Low beam on the right side dead.
I replaced the bulb which cost me 100 bucks. Still dead. Checked fuses one blown the highbeam replaced highbeam works, low beam dead. Help!..i checked all fuses only the one was blown.
Ballast is dead Jim. Replace it with an aftermarket one. The OEM is atrocious
(Post 16091198)
(Post 16091198)
Leaking perhaps or just a coincidence. So you put in new aftermarket housings but kept the ballast bulbs etc the same.?
Just check all your connections to rule out user error |
(Post 16091209)
Swap your ignitors, if the problem follows then the ignitor is defective.
If the problem doesn't follow the ignitor and still exists on the same side then the ballist is bad. If both headlamps are acting up after the swap then both the ignitor and ballist are defective at their original defective location. |
Originally Posted by 01acls
(Post 16091451)
Originally Posted by vcastillojr
(Post 16091183)
+1 on replacing with an OEM ballast. I'd visit your local salvage yard if you can't find one on eBay.
Nick C. |
Geez, I didn't know headlights were such a pain in the ass on these...
$100 for an HID bulb?? I grabbed a 4300k knockoff brand on eBay for like $12 and has been going strong for almost a year so far..
