2G TSX Chat, Chit, and General Info Thread
So, has the TSX forum dropped off the main forum page and off the AZ header bar or am I just having a seizure or something?
I can't seem to find it anywhere and need to use the tsx.acurazine.com redirect to get in.
Are they finally kicking us out because the TSX is a relic or was it too many dick jokes?
Voice your opinions here
https://acurazine.com/forums/acurazi...n-menu-925675/
Outrageous. It's been missing from the other dropdown menus for a few months now. How difficult could it be to fix this? ffs.
Check Azine Black Market, local Craigslist, eBay. Junk yards are fine too... but naturally, they may not be in the best condition.
FYI, if you have a 2G TSX (I assume you do... cuz you posted this in the 2G TSX forum), like most Hondas/Acuras for the past few years now you will want a wheel that is 5x114.3 in bolt pattern with a 64.1mm center bore. Pretty much any OEM 17" wheel with those specs will fit the TSX. I'm like 99.9% sure there aren't any 5x114.3 64.1CB OEM wheels that have overly aggressive/unaggressive specs that you would run into contact issues with the fenders/suspension. They will all likely be in the 7" wide +45 - +55 offset range.
Post there or PM honda_boy83. Not sure if you need tires also but they pop up on the black market every now and then.
