ABS Light Code 11-01 and 13-01 and Ebrake light
Old Feb 3, 2024 | 02:06 PM
MRTL06's Avatar
Vtec Powaa
Hi this is my first post so please excuse me if I make any mistakes, I have a abs Light on for 11 - 01 1. LEFT REAR WHEEL SPEED SENSOR SIGNAL ERROR 2. RIGHT FRONT WHEEL SPEED SENSOR OPEN OR SHORT 3. Low/high IG1- terminal. and 13 - 01 1. LF Tire Low air Pressure 2. MOTOR VOLTAGE MALFUNCTION 2 3. A problem with the average of voltage for torque sensor VS1 and VS2 4. Tire2 Low.
And the emergency brake light wont turn off after putting the hand brake down
Any help would be most appreciated
Old Feb 3, 2024 | 08:01 PM
Pair of TLs's Avatar
What year and model is your vehicle? Can we assume an 06 TL 5AT?
What's your battery condition?
Put air in your LF tire. Also, Tire2.
Old Feb 3, 2024 | 08:07 PM
MRTL06's Avatar
Vtec Powaa
2006 Acura TL
I put air in both and then the U with the ! in the middle stays on and then after a couple minuts of driving it says Fault with TPMS system
Old Feb 3, 2024 | 08:09 PM
2006 Acura TL
Your TPMS wheel sensors could be worn out of they are original.
Old Feb 3, 2024 | 08:17 PM
MRTL06's Avatar
Vtec Powaa
They were replaced with my new custom rims that resemble the R129 AMG rims
Old Feb 3, 2024 | 10:21 PM
Is that when the problem started?
Old Feb 4, 2024 | 12:03 AM
MRTL06's Avatar
Vtec Powaa
No No, Much later, maybe 2 weeks ago.
Old Feb 4, 2024 | 12:15 AM
Try a new battery.
Old Feb 4, 2024 | 12:19 AM
MRTL06's Avatar
Vtec Powaa
Battery is 2 months old
Old Feb 4, 2024 | 01:23 AM
Have it load tested. Age means nothing.
Old Feb 5, 2024 | 06:42 PM
MRTL06's Avatar
Vtec Powaa
Battery is good.
Old Feb 5, 2024 | 07:22 PM
Cthulhuy's Avatar
Have you disconnected your ABS's main connector to the modulator and inspect for brake fluid leakage? I has a similar problem recently with random ABS DTCs starting to pop up. I found the ABS module had fluid leaking internally and caused shorting.
Old Feb 5, 2024 | 07:31 PM
MRTL06's Avatar
Vtec Powaa
Where would that be located?
Old Feb 5, 2024 | 07:38 PM
Cthulhuy's Avatar
When you open your hood, it's directly behind the power steering reservoir. You can disconnect it and inspect if there's any leakage.
Old Feb 8, 2024 | 06:25 PM
MRTL06's Avatar
Vtec Powaa
Angry
OK so, ABS module is fine and dry, I replaced the RF Speed sensor, now its giving me a 21-1 code saying Right front pulsar failure, and the RL speed sensor code is gone but now its telling me the 13-1 Left front wheel speed sensor open or short, and also figured out the ebrake light turns off after i clear the codes but then it comes back on after 2 mins of driving for the RF Pulsar
Old Feb 10, 2024 | 07:31 AM
MRTL06's Avatar
Vtec Powaa
I fixed the LF Wheel speed sensor now its only the code for the right front pulsar... any idea what it is?
Old Feb 12, 2024 | 06:44 AM
MRTL06's Avatar
Vtec Powaa
bump...
Old Feb 12, 2024 | 10:41 AM
Just throwing this out there:
Not sure, because I don't know if the picture (Honda link, #1) below is accurate, even though it shows 44014-SDA-A51 outboard joint set (which fits your 06TL, #1 on Acura link)
44014-SDA-A51 - Genuine Honda Joint Set, Outboard (hondapartsnow.com)
Driveshaft - Half Shaft - 2006 Acura TL 4 Door BASE (NAVIGATION) KA 5AT (acurapartswarehouse.com)
The 'pulsar' may be the 'toothed' outer ring on the outboard CV spline assembly (red arrow)?
Check to see if it is intact on your current passenger side axle & if it is in proximity of the wheel sensor?
Good Luck!
Old Feb 12, 2024 | 11:26 AM
MRTL06's Avatar
Vtec Powaa
[QUOTE=zeta;16926230]Just throwing this out there:
QUOTE
​​​​​​​so it’s not the wheel bearing?
Old Feb 12, 2024 | 01:44 PM
Good question, if that outboard CV ring is not present on your car, then perhaps it is?
Pull off the tire and check, or max. turn the steering wheel to one side & see if you can see it?
Old Feb 12, 2024 | 04:35 PM
MRTL06's Avatar
Vtec Powaa
Im pretty sure it migh be the wheel bearing? as thats whats used to measure speed?
Old Feb 12, 2024 | 05:30 PM
Right you are:
Magnetic encoder is at issue?
Old Feb 12, 2024 | 05:33 PM
MRTL06's Avatar
Vtec Powaa
Right you are:
Thank you very much for this diagram. Do you think it would be okay to replace the bearing with this one here:
Amazon Amazon
Old Feb 12, 2024 | 06:37 PM
Thank you very much for this diagram. Do you think it would be okay to replace the bearing with this one here: https://www.amazon.ca/gp/product/B08...?ie=UTF8&psc=1
Best choice: Full price NSK OEM $105.49.
Same best NSK bearing price cut in half from ebay.
My choice.
However, if I had to pick between your lower cost amazon bearing and the 'middle of the road' ones below from rockauto, I'd probably go with the SKF or Beck/Arnley.
Good Luck
Old Feb 12, 2024 | 06:45 PM
MRTL06's Avatar
Vtec Powaa
My choice.
Good Luck
What do you think about ACDELCO?
Old Feb 14, 2024 | 06:02 PM
sweeT n Lo's Avatar
Unless I'm looking at it incorrectly, the NSK wheel bearing is listed on Rockauto for $30.79 right above the other ones mentioned in the other screenshot.
Old Feb 14, 2024 | 06:35 PM
You are correct!
I overlooked it in may haste.
Old Feb 14, 2024 | 07:16 PM
MRTL06's Avatar
Vtec Powaa
Ordered the NSK from amazon next day delivery. Got it today, going to see if my mechanic can put it in tomorrow. So for future reference, make sure the wheel bearing has a magnet on the side?
napajcl22
Sep 16, 2009 09:58 PM
fahstah
1G RL (1996-2004)
Aug 18, 2009 10:46 AM
JoeJamin
1G CL Problems & Fixes
Apr 14, 2008 04:12 PM
blackeagle113089
1G TL (1996-1998)
Dec 26, 2006 02:41 PM
christopher g
Aug 15, 2006 11:53 AM
