fans stay on and wants to stall
Old Mar 11, 2006 | 01:15 PM
blue tl-s's Avatar
After i start my car after its been sittin for a few it runs really rough and wants to stall and also the fans will turn on.I have to turn it off and restart and its better. Also sometimes the fans stay on after i shut the car off!
Old Mar 11, 2006 | 01:24 PM
blue tl-s's Avatar
btw 02 tl-s 47,000 miles.
Old Mar 11, 2006 | 01:28 PM
fsttyms1's Avatar
fans can and will run with the engine off. Them running with out more info doesnt mean much. Hows the temp gauge? Normal? Also only 1 fan should be running the other fan is for the AC
Old Mar 11, 2006 | 01:47 PM
blue tl-s's Avatar
temp gauge is fine.they just turned on when i started the car and it was wanting to stall.
Old Mar 11, 2006 | 02:09 PM
fsttyms1's Avatar
Both are on?
Old Mar 11, 2006 | 02:25 PM
blue tl-s's Avatar
dont know didnt get out to check. but this is the second time this happened!
Old Mar 12, 2006 | 07:16 PM
blue tl-s's Avatar
just happened a couple more times 2day. When it was idling rough i gave it a little gas and a puff of smoke came out the grill! i popped the hood right away but found nothin? maybe backfire out the intake?it has a aem cai. please help i hate payin people to fix my cars!!
Old Mar 12, 2006 | 07:42 PM
fsttyms1's Avatar
Does the check engine light come on at all? Something is causing the fans to come on. The rough idle could be a few things. But throwing things out there would just be a guess. Have you checked your coolant level? You may want to try bringing it to a autozone or some place like that that does free ecu scanning to see if a code does happen to come up.
Old Mar 13, 2006 | 09:24 AM
blue tl-s's Avatar
no check engine light. The fans came on only the first time time it happened. The radiator looks a tad low the the overflow is ok. I looked at the tb for build up of any kind but looked ok?maybe egr? can i take it off and look?
Old Mar 13, 2006 | 10:13 AM
fsttyms1's Avatar
Its possible, but there should be a checkengine light if the egr is stuck or plugged. The rough idle, do you notice the tach/rpm going lower than normal all the time or just intermitent?
Old Mar 13, 2006 | 10:40 AM
blue tl-s's Avatar
When i come to a aprupt stop the rpms will drop real low like its gonna stall.for some reason this only happens on start up. One time last year it didnt want to start the first time i had to let it sit a few minutes? Im this close to takin it in but in a do-it-yourselfer!
Old Mar 13, 2006 | 11:34 AM
Pure Adrenaline's Avatar
Dragging knees in
How is your air filter?
My car kept wanting to stall out and basically exhibiting similar symptoms... then one day while doing an oil change, I decided to check on the filter and it was completely clogged with dirt and grease.
Cleaned it out, and it stopped the rough idle and almost stalling.
Old Mar 13, 2006 | 12:52 PM
blue tl-s's Avatar
the filter is fine.
Old Mar 13, 2006 | 03:27 PM
blue tl-s's Avatar
i check my egr and looks fine. i was wondering, when i installed my cai i had to reroute some "coolant lines?" that go to the first throttle body what ever that is, maybe i rerouted them wrong? any pictures of that area??
Old Mar 13, 2006 | 03:56 PM
fsttyms1's Avatar
? how did you check your egr?
Old Mar 13, 2006 | 04:29 PM
blue tl-s's Avatar
just took that somunabitc off and checked the passages. So what is that first butterfly valve i was talkin about?
Old Mar 13, 2006 | 05:09 PM
fsttyms1's Avatar
That is your throttle body.
Old Mar 13, 2006 | 05:48 PM
blue tl-s's Avatar
so there r 2 throttle bodys? Not the one with the throttle cables but the on in front of it?
Old Mar 13, 2006 | 06:17 PM
fsttyms1's Avatar
You have a TL-S? If so that is the buterfly for the VSA
F-C
Motorsports News
33
Aug 22, 2018 09:53 AM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
gatrhumpy
19
Dec 31, 2015 04:22 PM
hashbrown
Sep 29, 2015 12:13 PM
