Key Fob Programming Question
Old Jul 16, 2024 | 08:02 PM
domano 68's Avatar
Do you have to have at least one key fob that works correctly to program additional fobs? And if so do you have to reprogram all fobs (including current one)? Or do you just have to program new fob(s)? Thanks in advance. 08 TL
Old Jul 16, 2024 | 08:43 PM
VictorTL's Avatar
Here is very simple DIY
https://m.youtube.com/watch?si=mZ5FO...ature=youtu.be
Old Jul 18, 2024 | 03:56 PM
domano 68's Avatar
The video author states "for interest of this video, I disabled both my remotes". So this does not answer my questions. Can anyone help please?
Old Jul 18, 2024 | 05:51 PM
csmeance's Avatar
You program only the new FOB (unlock/lock/trunk), the old one will work fine. It will not program the immobilizer, you'll need a locksmith/dealer for that.
Old Jul 18, 2024 | 05:59 PM
domano 68's Avatar
Thanks for the input. But what is the immobilizer please? I assumed programming the new fob by turning off on clicking lock 4 times would fully program the fob, not just partially program it. How do you fully program a fob to lock, unlock, trunk and START?
Old Jul 18, 2024 | 07:25 PM
VictorTL's Avatar
The answer is in the video I posted.
Old Jul 18, 2024 | 07:37 PM
domano 68's Avatar
Nope
Old Jul 18, 2024 | 08:52 PM
csmeance's Avatar
it's a little chip inside the new key that needs to be paired with the car via a computer. Locksmiths have the scan tool and so does the dealer to program it.
see pics of chip in keyfob here:
https://acurazine.com/forums/3g-tl-2...-loose-906731/
go to a honda dealer, they are normally cheaper and may charge 30 mins of labor.
Old Jul 18, 2024 | 10:44 PM
VictorTL's Avatar
Nope
Then the dealer will have a solution for you. Good luck!
Old Jul 18, 2024 | 10:48 PM
VictorTL's Avatar
I bought a few key fobs from eBay for my tl and MDX and the video I posted work like a charm.
I can use to lock unlocked and START!
Old Jul 27, 2024 | 11:11 PM
mav83's Avatar
I'm going through the same process to replace a lost key. Do you know if the currently available NXP transponder HT2DC20S2OR is the same Part# (or compatible) with 3G TLs. This one is 256 bits.
Old Jul 29, 2024 | 10:37 AM
VictorTL's Avatar
That YouTube is your answer. Good luck
mdb007
Nov 13, 2018 03:49 PM
Moses08tl
Mar 8, 2011 02:45 PM
tbone1970
Jul 22, 2009 08:01 PM
sol_da_man
Sep 4, 2007 05:33 PM
repotl
Oct 23, 2006 06:14 AM
