Low beam on the right side dead.
I replaced the bulb which cost me 100 bucks. Still dead. Checked fuses one blown the highbeam replaced highbeam works, low beam dead. Help!..i checked all fuses only the one was blown.
Swap your ignitors, if the problem follows then the ignitor is defective.
If the problem doesn't follow the ignitor and still exists on the same side then the ballist is bad.
If both headlamps are acting up after the swap then both the ignitor and ballist are defective at their original defective location.
Buy a used ballast and igniter from ebay and replace them both on the headlight. I had to do this with both of my headlights on separate occasions. It's such a hassle to have to take the bumper off twice but it had to be done. Should run you about $55 for a ballast and igniter (For each headlight).
