Still vibrating after alignment !!!!!! Help !!
Old Oct 2, 2013 | 07:01 PM
Acura_Swag's Avatar
Whats up AZ, so for about a month now my car has been vibrating on high speeds meaning on the highway after 75mph it would vibrate hard and it got annoying so recently i went to get it aligned so they checked the front end for any issues and my passenger outter and inner tie rods were done so i got them replaced and finally got the car aligned. After the alighment i jumped on the highway and the vibration has reduced from how it was before but its still vibrating at 75mph and over. What else can be cuasing this vibration at high speed ? Anyone that had or has this prob can please tell me what you did to solve it or what you may think it is. Thanks i appreciate the help.
Old Oct 2, 2013 | 07:28 PM
Turbonut's Avatar
Alignment isn't the cause of wheel vibration. Look for a Hunter Road Force machine in your area and have the wheels balanced and checked for any out of spec conditions:
http://www.gsp9700.com/search/findgsp9700.cfm
Old Oct 3, 2013 | 09:28 PM
Bikergal515's Avatar
You didn't say but vibration from the front or felt from the seat? Steering wheel is front out of balance, seat is rear tires out.
Old Oct 3, 2013 | 10:11 PM
DeathMetal's Avatar
Fearless DIY Guy
Check your control arm bushings. These fail after 60k or so. Not sometimes, but always. It's a known design flaw that Acura has refused to address. Turn the wheel, jack the car up on the side turned in, and raise the car. You'll be able to see the bushing in its free state.
Old Oct 3, 2013 | 10:40 PM
nfnsquared's Avatar
What Turbonut said...
Old Oct 3, 2013 | 11:38 PM
v8killaz's Avatar
first check
control arm bushings. common problem mine is vibrating at 80mpg also and I have bad bushings im replacing now.
then check all the ball joints bushing under the car and suspension areas. easy to check visually and physically with big pry bar. if anything is loose its probably bad.
after that get the wheels checked for balance
Old Oct 4, 2013 | 12:45 AM
kibbles906's Avatar
most likely you have bend in your wheel...even alittle bend can cause it to shake. take it to tire shop and have it balanced and see if its wobbling...if the rim is okay then mess with your suspension
Old Oct 5, 2013 | 09:28 AM
Acura_Swag's Avatar
from the front sir. its mostly on the steering wheel not so much the seats anymore after I replaced the inner and outter tie rods
I pulled out both lower control arms from the front and replaced the bushings both when I replace the tie rods so that's done with aswell
Originally Posted by v8killaz
first check
I think it might be one of my wheels that is bent somewhere, ofcourse when my girl takes my car idk how many potholes she runs into
yea im going to have to have my wheels checked out to see if they bent or not then ill see my next step after that
Acura_Swag's Avatar
thanks guys I appreciate ya'll
Old Oct 5, 2013 | 09:36 AM
Ccvn0's Avatar
Have you ever got in accident? If you do you need to replace the front sub-fame
Old Oct 5, 2013 | 12:16 PM
Fadi81's Avatar
that's related to tires, mostly front, check tire balance and wear
Old Oct 5, 2013 | 12:33 PM
Undying Dreams's Avatar
Axles? Are you lowered any?
I just had my axles replaced and it cured the 20 mph shudder I had and it no longer vibrates at 55 like it used to.
Old Oct 6, 2013 | 09:23 PM
Cruz38's Avatar
I heck your wheels..warped wheels will do what you describe.
Old Oct 6, 2013 | 10:07 PM
flyromeo3's Avatar
His g/f drives the car too. If she drives like my wife.
It's going to be a bent rim.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
emailnatec
29
Sep 28, 2018 04:27 PM
joflewbyu2
Oct 8, 2015 11:16 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
