hardwiring radar detector
Old Jul 14, 2010 | 06:21 PM
raf1919's Avatar
i want to hardwire my radar detector and i thought about wiring it to the center console. it does not some to pull off easily is there way to do it?
also i'm open to suggestions where you wired your radar detector.
Old Jul 14, 2010 | 08:56 PM
shadowkahn's Avatar
I usually splice into the cigarette lighter wires, since I never use the cigarette lighter for anything anyway. Haven't done that in my TL, because I long ago determined that radar detectors are pretty much pointless, but I had it that way in a Grand Cherokee, and 2 CRX's.
Old Jul 14, 2010 | 11:29 PM
AMUA6's Avatar
ScoobyZINE
+1, wire it into your window lock switch. IDR what fuse it is, but it's in the kick panel fuse box. That way you can shut it on or off by using the window lock switch.
Old Jul 21, 2010 | 05:10 PM
JORTS's Avatar
i am looking to hardwire my radar dectector as well....
search the forums...you can hardwire it to the powercords above the dom lights...i am looking at doing this as well....
https://acurazine.com/forums/showthr...ighlight=radar
http://www.invisicord.com/
Old Jul 22, 2010 | 09:26 AM
flyromeo3's Avatar
and before anyone comments that it doesnt work because of its location is WRONG.
here's where I mounted mine
right above the rear view mirror
Old Jul 22, 2010 | 05:48 PM
JORTS's Avatar
can you tell us how your hardwired it? did you use a hardwire kit?
Old Jul 22, 2010 | 07:54 PM
flyromeo3's Avatar
i used the hardwire kit.
I tapped fuse #32 ( i know it was an empty slot ) and wired that as the 12v trigger for a relay.
From that relay I power on my amp, crossover, GPS, and radar.
Relay obtains 12v constant from battery.
I routed the wires up the drivers side A pillar through the headliner to the radar.
Old Jul 24, 2010 | 09:41 AM
blacktsx05's Avatar
2011 M37x
looks good same place where mine is mounted
Old Jul 25, 2010 | 10:14 AM
raf1919's Avatar
ok got mine done last night. bought a kit on ebay for 7 bucks. have it to the left of the mirror right at the tint line. came out really good and love this location. makes it very easy to take off or turn down volume. last car i had it low and always had to reach for it.
took like 10min to do. hardest part was trying to find a ground for the wire its plastic everywhere.
Old Jul 25, 2010 | 10:15 AM
raf1919's Avatar
oh i should add. i tapped the rear passenger window fuse. this way you can power it on off w/ the windows lock button kinda nice when driving through city and it gets annoying just quick off switch.
ITSJESTER
17
Dec 6, 2018 02:29 AM
chrisr
Dec 4, 2015 02:17 AM
ITSJESTER
4G TL Photograph Gallery
Oct 13, 2015 12:53 PM
sockr1
Oct 1, 2015 01:31 AM
deyainrdy4ds
Sep 22, 2015 10:15 AM
