Cell phone pairing
Hi, my mother has a TL 2008 w/tech package and an iPhone 6 running iOS 12.2.
Until recently she had no problem using her phone in the car. Now, not only the phone disappeared, but I cannot even find the options to pair it again. She took the car to an Acura dealer and they could not figure it out. They said "the car is too old to pair with an iPhone"... Any advice on how to make it work again? |
whoever told you its too old... that person is full of shit.
Press the HFL button and say "option" then follow by "paring" (I am assuming your mother HFL still working like it should be) |
Of course it is BS.
Is the HFL the only way to access phone pairing? Is there a button combination I could follow? |
Originally Posted by Lalin
(Post 16421871)
Of course it is BS.
Is the HFL the only way to access phone pairing? Is there a button combination I could follow? FWIW, my 2005 HFL stopped pairing with my iPhone SE when it moved to iOS 11.XX from 10.XX. I'm on iOS 12.2 now. Either my HFL is defective or it doesn't pair to iOS 11+. |
(Post 16421860)
(Post 16423010)
The HFL works terribly and I cannot even get past "option"...
honestly, you probably want to disconnect the HFL before it starts draining your battery.
Also ... that iPhone is older than the car lol that dealer is tripping |
How do you disconnect the HFL
Originally Posted by Sthomasson72
(Post 16435387)
Unplug the HFL connector, then reinstall in reverse order from disassembly. Should take less than 5 minutes if you have the pry tool for the sunroof switch(I used a thin feeler gauge blade) and 8mm ratchet with you in the car. |
Curious to note the only people having pairing problems all have iPhones, hmmm.......................
We Samsung Galaxy owners have no problems pairing. :biggrin: . . |
I have problem with android. The strange thing is my phone paired when i had android 6.x. Since I updated it to 7.0 the car does not detect the phone.
Google says it is common and not dependent on phone or car mark. |
I'm on Android 9, Samsung Galaxy S8. No problems.
S7, no problems here.
S6, no dice connecting.
Google says the problem occurs when the android is upgraded on phone.
