Low beam on the right side dead.
Old Sep 8, 2017 | 12:52 PM
vcastillojr's Avatar
I replaced the bulb which cost me 100 bucks. Still dead. Checked fuses one blown the highbeam replaced highbeam works, low beam dead. Help!..i checked all fuses only the one was blown.
Old Sep 8, 2017 | 01:18 PM
Ballast is dead Jim. Replace it with an aftermarket one. The OEM is atrocious
Old Sep 8, 2017 | 01:27 PM
thanx i was hoping i didnt have to take the whole thing apart again. Makes sense.
Old Sep 8, 2017 | 01:31 PM
i just replaced light casing with aftermarket ones, everything was fine until two days ago
Old Sep 8, 2017 | 01:39 PM
Leaking perhaps or just a coincidence. So you put in new aftermarket housings but kept the ballast bulbs etc the same.?
Just check all your connections to rule out user error
Old Sep 8, 2017 | 01:54 PM
correct
Old Sep 8, 2017 | 02:01 PM
https://acurazine.com/forums/2g-tl-p...type-s-958753/
Link in here!
Old Sep 9, 2017 | 04:04 AM
01acls's Avatar
Swap your ignitors, if the problem follows then the ignitor is defective.
If the problem doesn't follow the ignitor and still exists on the same side then the ballist is bad.
If both headlamps are acting up after the swap then both the ignitor and ballist are defective at their original defective location.
Old Sep 10, 2017 | 06:29 AM
frankjnjr's Avatar
Very easy and effective diagnostic. Thank you 01acls, for yet another simple fix resource.
Old Sep 12, 2017 | 12:15 PM
Homestead12's Avatar
Buy a used ballast and igniter from ebay and replace them both on the headlight. I had to do this with both of my headlights on separate occasions. It's such a hassle to have to take the bumper off twice but it had to be done. Should run you about $55 for a ballast and igniter (For each headlight).
Old Sep 12, 2017 | 12:55 PM
Diode Dynamics's Avatar
Former Sponsor
+1 on replacing with an OEM ballast. I'd visit your local salvage yard if you can't find one on eBay.
Nick C.
Old Sep 13, 2017 | 03:35 PM
tbizzle's Avatar
Geez, I didn't know headlights were such a pain in the ass on these...
Old Sep 19, 2017 | 01:19 PM
Kris9884's Avatar
$100 for an HID bulb?? I grabbed a 4300k knockoff brand on eBay for like $12 and has been going strong for almost a year so far..
