how to add a sub and amp to stock system 2010 tsx
Old Jul 17, 2013 | 08:53 AM
amarranjha's Avatar
mr_tsxranjha
hey guys. im looking for some information to get this done by myself.
i want to add a amp and sub to my stock sound system that i have. i will leave the old sub in just add another am and sub.
how will i do this? do i need any wire adapters for the stock radio or i could connect the wiring straight to the wiring already therE?
hmu w some info
Old Jul 17, 2013 | 09:29 AM
iCrap's Avatar
TSX AMG Type //M i-VVT
Line out converter from the stock sub output into an amp, then into your new sub.
Old Jul 17, 2013 | 09:54 AM
amarranjha's Avatar
mr_tsxranjha
can u suggest a good line out converter?
Old Jul 17, 2013 | 10:37 AM
amarranjha's Avatar
mr_tsxranjha
one more question..
will it be possible to install a kill switch to the amplifies?
i know the remote wire does than when the car is off.
but if i want to turn it off when the car is on.
would i install it to the power wire? or to the remote wire?
Old Jul 17, 2013 | 05:16 PM
musty hustla's Avatar
install an inline switch
Old Jul 18, 2013 | 09:08 AM
D4nnyD's Avatar
Originally Posted by amarranjha
one more question..
PAC sells some good inline converters.
http://www.sonicelectronix.com/cat_m...onverters.html
I would just use the same wires coming off the stock sub and wire it in parallel. As for kill switch, i would just get a switch that looks like the VSA button and mount it right in one of those empty spots. The remote wire is a 12 volt signal wire that you can get off your fuse box and run it through that switch and then to your amp. Simple on / off
Old Jul 18, 2013 | 09:50 AM
amarranjha's Avatar
mr_tsxranjha
i will be using one of those loc from the stock sub to the amp but any idea which one will i need? theres soo many variety. i dont know which one i will need. any suggestions?
Old Jul 19, 2013 | 09:13 AM
amarranjha's Avatar
mr_tsxranjha
ok so i installed the amp and sub.
i ran the wires to the amp. power from the battery and remote from a fuse in the footwell. i used the sunroof fuse so when the car is off the amp will shutoff. and the ground to a bolt in the trunk.
the amp was working until i installed the loc. the amp seems to go into safemode. but how? i got no idea it just wont work. any ideas on what may have gone wrong?
Old Jul 19, 2013 | 02:58 PM
D4nnyD's Avatar
Good stuff. Do u have the model number of the amp and line in converter available? might just be a setting issue. Or maybe you plugged your RCA's into the the preamp out of your amp instead of the input channel... just an idea. i'm sure your smarter than that
cycdaniel
Dec 17, 2019 10:58 AM
Rocktman1
Oct 31, 2015 02:33 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
yahelou
Sep 6, 2015 09:12 PM
jordanboi
Sep 5, 2015 01:33 AM
