Mirrors going down in reverse glitching
Old Jan 24, 2018 | 04:17 PM
Hanoke's Avatar
Hi everyone,
I understand the mirror selector decides which mirror goes down, but my problem is once I select a side, it looks like the mirror glitches, and doesnt go fully down, it goes a bit down, that moves up and down quickly? I still have to manually move it down with the selector if I wanna see the driveway.
If someone knows if this is a fuse issue? Or maybe a part that needs to be replaced? Other than in reverse, the power mirrors work fine.
-new to the forum
Old Jan 24, 2018 | 04:18 PM
very common,
post here:
https://acurazine.com/forums/3g-tl-p...-045-a-832020/
Old Jan 24, 2018 | 04:20 PM
Hanoke's Avatar
Thanks, ill check it out!
Old Jan 25, 2018 | 07:44 PM
WDPanda's Avatar
Very easy repair, if you don't break the mirror
Old Jan 25, 2018 | 10:51 PM
Hanoke's Avatar
ya thats what im worried about, but i think ill try it. Any tips? I feel like i wont know how much pressure it can take when i pry it off
Old Jan 26, 2018 | 02:04 PM
USNA93's Avatar
Don't use a screw driver! Invest a few bucks in a plastic pry tool and you'll be much safer. I've done the lubrication fix many times. There will likely be a point where your side mirrors just start doing their own thing; my passenger side mirror will all of a sudden move completely inward when I'm driving down the freeway. It will even move when I don't have that mirror selected on the controller. But right now, I don't feel like spending the $75 for a new actuator motor to fix it since I can still control it.
Old Jan 29, 2018 | 08:47 AM
Jackass's Avatar
This is pretty much where mine are at now. I have taken mine apart for cleaning which helped for a while. But they are doing odd things more often now. I think the original stuttering is related to the grease while the new oddness is related to the electrical connections aging out. My boots are torn as well which I know will limit the lifespan of the mechanicals. Some day I will purchase new assemblies as well......
To note, I agree the plastic tools are better...but I did just use a long screwdriver wrapped in a shop towel with no issues. It is nerve racking the first time since you think you are going to break a mirror. So just make sure you are ready to pay for a replacement and try it. If you succeed, great!! If not, you have a new mirror with new mechanicals. Win-win in my book.
Old Jan 29, 2018 | 11:45 PM
WDPanda's Avatar
Stay away from any browned areas of mirror if you have that. They tend to be weak spots.
Old Jan 31, 2018 | 01:52 AM
Waffeey's Avatar
Broke my driver side actuator when i reinstalled it after lubing it up, tried everything and it still cracked the plastic arms inside... My memory seat postions completely stopped working around the same time i believe they are in series with the mirror actuator.
GUNMETAL-TSX
2G TSX Problems & Fixes
Jul 25, 2008 06:27 PM
yuhoo22
Aug 22, 2007 05:41 AM
mohfoe22
1G TSX Problems & Fixes
Feb 24, 2006 12:08 PM
morninglight
Dec 15, 2005 10:52 AM
nycvr6
Jun 22, 2001 08:49 PM
