O2 Sensor Reading from Autozone
Old Dec 7, 2008 | 01:10 PM
Burghman81's Avatar
So my engine light was on and I went to Autozone and checked it with their scanner. I got the message code that the O2 sensor was triggering it. However, before I unplugged the machine, the engine light went off.
Did the light go off simply because I read the code, or is the car alright now? When I bring it to the dealer, will the code show again? I ask because they charge $125 if they scan and nothing is wrong.
Old Dec 7, 2008 | 01:51 PM
BradE's Avatar
Autozone might have cleared it when they read it. Give it a few days and see if it comes back.
Old Dec 7, 2008 | 04:51 PM
Riga89's Avatar
B A N N E D
X2
Just wait a couple of days to see if it will come back on. Most likely it will, those kind of things don't go away by themselves. You may not even need to bring the car to the dealer for such a simple fix.
Old Dec 7, 2008 | 05:06 PM
TL1999's Avatar
GO DAWGS!! SICK'EM!!
what dealer is this charging $125 to just scan your car?? I never heard this.
Old Dec 7, 2008 | 06:12 PM
stillhere153's Avatar
94 DC4 RS LSV/Turbo
Do not go to the dealer until the light comes on
Ps. Emissions has a completely different warranty from all the other parts so it is covered under warranty
Old Dec 7, 2008 | 06:38 PM
Burghman81's Avatar
Really, it is a separate warranty?
Why wait for it to come back? What if it doesn't this week? I don't have time to just wait for the light to come back on. Can't I just tell them I brought it to autozone and it cleared after?
The $125 thing is only if they scan it and nothing is wrong. It's because people are constantly monopolizing time at a dealership. While I think $125 is a bit ridiculous, I understand where they are coming from.
Old Dec 7, 2008 | 07:11 PM
01tl4tl's Avatar
Its called Diagnostic Fee and covers 1.5 hours for them to locate a problem and advise.
Since some people come in and want pro diagnosis, then their buddy is going to fix it,,, they should be paid for the time!
Emission warranty is 8/80 depending on what part, but anything in the first 4-5 years that would cause it to fail smog- a check light would be that- its covered by warranty
Azone didnt clear the codes intentionally, and they are stored in the memory unless you disconnect the battery or reset the ECU
Get to the dealer
Old Dec 7, 2008 | 07:47 PM
CarrieLynn's Avatar
OP - it may be bad gas...also are you using premium gas? This happend to me when I first bought my car, I was like f it im not using premium, sure enough check engine light came on. I want to auto zone...same code. I left it on till I ran all the gas out and filled it with premium, reset code it has not been back on since, now I only use premium g/l
Old Dec 7, 2008 | 08:10 PM
Burghman81's Avatar
I've never put anything in it but premium.
I have an appointment for Friday. Just didn't want them to be like "the light is off now...."
Old Dec 7, 2008 | 09:39 PM
BLACKURA_NY's Avatar
I have car ADD
^ my TL-S throws Engine codes ALL THE TIME in the winter... for BANK 1 TOO LEAN or BANK 2 TOO LEAN..... ive come to the conclusion that its the winter fuel mix gas stations sometimes use... it only happens in the winter.... and the light goes away in a few hours everytime... car performs 100% fine
Old Dec 8, 2008 | 12:54 AM
dechlin's Avatar
Never go to Autozone. Those people have no idea!!
Old Dec 8, 2008 | 07:26 AM
Burghman81's Avatar
I didn't have autozone do anything.....
I used their scanner and got the code. It's not rocket science haha. You plug in the machine, it gives a code. What I'm saying is before I unplugged the machine, the engine light went off.
I was just trying to figure out if I should still go to the dealer or if the problem is solved. I am going to go to the dealer. I just wanted to make sure they will still be able to find the code when the light is now off.
Old Dec 8, 2008 | 10:13 AM
01tl4tl's Avatar
resetting a check light does not fix any problems~~~
Old Mar 1, 2009 | 09:56 PM
lost's Avatar
9th Gear
I called my local Acura dealership and they said the o2 sensor is not covered under the 8/80k emissions warranty because its a wearable item like brakes, are you guys getting different answers from your dealers?
My car has 63k and my buddy at a Honda dealership ran the code for me and he also said it should be covered under Acura warranty.
Old Mar 2, 2009 | 04:34 AM
Rob RiL's Avatar
Unregistered User
O2 sensors are considered wearable like spark plugs.
The dealer should NOT cover them at 62K.
Maybe something strange like at 22K....which could be just the end result of a larger problem.
If I were you, I'd replace the sensor and do some sort of fuel injection cleaning (there's a DIY) somewhere on this forum. If that doesn't fix it, take it back.
4drviper
Apr 23, 2025 07:13 PM
johnalfa
Nov 5, 2015 06:44 PM
RobbDizzle
Oct 15, 2015 11:16 AM
jpadilla
3G RLX (2013+)
Sep 27, 2015 07:53 PM
