleration at speed but not while coasting at speed. If anyone can help i'd much appreciate it.
Old Oct 2, 2023 | 10:42 AM
BreezyTL's Avatar
Get it aligned and see if it goes away. They may find something broken while adjusting the alignment. If it doesn't go away, inspect it further.
Old Oct 2, 2023 | 04:58 PM
csmeance's Avatar
sounds like a bent tie rod at a minimum...
Old Oct 3, 2023 | 06:37 AM
05tlguy's Avatar
The only problem is, the steering wheel does not vibrate at all. It can only be felt through the floor, pedal and seat. Immediately upon lifting my foot off the pedal, all is smooth. Really starting to wonder if a motor mount was destroyed, or somehow the inner cv was damaged ? I don't feel any back and forth looseness on cv axle, just slight in/out movement. FWIW I have a routine service and alignment scheduled upcoming. Mechanic will look everything over at that point, because I'm stumped.
Old Oct 3, 2023 | 08:19 AM
BreezyTL's Avatar
We can sit here and suggest things but without completing the alignment, we are shooting in the dark. Report back after your routine service, or go get an alignment and see if they can do that or find other issues.
Old Oct 10, 2023 | 07:20 PM
csmeance's Avatar
If you can jack it up to move the wheel, you can easily take pictures to post here.... just sayin...
RedsTL
Aug 17, 2022 08:15 PM
kuzdu
Feb 28, 2019 02:14 PM
Acura_Swag
Oct 6, 2013 10:07 PM
2k6ATL
Sep 16, 2012 12:16 AM
probmxstyle
Aug 20, 2007 02:08 PM
