Rpm
Old Sep 20, 2017 | 07:56 AM
Frito's Avatar
Rpm
I have a 2000 acura 3.2 TL & my rpm meter constantly goes up and down just when park. what the problem with that??
Old Sep 20, 2017 | 08:14 AM
jjojo2004's Avatar
9th Gear
Possibly clogged EGR passages in the intake manifold or the use of gas less than 91 octane. At least that's what affected my 2001 CL Type S.
Old Sep 20, 2017 | 08:19 AM
gnuts's Avatar
3.5 psi
your Idle Air Control Valve is probably dirty which makes it stick, that or a vacuum leak, but the IAC is more likely unless you recently had some of the engine apart. It's one of the black things on the throttle body. You can try cleaning it with carb cleaner, or just get a new one.
https://acurazine.com/forums/second-...-valve-456491/
TSX1012m6
Oct 15, 2019 02:22 PM
pdpunome
1G RDX Problems & Fixes
Aug 12, 2017 08:45 AM
MrVtech
Feb 28, 2017 09:12 AM
eurosport360
Dec 25, 2016 06:42 PM
sseiyah
4G TL Problems & Fixes
Dec 14, 2016 06:33 AM
