Power Mirrors
Old Jul 20, 2024 | 10:16 AM
hey's Avatar
hey
7th Gear
Power Mirrors
My power mirror switch went bad to where the mirrors randomly click up towards the sky whenever im driving. Is there an easy way to disconnect them?
Old Jul 20, 2024 | 12:26 PM
GhostTL09's Avatar
it's not the switch. You have to take the glass off, clean the actuator, re-grease and move the mirrors around in different position points to work it in and it will move quietly and fluidly again.
The problem is getting the glass off as to not crack the mirror. There is a thread that shows the appropriate pressure points to mitigate breakage.
Old Jul 20, 2024 | 12:40 PM
hey's Avatar
hey
7th Gear
Will that fix them moving on their own as well?
Old Jul 20, 2024 | 01:05 PM
csmeance's Avatar
it might, or you can spend $50 and get new actuators from acura and swap them out and the mirrors will work perfectly again. The motor binds and the computer thinks the mirror is not in the right position thus causing movement.
Old Jul 22, 2024 | 04:45 PM
GeoffJr's Avatar
9th Gear
Search for this thread:
3G mirror repair with pictures!! 3G Garage #E-045
Full URL:
https://acurazine.com/forums/3g-tl-p...-045-a-832020/
Just what I need to do to my 3G TL. Has plenty of photos, too!
Old Jul 23, 2024 | 05:01 PM
VictorTL's Avatar
I cleaned and lubed mines today and no more sticking. Move smooth as silk.
Old Jul 23, 2024 | 09:56 PM
Cthulhuy's Avatar
What lubricant did you use for the actuators? I have plenty of silicone spray, but I typically use that for any kind of liner.
Old Jul 24, 2024 | 11:02 AM
VictorTL's Avatar
Old Jul 24, 2024 | 12:20 PM
Adobeman's Avatar
The DVD-A Script Guy
I'd prefer Shin Etsu Silicon grease over lithium based formulas for applications on plastic. I bought a tube many, many, years ago to do the same job on my mirrors. Works great on all manner of things in the car especially keeping weather seals supple. Also keeps them from getting stuck to the door jams in wet/freezing conditions if you are in a cold climate. It's available on Amazon and one tube is a lifetime supply. But you are prob fine with what VictorTL pointed out. I think you will just get more uses out of the Shin Etsu.
ref:https://acurazine.com/forums/3g-tl-p...hiznit-745587/
Old Jul 26, 2024 | 09:31 AM
Jackass's Avatar
Also note, if the mirror is constantly wondering around doing odd things, it probably isn't the gear/lube issue. It is probably worn or dirty contacts. If it gets stuck and clicks, that is the gear/lube issue. I have had both issues at different times over the years.
As others have said, taking it apart, cleaning and adding a light coat of grease to the moving parts does have a good chance to buy you some time. I did that a couple of times on mine and finally that stopped helping and my mirrors just moved to the wrong spot on a regular basis. That was the electrical contacts being worn/dirty. I ended up buying new units and putting them in, which was the final and best solution overall. The parts are readily available, either via online or your local Honda dealer. Pretty sure there are a couple of threads that clearly identify the current part number since the original one is discontinued. The same one fits both sides.
https://acurazine.com/forums/3g-tl-p...tching-966482/
https://acurazine.com/forums/3g-tl-2...tinued-803996/
https://acurazine.com/forums/3g-tl-p...t-save-971394/
x Hades Stamps
Feb 8, 2022 01:46 PM
dmjh216
Nov 3, 2018 02:27 AM
Aztecf
ZDX
Feb 16, 2017 04:54 PM
DMZ
Mar 19, 2010 09:43 PM
