ABS light on!
Old Mar 16, 2006 | 09:19 PM
christopher g's Avatar
ABS light on!
Ok first my drivers side window regulator goes this week now my ABS light is on.
This has really been a crappy week.
I did the paper clip jump and the ABS light first flashed a 18 then 17.
I looked it up and got:
17 Vehicle Speed Sensor Malfunction
18 High Pressure System
What do I need to fix or look into fixing?
Old Mar 16, 2006 | 11:27 PM
saiko_cl_duck's Avatar
is your brake fluid topped off, cause our cars are pretty sensitive. Search the forum, those codes have been covered. Might be the speed sensor.
Old Mar 17, 2006 | 12:00 AM
teh CL's Avatar
first check your brake fluid...it happened to me acouple times...
God knows how long my ABS light has been on but im doin my brakes soon so hopefully it'll fix that problem
Old Mar 17, 2006 | 12:06 AM
starboy2nv's Avatar
First EVER K24 Turbo CL
werd me too
Old Mar 17, 2006 | 01:22 AM
97Acura3.0CL's Avatar
ENGAGE MY VTEC BABY!!!!!!
call the dealer if im not mistaken I think I had mine flash a 17 and it was covered under the 150k extened warrenty that acura extened for all owners
just a thought, save some money
Old Mar 17, 2006 | 01:23 AM
I have one right now and it gives me a right front wheel sensor, and I think from my accident about 2 years ago, the sensor is now going bad and it only goes on when i hit 70+ mph on the freeway
sucks, I feel ya bro
Old Mar 17, 2006 | 02:20 AM
Outlaw's Avatar
CL smashin
I had mine on for a while and when I checked for the code, it never blinked. It's been almost a year and it just turned off like 2 weeks.
Old Jul 31, 2006 | 10:40 AM
RyeCL's Avatar
i just had a sensor replaced and my light is still going on at 70+ mph....
did you end up replacing your sensor....
im thinking maybe this one is bad too, or maybe another one is bad....
edit: by the way i know this thread is 4+ months old....
Old Jul 31, 2006 | 03:54 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
I had that problem, it was the axle needed replaced, there's a sensor that reads the axle too. I've also replaced 3 wss as well. Light still comes on
Old Aug 1, 2006 | 01:45 PM
RyeCL's Avatar
i hadnt had any problems with the ABS light before i got my brakes done (except it would occasionally come on for a second when i broke real hard) but i had the rotors replaced and new pads put on, along with new calipers. they also bled the brakes.
well i was driving it a day later when both hubs came off the rotors (because i guess it wasnt pressed on good enough) and it ended up spinning around the axle and it broke off one of the sensors. They replaced it for me and since then i have had this problem with the ABS light going off around 70mph or so. I just had the master brake cylinder replaced too because it had no pressure and didnt hold pressure when i was stopped. now my brakes are working great, i stop great, but the damn light keeps coming on after 70mph....its really pissing me off.... :angryfire guess its back to the shop. who knows maybe the other sensor is messed too.
Old Aug 1, 2006 | 02:23 PM
(Mid-Atlantic)
70 MPH light coming on is def a sensor, like i said above, mine ended up being on the axle for that one
Old Aug 1, 2006 | 03:05 PM
matH22's Avatar
i have abs light on since 2 years .. yeah so what ... f*ck abs ..
Old Aug 15, 2006 | 08:38 AM
97-2.2CL's Avatar
All around nice guy....
this just happened to my g/f's 97 2.2 last week. checked the fluid, was low so i topped it off. yesterday, came on again, checked fluid and it was low again. abs light is on and the brake light is on also and the pedal is going almost all the way to the floor when stopping. havent gotten a chance to check codes yet, but if anyone has any helpful info on what i can do, please help..... thanks......
Old Aug 15, 2006 | 09:36 AM
(Mid-Atlantic)
Sounds like your master cylinder, a brake line, or a caliper is leaking fluid, been there done that twice, get it checked by a mechanic b4 her brakes fail on her like they did on me
Old Aug 15, 2006 | 09:40 AM
97-2.2CL's Avatar
cool thx 97blackackcl.....
Old Aug 15, 2006 | 10:53 AM
Sniper3.0's Avatar
same thing happened to me 3X and counting.... Rear passeneger Caliper leaks take it in get new caliper but on, bleed the system, lasts about 3- 4weeks and then the abs light comes on, fluid links and I almost die going through an interestion.
Im starting to think maybe its an issue with the pressure regulator on that line ?
Cant be three faulty calipers but the shop keeps fixing it at their cost saying it is.
Old Aug 15, 2006 | 11:53 AM
97-2.2CL's Avatar
yea i just went and had it looked at and its the pass rear caliper leaking right underneath the spring thingy....... ordered new one from the dealer, will be here wed......then getting fixed asap.... pays to have friends at a honda dealer, parts and mechanics.......
mada51589
Jan 9, 2025 04:40 PM
hedzup
1G RL (1996-2004)
Jun 29, 2016 08:07 AM
fifer16
1G RL (1996-2004)
Oct 16, 2015 08:54 AM
gemz_acura
4G TL Problems & Fixes
15
Sep 26, 2015 06:12 PM
Stu2414
Aug 30, 2015 07:30 PM
