ac problem
Old Jul 27, 2023 | 01:36 PM
deltaflow13's Avatar
ac problem
Hi guys anyone can help me to diagnose a problem with the ac.
My mdx15 started to having problems with the air conditioner when I'm parked start blow mild air not cold but when the car start moving blow cold during the day. In the night sometimes do the same.
That's mean the ac compressor it's about the get out of work?
Cuz I can hear how he start and shutdown a lot when I'm parked with ac on.
Old Jul 28, 2023 | 05:53 PM
MCRacer's Avatar
no, not likely the compressor is going out. Likely you are low on freon. with the engine idling, and stationary (a) the compressor is turning pretty slowly and (b) high underhood temps harder to suck enough freon fast enough as a gas and compress and liquify the freon. so it cycles. once up to speed higher rpm on the compressor problem goes away. This is a pretty common symptom of low freon level
Old Jul 29, 2023 | 04:28 PM
Thank you for the info.
Well I checked the freon and is good almost passing the full line.
Old Jul 29, 2023 | 05:22 PM
MCRacer's Avatar
if the ac has a "sight glass" (something that was common in the 70's, though they had quite using them) you should see NO bubble in the glass when the AC is running, Bubbles=low freon. If it doesn't have a sight glass, where are you checking the freon level?
Old Jul 29, 2023 | 05:34 PM
And when the compressor goes out the gauge goes up
Which fan is the one for cool the condenser? Cuz I only seen the driver side fan working.
Old Jul 29, 2023 | 06:35 PM
MCRacer's Avatar
have you had the AC recharged lately? with that pressure I wouldn't expect the AC to cycle when idling if everything is functional. Now some AC units will shut off if the pressure gets to high. the low side presure you are seeing is in the ballpark for ambient in the 85F + range. If operating correctly, the pressure will drop with lower ambient temps.
However to fully see if the system pressures are as expected you also need to check the high side pressure, but that's not a task for someone without proper tools and understanding, since the high side pressures should be in the range of 150-350psi, highly dependent on temperature. something best left to a shop to analyze.
Old Jul 29, 2023 | 07:53 PM
I got the tools to do it I'll try tomorrow
Ill.trh to keep updated
But im sure that my fan condenser its out...
Old Aug 29, 2023 | 05:27 AM
E92Vancouver's Avatar
Sounds like the system needs a refrigerant top up.
lahull
Integra
Jun 4, 2012 06:39 PM
Forevafire
Oct 15, 2011 06:53 PM
Hektman
1G TSX Problems & Fixes
Sep 27, 2010 06:29 PM
azn5ucka86
Jul 11, 2004 12:43 PM
Chinisimo
Dec 14, 2002 05:21 PM
