Clanking sound when stoppped
Old Mar 11, 2006 | 07:00 PM
ArN 2000 TL's Avatar
Moderator Alumnus
I have the worst sounding (fairly loud) clanking sound from the drivers side back part of the engine compartment (near firewall).
It is very noticeable at lights when i am in D5 and have my foot on the brake. Once i accerelate from the light the sound is gone. This also applies when the car is in motion, however once i stop at a light or whatever it starts again.
If i throw the car in Nuetral and let my foot off the brake it stops. I looked under the hood for anything out of the ordinary, but didnt find anything. its a '00 with 92k on it.
Old Mar 11, 2006 | 08:37 PM
NSXNEXT's Avatar
Catalytic converter heat shield?
Old Mar 11, 2006 | 08:39 PM
optomos's Avatar
I=X - optomos
Hm, have you checked the mounts yet especially the one by the tranny. Could also be the heat shield on the exhaust.
Old Mar 11, 2006 | 08:53 PM
Moderator Alumnus
I got all 3 motor mounts replaced under warranty around 65-70k i believe. I'll check the heat shield tomorrow and see if thats the problem....thanks!
Old Mar 13, 2006 | 10:58 AM
acutee's Avatar
What is your story of getting the mounts replaced under warranty at that mileage?
Old Mar 13, 2006 | 12:54 PM
fsttyms1's Avatar
Sounds like a Heatsheild
Old Mar 13, 2006 | 02:17 PM
Moderator Alumnus
I had the extended warranty on the car and actually brought it in due to the tranny failing and they told me they would replace them under warranty while doing the tranny swap. go figure.
Old Mar 13, 2006 | 02:18 PM
Moderator Alumnus
Thanks. I was supposed to take a look at it sunday but the weather was crappy. Its driving me crazy every morning on the way to work.
Can i replace it or is it something i'm going to have to rig?
Old Mar 13, 2006 | 03:58 PM
fsttyms1's Avatar
Look to see if its loose or rattling. You may be able to reclamp it or just plain remove it (if thats what it is)
Old Mar 13, 2006 | 04:47 PM
acutee's Avatar
There was one thread mentioned about the clip on the o2 sensor wire running up to the engine causing the rattling noise.
Old Mar 13, 2006 | 08:48 PM
Moderator Alumnus
I think i might have found the problem. Today driving home from work i was embarassed to pull next to someone at the light it was that bad.
Opened the hood and checked under the car...heat shield felt solid and i couldn't find anything else out of place. I figured while i was there i would check my air filter on my CAI. Sure enough the piping from the CAI was rubbing where it goes through to the bottom part of the car where the air filter connects.
When i got my battery replaced the moron at Sears must have pushed the CAI over trying to grab the battery and bent my brakcet that connects to the chasis from the CAI. It was almost cut all the way through. I wrapped some rubber type tape around it, heated the brakcet and slowly bent it back and then re-tightened everything and I should be good to go. I'll keep this thread updated....hopefully it was just that.
mlody
Dec 4, 2019 02:11 PM
DerrickW
Nov 15, 2015 05:52 PM
blacktsxwagon
Oct 27, 2015 10:12 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
hashbrown
Sep 29, 2015 12:13 PM
