Pairing cell phone to RDX...
Old Nov 4, 2007 | 06:30 PM
DreamRDX's Avatar
AWD + Turbo = FTW
Just picked up a used 07 RDX and we are trying to figure out how to get our bluetooth cell phones to pair with the car. We are missing the cars manual and cant make it back to the dealer for a few days. Can anybody help?
Old Nov 4, 2007 | 07:57 PM
jakas's Avatar
You can buy the owners manual and service manuals here :-
http://www.helminc.com/helm/Result.a...T71TWTB5M93T6D
Instructions to pair the cell phone :-
1. With your phone on and the ignition in the ACCESSORY (I) or ON (II) position, press and release the Talk button. After the beep, say "Phone set up". The HFL response is "Phone setup options are status, pair, edit, delete, and list"
2. Press and release the Talk button. After the beep, say "Pair". The HFL response is "the pairing process requires operation of your mobile phone. For safety, only perform this function while the vehcle is stopped. State a four-digit code for pairing. Note this code. It will be requested by the phone."
3. Press and release the Talk button. After the beep, say the four-digit code you want to use. For example say "1,2,3,4". The HFL response is "1,2,3,4. Is this correct?"
4. Press and release the Talk button. After the beep, say "Yes". The HFL response is "Searching for a bluetooth phone. Make sure the phone you are trying to pair is in Discovery mode"
5. Follow the prompts on your phone to get it into Discovery mode. The phone will search for the HFL. When it comes up, select HandsFreeLink from the list of options displayed on your phone.
6. When asked by the phone, enter the four-digit code from step 3 into your phone. The HFL response is "A new phone has been found. What would you like to name this phone?"
7. Press and release the Talk button. After the beep, say the name you want to use. For example, say "Eric's phone". The HFL response is "Eric's phone has been successfully paired, Returning to the main menu"
Enjoy !!!
Old Nov 4, 2007 | 09:35 PM
sasair's Avatar
Or you can download the owners manuals here:
https://acurazine.com/forums/showthread.php?t=218
Old Nov 4, 2007 | 09:48 PM
DreamRDX's Avatar
AWD + Turbo = FTW
Thank you so much guys!!!!!
mlody
Dec 4, 2019 02:11 PM
ExcelerateRep
Oct 14, 2015 08:20 AM
RadiantCycles
ZDX
Sep 26, 2015 09:18 PM
ivan06106
Sep 26, 2015 04:38 PM
