Removing interior panel...?
Old Mar 18, 2010 | 10:13 AM
Crestwood1001's Avatar
I mounted my radar detector at the top of my windsheild, to hide the wire better I wanna take off the panel thats on the left side of the windsheild, it has the little square on it that says something about the airbag, I think its called the A-Pillar? Does anyone know how I can take it off....
Old Mar 18, 2010 | 10:19 AM
Bearcat94's Avatar
AZ Community Team
Have you checked the garage for service manual scans?
https://acurazine.com/forums/3g-tl-2004-2008-93/3g-tl-garage-faq-3g-tl-newbies-553554/
Regards the Square. That is to inform you that there is an airbag in that area. It also acts as one of the clips for the pillar. Use a small screw driver to get under that tab. Once it's out a little bit, give it a steady pull. It need to come out about 3/4 inch or so to unclip - if it comes all the way out, thats OK too.
From there, oyu probably just gently work the edges of the pillar loose, but I don't know exactly where all the clips are.
Old Mar 18, 2010 | 10:24 AM
Yea I dont need to take it off the car, just get enough of a gap to tuck the wire in there
Old Mar 18, 2010 | 10:26 AM
Bearcat94's Avatar
AZ Community Team
Oh. Just use a credit card or something like that (thin, not sharp) and wedge the cord in a little at a time as you go along.
It won't bother the airbag any; it's done all the time with stereo, radar detector, GPS, etc installs.
nfnsquared's Avatar
There's one more clip about 2/3 down the pillar. It will come out with gentle pulling. The pillar is very easy to remove and replace.
Old Mar 18, 2010 | 10:28 AM
Izzy-Type-S's Avatar
WOT in the new ATLP V2s!
I'm about to get the new Passport & I hate the wire hanging down getting in the way of controls & Nav, better revisit this thread.
Old Mar 18, 2010 | 10:31 AM
TeknoKing's Avatar
See this page https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/v1-install-552627/
Old Mar 18, 2010 | 10:32 AM
nfnsquared's Avatar
Why not hardwire the detector from the overhead console wiring using the invisicord?
http://www.invisicord.com
See this thread:
https://acurazine.com/forums/3g-tl-2004-2008-93/radar-detector-location-766554/
Old Mar 18, 2010 | 10:37 AM
I made my own power wire, did it all coustom so I would have the right length, I tapped into the fuse box and will run it up the pillar, ill post pics when I get home and do it
Old Mar 18, 2010 | 03:12 PM
Done, super easy, just pop the tab out and pull on it, comes right out, couldnt have been easier
oo7spy
Jun 19, 2023 12:48 AM
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
BoricuaTL
Apr 8, 2016 01:08 PM
james357
Feb 13, 2016 02:37 PM
