I have installed a type-S spoiler on my 05 TL
#202
Originally Posted by leedogg
More pics please esp side views and full car views, the temptation is growing
Pictures of the entire car will come shortly in the next couple of days. Keep a look out in the Photograph Gallery.
#203
#204
07 Type-S spoiler
I just bought one for $130.00. I should be getting it installed in a few weeks. Wow, it's amazing what you can find if you look hard enough.
Thanks for the info. Keep it coming!!!
#205
I finished taping (yes, no bolts or holes) my Type S spoiler on my 07 TL.
Here's some comparison shots of the real deal on a WDP Type S to mine:
Real:
Mine:
Real:
Mine:
And a bunch of others of mine:
I even used the paint can method
I think it's stuck on pretty good. I don't think it will last forever, but I think it will last as long as I own the car. And I figure worst case scenario is if it gets loose I bolt it on, as I saved the two bolts.
boxstock
Real:
Mine:
Real:
Mine:
boxstock
#207
Argggggggg!
Still waiting on mine. got it from the dealer last week, but.......
I have Anthracite so i had to spend another $100 to get it repainted in my color. It really SUCKS that they discontinued it in 07.
I plan to use tape & C-Clamps to install mine. will post pics if it ever comes back from the body shop.
#210
Originally Posted by pinina
I put mine on this evening using the 3M tape & the paint cans. I'm letting it sit over night.
boxstock
#211
Originally Posted by terminex
Got it back from the body shop Thursday & put it on about 10 Min after I got home.
I BELIEVE I have the first Antracite TL-S lip spoiler. It is beautiful
boxstock
#213
my corners popped up. either because i did it in the freezing cold or cause Pep Boys was out of 3M so I got Magic Mounts. it looks the same. anyway I peeled it off again, i'll try once more. maybe I need to have 3 layers of tape in some parts.
it looks so good
it looks so good
#215
Any bodyshop could probably install the spoiler for a $100 or less. The body shop I take my cars too is that way. It doesn't take that long for them to install it either. If someone already mentioned, sorry for reposting. BTW, those spoilers look really nice.
#216
Kaa - Ching !!!
From: Rhode Island.....Self-Proclaimed Chromed Cousin of Brettallica
Originally Posted by boxstock
mine is starting to lift on the left side w/ the tape only method.
boxstock
boxstock
Mine too - maybe that's why they supply 7 clips with it?.....LOL. I'm going to remove it once it gets nicer out and add two additional clips to the ends only. Once done I'll have 4 holes in the trunk lip but at least it will be secure.
#217
#221
The tape method is fine. Just make sure you've prepped the area, install it at a "normal" temperature (not extremely cold), and strategically place enough tape where you will need it (near the edges for instance).
The 3M tape is very strong and I think the issues with it is more or less concerning gaps.
#223
okay, thanks for the help guys, i'll work on it once the weather gets nicer, can't wait and thanks for all the information in this thread. I've never worked on the car before until,.,well meeting u guys. haha
#226
Kaa - Ching !!!
It bothers me that 'this' thread is the 07 spoiler thread. The original post is so unworthy.
#227
it looks so good
it looks so good
#228
I was looking on here a couple months ago and there was a thread with a bunch of pictures that someone posted of how they taped their lip spoiler. It was a black TL and I remember a bunch of red tape... Now I can't find it for the life of me!! Does anyone know where it is?? Thanks!!
#229
I wonder if it was on page 7 in this thread. Some dude posted some pics there.
#230
Originally Posted by Crook
Hmmmmm,
#231
I noticed some slight lifting on the ends of the spoiler where I could have used a little more 3m tape. Only about 1 or 2 millimeter gap but the spoiler isn't at risk of coming off.
I would now suggest using extra 3m tape along the entire edge of the spoiler at both ends.
To the people who already installed theirs following my posts, I apologize. I wish I would have found out about this earlier.
#232
boxstock
#234
the 2ndtime, I put more tape on. Plus I put another strip right along the inner edge of the rubber strip. it needs 3 layers by the parts in between where the clips/bolts were meant to go. the corners are the tricky part because there isn't enough of a flat surface to work with, so it will stick to the trunk very well, but the other side loses grip. it still wasn't too easy to rip pff the 1st time so, don't worry about it flying off
#236
Kaa - Ching !!!
I did the two bolt method and mine is lifting on the edges too - I'm going back to add the two clips to the ends of the spoiler - so that woudl equal 4 small holes when all is said and done.
No wonder they give you 7 clips to install this sucker.
By adding the two end clips I think that will solve my lifting issue for good.......no problem for me drilling into the trunk as I don't ever plan on taking the spoiler off.
#237
How many holes are you suppose to drill if you want to install it on the trunk the real way it was meant to be installed from factory? Basically how is it installed on the TYPE S?
#238
Kaa - Ching !!!
Post #88 Page 4
2 Bolts
2 Plastic Plugs (Teal Blue in the pic)
3 Plastic Clips (White in the pic)
The two end ones should take care of the lifting
2 Bolts
#239
I did the two bolt method and mine is lifting on the edges also...I ordered 4 more bolts = 6 bolts holding down the lip, except for the middle opening (not using any of the clips that it came with). I know I have to slightly modify the clip open for the bolt. The parts # for the bolt, TAILGATE SPOILER is 71703-S6M-003 ...$1.77 each. I have not received it yet, still waiting for it. Once I put it on I will tell you how good the fit and finish is, using 6 bolts.
#240
Kaa - Ching !!!
Before you go modding your spoiler for the added 4 bolts make sure you have enough clearance inside the trunk to add the nuts!
It was kinda tight in there and I have a funny feeling you won't be able to bolt up.
