A/C question
Old Dec 13, 2002 | 05:30 PM
Chinisimo's Avatar
A/C question
I just start noticing the hissing noise when the AC is turn on doesn't go away. It used to hiss for a few minutes and than turned off. I think something is wrong w/ the AC system. will low frion make it hiss all the time? if i keep the AC on all the time, will it damage the AC?
thanks guys
Old Dec 13, 2002 | 09:06 PM
ding069's Avatar
acura-cl.com OG
OK, i am actually an AC guy, my day job. If you were low on freon, the air would not be coming out as cold as it used to come out, you could need a recharge if that is your problem. The hissing would only be if you had a leak in the tubing, but it would be a very large and out of place leak. So, if freon is too low, the compressor will just shut off, and you wil get no cold air at all. That isnt your problem. Your problem is probably something to do with a fan motor/blade. You might have also lost a vacum.
Old Dec 13, 2002 | 10:10 PM
Chinisimo's Avatar
but i think some other members can hear the hiss inside the car, i think is when the evaporator is kicked in? so, i could used to hear it kick in and out. but it's on all the time now.
any ideas?
Old Dec 13, 2002 | 11:47 PM
ding069's Avatar
acura-cl.com OG
Sorry, that is probably something specific to cars, i know commercial/residential systems. Time to see the mechanic.
Old Dec 14, 2002 | 05:21 PM
Chinisimo's Avatar
bump
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
MikeJM310
Sep 24, 2015 07:24 PM
