Project Blown TL Type S is underway
So, i am new to acura forums, and never thought i would be on one....... But i am here......
I just want to clear some things up
the ecu was never reflashed. The hardest part about this install was getting any info on the ecu.
S_heng_62 car works with the ct engineeering acm.
I will put any ones kit in.
Wow man, congrats on this. It's people who have the balls and teh drive to go out on a limb and do something fresh that really make these forums great and expand the true potential of our cars. Kudos!
When i first put a turbo on my mazda, i had to do a lot of fabing. I dont think the type s is capable of getting a turbo, the manifold position, and motor spacing would make connecting the 2 turbos impossible. I dont think that motor could really handle high boost either. Whats the compression 11:1 you would need to also add extra injectors, or completely overhaul the fuel system to crank up the pressure. It would be fun to try if money was no object.
So I'm assuming you have ran it on a dyno? Only reason I say that is because you seem to be willing to drive it so I'm guessing the AFR is looking good? Or you have a wideband?
you mean 5k SO FAR lol. i'd say a good 6k-6.5k after its said and done.
first off, congrats on being a pioneer and getting this done. i had no doubt in my mind that this was a direct bolt on.
let me give you some good advice though. you've gone this far with the project, dont be stupid and post some drive by WOT videos until you either install a wideband (which should have been the first thing on your budget list) or get it on a dyno to see where you a/f stands. no way, no how, is that ACM POS compech provides is going to give you the right tuning for the 3.5. i think it was a big waste of your time to even wire the damn thing up IMO. be smart and have boomslang make you a custom harness, install a AEM fi/c and get a proper tune before you blow that thing up.
how is boomslang? how can i contact him? AEM wanted nothing to do with this build. guys at Haltec were a massive help. i would love to get a pin out on the ECU. I tried every were, that is the big mystery on this car. only way I got the pin out was wire by wire. I am sure S_heng would get a standalone. PLEASE HELP ME MEET BOOMSLANG
so, went for a ride in this best of a car today...... HFS was that thing fast!!!!!!!! when I got out, all i could smell was burning rubber!!!!
XLR8- Do you have a Dyno? can we get this machine Dyno'd on Sunday?
http://www.helminc.com
$120 for Electrical Service Manual
Part #: 61SEP04EL
The ECU pin out is no secret.
I recommend getting the service manual too... but then I thought both of these items would be pretty standard for someone doing this kind of work.
Part #: 61SEP04EL
ask for rustin. he will be glad to help you out
the fi/c will work
Originally Posted by Excelerate
Boomslang will make one. I have already talked to them. I just need to get 5 made on the initial order.
would it not be way more cost effective to run an extra injector set up? I mean lets face it, its only 6-7 pounds of boost after pulley upgrades. the 3.5 is more then capable of adjusting timing to limit knocking, so the only real issue would be fuel? fuel system options are very limited for the type s. it is different then the non type s, I am assuming for the larger displacement..... so, if I am only worried about running lean, doesnt this seam like the cheapest fix. the AEM, is still going to need to use the same stock FPR so, I still have the same problem. crushing the FPR gives you an extra 10 pounds of flow, or does it?
You need the factory (Acura) electrical & service manuals, the type-s and base should be in the same manual, with the type-s differences being distinguished. Like "Clean" said it should be no mystery to find the pinouts for the ecu...
damnt... i was in the new london CT area yesterday, shoulda stopped by
subsonicman.. u mentioned the stock FPR.... when you install the blower, didnt you use the comptech FPR crush tool to increase the flow?
alot of people with CLs/2G TLs used the walbro 255
Right... usually Helm/Acura put the base/type s/auto/manual all into one book.
badass bro..makes me wanna go buy a TL-S and supercharge it
