OFFICIAL Hondata Flashpro Calibration/Tuning Thread
Old 09-04-2015, 07:04 AM
  #881
I like cars.
Username 0's Avatar
Any of you guys having cranking issues? I'm on cal 3.9 and vit hasn't been able to even fix my cranking problem.
Starting to really depress me. My tune is almost done. Car drives great but start ups suck ass!
Old 09-04-2015, 07:46 AM
  #882
boki_cu2's Avatar
Did this start after tune or prob was there before?
Old 09-04-2015, 09:09 AM
  #883
I like cars.
Username 0's Avatar
It was fine when it was stock. This started right after vit sent me my first cal. I have 550cc injectors and SC. But that shouldn't an issue. All the other sc k24 guys don't seem to be having this issue. It's driving me bananas.
Old 09-04-2015, 10:59 AM
  #884
VTEC just kicked in, yo!
xtcnrice's Avatar
Received 1,112 Likes on 876 Posts
<p>Did you experience this when you were on the base SC map? If not, I guess you can try temporarily flashing to the base SC calibration and see if you're still experiencing this. Flash it back to your current map when done testing.</p>
Old 09-04-2015, 11:18 AM
  #885
ROTAREDOM
ssjoeboe9's Avatar
Received 1,488 Likes on 1,058 Posts
<p>
Originally Posted by xtcnrice
</p><p>Did you experience this when you were on the base SC map? If not, I guess you can try temporarily flashing to the base SC calibration and see if you're still experiencing this. Flash it back to your current map when done testing.</p><p>
</p><p>He can't.. base SC map is for 780CC injectors.</p>
xtcnrice (09-04-2015)
Old 09-04-2015, 11:20 AM
  #886
ROTAREDOM
ssjoeboe9's Avatar
<p>Also, before your next comment.. 550CC injectors you have to splice the the OEM harness, soooo going back to stock OR switching to 780CC injectors is going to be a big hassle.</p>
Old 09-04-2015, 11:37 AM
  #887
I like cars.
Username 0's Avatar
There is no base sc map for the 11-14 tsx.
Old 09-04-2015, 11:40 AM
  #888
I like cars.
Username 0's Avatar
Originally Posted by ssjoeboe9
<p></p><p>He can't.. base SC map is for 780CC injectors.</p>
Also as I just posted, there's no sc base map for the 11-14 tsx. I also tried to find another 11-14 sc tsx To compare but no luck.
Old 09-04-2015, 11:47 AM
  #889
xtcnrice's Avatar
<p>
Yeah I realized that mid way typing my response. Did this start occurring even on Vit's cal 1?</p>
Old 09-04-2015, 11:51 AM
  #890
I like cars.
Username 0's Avatar
<p>Yeah I realized that mid way typing my response. Did this start occurring even on Vit's cal 1?</p>
Yeah. I had the problem since cal 1. I believe there is to much fuel being sprayed during cranking. I tried reducing fuel but results are mixed and I can only cold start twice a day. I also have warm start issues as well. The entire cranking fuel is off it seems. I even email hondata thinking maybe there was a glitch with bigger injector compensation but they said there end is good.
Old 09-04-2015, 12:39 PM
  #891
ROTAREDOM
ssjoeboe9's Avatar
<p>I mean... it might be a good idea to take it to a tuner, specifically for cranking. They may be able to see something that Vit cannot, simply because they are there in person to diagnose.</p>
Old 09-04-2015, 01:12 PM
  #892
I like cars.
Username 0's Avatar
I might have to do that if all else fails.
Old 09-04-2015, 02:06 PM
  #893
Jaheri_cbp's Avatar
How old is your battery?? It may not have enough cold crank amps to start it well?? With the added drag of the supercharger cranking during starts maybe it's your battery getting too tired.. Just an educated guess idk it's worth a quick check though...
Old 09-04-2015, 02:49 PM
  #894
I like cars.
Username 0's Avatar
Battery is new. That's the first thing I changed because my cranks we're going under 9v.
Old 09-04-2015, 02:51 PM
  #895
Jaheri_cbp's Avatar
Oooooooooo ok... Well I'm fresh out of ideas now lol
Edit: well maybe there might be some added drag during starting that shouldn't be there?? Too much belt tension? Starter going bad?? Just thinking out loud.. Sucks this would be driving me nuts...
Old 09-04-2015, 03:51 PM
  #896
Jaheri_cbp's Avatar
Just maybe thinking it's something mechanically going on.. Cuz if VIT couldn't tuned it out??...
Old 09-04-2015, 04:03 PM
  #897
I like cars.
Username 0's Avatar
Well Vit is still in the process of tuning the cranking issue. From what I learned, cranking fuel can be a bit of a bitch to tune because well you can only do one or two cold cranks per day and sometimes you have to tune the coolant temp compensation and the IAT compensation on top of global cranking fuel setting and the cranking fuel tables. So im giving Vit time to sort it out for me.
Old 09-04-2015, 04:15 PM
  #898
ROTAREDOM
ssjoeboe9's Avatar
<p>The troubles of being 1st.... I know the feelz&nbsp;</p>
Old 09-07-2015, 10:52 AM
  #899
UTAH TSX's Avatar
New mod support your tuner sticker
iCrap (09-07-2015)
Old 09-07-2015, 02:17 PM
  #900
xtcnrice's Avatar
<p>Car looks great UTAH!</p>
UTAH TSX (09-07-2015)
Old 09-08-2015, 11:36 AM
  #901
Cu2Suspect's Avatar
Disreguard -_-
Old 09-08-2015, 11:47 AM
  #902
curtdragon's Avatar
Originally Posted by Cu2Suspect
Disreguard -_-
I was going to say click the where's my tune button
Old 09-08-2015, 04:06 PM
  #903
Cu2Suspect's Avatar
Email ended up in my spam.... Felt retarted
Old 09-09-2015, 03:56 PM
  #904
ROTAREDOM
ssjoeboe9's Avatar
<p>@UTAH TSX I don't wanna say my sticker placement is better... but... it kinda is :P<br /><br /><img src="http://cimg7.ibsrv.net/gimg/acurazine.com-vbulletin/1024x1024/80-ec069fe1_68ea_4dd6_a571_1c9875ef6dd1_zpsawyw7dvp_4 af9e7ea66b8ae38c37630c2b276231d4ba92c21.jpg" title="" /><br /><br />&nbsp;</p>
UTAH TSX (09-10-2015)
Old 09-10-2015, 08:54 AM
  #905
ulrblitzer's Avatar
<p>
Felt retarted <img alt="" src="images/smilies/ugh.gif" title="ugh" />
</p><p>You tarted?</p>
Old 09-10-2015, 07:20 PM
  #906
I like cars.
Username 0's Avatar
Vit just told me I'm the only K24Z with the hard start issue. I want to kill myself.
Old 09-10-2015, 10:10 PM
  #907
UTAH TSX's Avatar
Explain what it does cranks for a long time ? starts and chugs wont rev up ?
Old 09-10-2015, 10:36 PM
  #908
I like cars.
Username 0's Avatar
Just cranks for a long time.
Old 09-10-2015, 11:10 PM
  #909
UTAH TSX's Avatar
It's very easy to adjust cranking fuel write down the settings vit has then play with it change it 20% lower and try it for a day see what it does and the same with the tip in fuel compensation in the throttle calibration, usually if it is getting to much fuel it will sputter and chug after starting my guess is it is not enough fuel on cranking.
first try priming the pump before starting turn the key on for 5 seconds and off do that 3 times then start it if it starts right up that means the fuel is draining back into the tank (bad check valve in pump)
Old 09-11-2015, 11:31 AM
  #910
I like cars.
Username 0's Avatar
I'll try that. He's got me adjusting the fuel cranking table right now. It's so hard cuz there are like 4 different places to adjust cranking feul and I'm not sure which one to focus on. It's really stressing me out. The car only has 9k miles on it so it's practically still a new car. He also said that it might be vapor lock. I never had this problem until I put the sc kit on with 550cc injectors. My head is just spinning.
Old 09-11-2015, 12:08 PM
  #911
I like cars.
Username 0's Avatar
One confusing observation... I compared the stock fuel cranking table between the k24z3 and the k24z7 and there is a huge difference. The z3 is at about 8000 and the z7 is at 16000. This is at the "0.0" column. Why is that? I though the tsx and the SI motors were very similar engine wise.
Old 09-11-2015, 07:35 PM
  #912
threetwentyfizzle's Avatar
Dang bro, did you forfeit your factory warranty with the SC install? Long Crank issues aside, how you liking the added power from the SC? Anyone here happen to get warranty work done and have any issues with the FP software being detected by the dealer?
Old 09-11-2015, 09:24 PM
  #913
I like cars.
Username 0's Avatar
Breaking warranty (if I even have any) is worth breaking for the SC. I love it except for the cranking crap I'm dealing with. I read a post where some guy went to the dealer for some repairs and they ended up "updating" his ecu over his reflash. But that's about it. Not sure if they can detect that sort of stuff.
Old 09-11-2015, 10:25 PM
  #914
ROTAREDOM
ssjoeboe9's Avatar
<p>Fuck her right in the Pussy!</p>
iCrap (09-12-2015)
Old 09-12-2015, 12:41 AM
  #915
I like cars.
Username 0's Avatar
Has someone been drinking? Or perhaps to much boost in the brain?
iCrap (09-12-2015)
Old 09-12-2015, 08:28 AM
  #916
ROTAREDOM
ssjoeboe9's Avatar
<p>hmmmmm.... sorry about that outburst. Totally out of character for me.</p>
iCrap (09-12-2015)
Old 09-21-2015, 02:50 PM
  #917
7th Gear
ftblstud45's Avatar
2012 tsx se at
Anyone have a MAP for the 2012 TSX SE AT?
I have the CT Icebox and a custom exhaust. Will be doing the RV6 downpipe and cat delete soon
Old 09-21-2015, 03:27 PM
  #918
TSX AMG Type //M i-VVT
iCrap's Avatar
yeah it's posted a few pages back
Old 09-21-2015, 03:54 PM
  #919
xtcnrice's Avatar
<p>
Originally Posted by ftblstud45
Anyone have a MAP for the 2012 TSX SE AT? I have the CT Icebox and a custom exhaust. Will be doing the RV6 downpipe and cat delete soon
Here's the calibration. I took Dime Feng's 09-10 5AT map and copy/pasted all the values into a clean 11+ map. I haven't seen any <em>real&nbsp;</em>problems and I've been using the calibration on my 2013 tech for over half a year now. I've seen some random phantom knocks... but I suspect this is just road noise or noise/vibration from the RV6 PCD that I have. Also when I'm on WOT, shifting from 2nd to 3rd, there's a sudden loss of power about 1s after the shift is done, then the RPMs begin climbing back up. I realized this isn't related to the map at all, but rather a shitty side effect of owning an automatic transmission (torque converter lockup).</p><p>Mind you, Dime Feng had quite a few mods going, so YMMV. Good luck, and let us know how it goes. BTW, where'd you get the Icebox from?</p>
File Type: zip
Rideout421 (07-17-2018)
Old 09-21-2015, 04:05 PM
  #920
iCrap's Avatar
dime feng had the injen intake, p2r spacer (dosen't do shit) and the downpipe. (all that was in the cal notes)
so the only actual mod that should have made a difference was the downpipe anyways.
same as xtc i have been running that cal for a long time now with no prob.
The only cal that ever gave me problems was OptimusAccords original one, it would cause my car to randomly stall and die so i would have to keep the rpm up at idle.
Quick Reply: OFFICIAL Hondata Flashpro Calibration/Tuning Thread
