Cell phone pairing
Cell phone pairing
Hi, my mother has a TL 2008 w/tech package and an iPhone 6 running iOS 12.2.
Until recently she had no problem using her phone in the car. Now, not only the phone disappeared, but I cannot even find the options to pair it again.
She took the car to an Acura dealer and they could not figure it out. They said "the car is too old to pair with an iPhone"...
Any advice on how to make it work again?
FWIW, my 2005 HFL stopped pairing with my iPhone SE when it moved to iOS 11.XX from 10.XX. I'm on iOS 12.2 now.
Either my HFL is defective or it doesn't pair to iOS 11+.
See directions in https://acurazine.com/forums/3g-tl-a.../#post13460854
Unplug the HFL connector, then reinstall in reverse order from disassembly.
Should take less than 5 minutes if you have the pry tool for the sunroof switch(I used a thin feeler gauge blade) and 8mm ratchet with you in the car.
I have problem with android. The strange thing is my phone paired when i had android 6.x. Since I updated it to 7.0 the car does not detect the phone.
Google says it is common and not dependent on phone or car mark.
georgejohn
07-28-2017 10:15 PM
BluNosr2
01-15-2012 07:57 PM
Jesstzn
19
07-03-2008 05:28 PM
DreamRDX
11-04-2007 09:48 PM
