Going through a pint + of oil a week
Old Apr 14, 2025 | 08:51 PM
Urhighness420's Avatar
Hello new hear, I have a 09 Acura tsx I have had it over ten years and the car itself is great but….. I recently have noticed my car going through a good amount of oil lately. I drive about 500 miles a week traveling to work and by the end of the week I have to put about a quart of oil in. I have tried changing out the pcv valve in hopes that’s what it is but no luck I’m looking here in hopes I can get some help. Any info is appreciated thank you!
Old Apr 15, 2025 | 12:15 PM
Have you checked under the car for oil leaks?
Old Apr 15, 2025 | 12:29 PM
EasyLoveRDX's Avatar
Zeta is right - first confirm that it's burning the oil and not leaking it.
If it is burning oil - some suggest running Seafoam or Marvel Mystery Oil thru the engine for a couple hundred miles before your next oil change. The idea is carbon and sludge buildup on the cylinder walls cause the piston rings to not make a perfect seal, allowing oil to be burned along with the air/fuel mixture.
Old Apr 15, 2025 | 02:38 PM
I have indeed I park in the garage and there is little to no oil on the ground.
Old Apr 15, 2025 | 02:41 PM
see this is something I haven’t heard before I will give this a shot and next oil change.. I mean I basically am doing one every few weeks minus the filter lol
Old Apr 26, 2025 | 06:25 PM
So I put in some of the high mileage sea foam and it seemed to help quiet my car down even know I never thought of it to be loud but it still seems to be leaking/burning oil. Still no oil leaked under the car that I can notice I park in the garage and I don’t see any new oil marks where I park. I’m just at a loss as to what could cause my car to burn so much oil so quickly. I literally just did a lol change after putting the sea foam in and it has burned through 1/4 if not 1/2 of the oil in just a few days. Not sure if it could be major internal damage like scored cylinders or the rings are stuck or something I cant think of any other reason my car would burn so much oil in such a short period of time. Again any help is much appreciated!
Old Apr 27, 2025 | 09:01 AM
The fundamental issue is that your piston rings aren't sealing in the cylinder, so oil is getting pushed up into the combustion chamber.
So how do you fix that?
Doing some more reading... you could try the next several oil changes (with more frequent intervals) with Valvoline Restore&Protect. If that doesn't work, a piston soak is the next step. Google "piston soak honda k24" for more info.
Old Apr 27, 2025 | 11:23 PM
I will do a search for that I appreciate the feedback. But do you happen to know if the piston soak can be done with the engine still in one piece of is this something that needs to be done once the engine is torn down? I just don’t have another vehicle to be able to get to work and back so I wouldn’t be able to tear the engine down.
Old Jun 12, 2025 | 06:09 PM
DannyMenudo's Avatar
8th Gear
Hi U420 .. I , as well as so many others have your exact problem and I also have your exact year TSX. I was burning about the rate you are and then I followed EXACTLY what this guy does below.. You can skip through his trial and error with seafoam and marvel mystery oil to what did the trick which is the Berrymans B12 fuel injector cleaner.. which you will use for the piston soak. . I went from burning a quart every 400 or so miles to currently at 2000 miles which is the absolute first time this has happened since I owned the car from 2015.
Follow his instructions but the one thing he screwed up on is in order to keep the B12 from flying out all over the place .. you need to put a white t-shirt or cloth folded over a few times , the length of all the piston holes with something laying on top to hold it in place when you turn the motor over the final step . This will also allow you to see what should be 4 very dark circles showing the liquid that shot up to the t-shirt or cloth which is a good sign fwir. I put the video start time after he had tried the Seafoam and STP which did not solve his oil burning.. so at this point he is using B12 for the first time.
Old Sep 7, 2025 | 07:39 AM
Whatsupwtht's Avatar
4th Gear
Same thing here w/ oil
[QUOTE=Urhighness420;16982207]Hello new hear, I have a 09 Acura tsx I have had it over ten years and the car itself is great but….. I recently have noticed my car going through a good amount of oil lately. I drive about 500 miles a week traveling to work and by the end of the week I have to put about a quart of oil in. I have tried changing out the pcv valve in hopes that’s what it is but no luck I’m looking here in hopes I can get some help. Any info is appreciated thank you![/QUOTE
Ok, I've had my 2009 TSX for 10 yrs. now .When I 1st bought my car I had the same issue ! I would go thru a quart of oil every 2wks to a month at a time then finally I had it & thought about this for a week then I remembered everytime it would get low, I would check it & it was 1/2 way between the 1st & 2nd holes then go down to the 1st hole but didn't fill it anymore as It would stay right there ! I continued$ checking for a month & did not lose anymore oil so I just figured then that this was it's "set" spot ! So, I quit filling it when it got down to the 1st hole & let me tell you I have saved sooo much in oil that I probably could've bought a nicer set of tires ! jk I ❤️ my car & am STILL looking wanting to find something wrong so that I can try to fix it ! I just hope you can understand my message & that it MAY work if you try it Take care!🤞
Old Sep 7, 2025 | 07:46 AM
4th Gear
Reset oil light
P.s. I forgot to mention that I would also reset the oil light on the dash after filling to the 1/2 way mark between the 2 holes each time !!!
robm
Sep 18, 2015 07:53 AM
IndycarFaster
Jun 5, 2012 04:41 PM
yom84
1G TSX Problems & Fixes
14
Dec 16, 2011 04:03 PM
conig
Apr 10, 2011 07:13 PM
CASPER
May 12, 2005 07:15 PM
