Heavy door
Old Mar 14, 2006 | 07:50 AM
parshooter's Avatar
Back in the slow lane.
Heavy door
I just noticed this yesterday. My driver's side door seems to really be "heavy" now. It doesn't swing open/closed as easy as it used to. It doesn't make any type of noise and nothing unusual has happened to the car. Do I just need a lube job?
Old Mar 14, 2006 | 11:12 AM
03CoupeV6's Avatar
05 C230K & 09 135i 6MT
Unless the car is mysteriously gaining weight then you should just use some WD-40 on the hinges.
Old Mar 14, 2006 | 01:05 PM
bkzjimmy's Avatar
NiGhT rIdEr
Old Mar 14, 2006 | 05:06 PM
fsttyms1's Avatar
Mine did the same, i had to grease up the hinges and there is a flat rod that goes into the door that helps hold it open and keeps it from slamong shut. That will need some lube. Lube it and open and close abunch of times and relube it.
soupi
14
Nov 15, 2015 11:15 AM
BIGxRED
Oct 19, 2015 10:47 PM
chiu0nthls
3G MDX (2014-2020)
Sep 28, 2015 03:46 AM
Sue1910
2G CL Problems & Fixes
Sep 27, 2015 12:34 PM
ceb
ILX
Sep 27, 2015 10:56 AM
